Projector Calibration (6040UB) - Second Look - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 63Likes
post #31 of 180 Old 06-28-2019, 07:31 PM
Quoted: 4483 Post(s)
Liked: 1678
Originally Posted by AdamAttewell View Post
I see, but I have not touched the CMS controls at all up to this point. Unless the CMS controls are related to the gamma or grayscale controls?
I just noticed that the Before and After saturation sweeps were measured at very different luminance levels - 58 nits vs 27 nits.
Were they in the same Picture Mode? Super white reduces luminance by only about 20%.
Dominic Chan is online now
post #32 of 180 Old 06-28-2019, 07:53 PM - Thread Starter
AdamAttewell's Avatar
Quoted: 644 Post(s)
Liked: 132
That will be because I closed the iris down manually as I read that 16fL is the recommended for front projection in light controlled environments.
With the iris wide open which is the default I was measuring 26.5 fL which was to bright from my environment.
Is this an issue?
AdamAttewell is offline
post #33 of 180 Old 06-28-2019, 09:20 PM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
What do you guys think of this?
The CMS adjustments did not do much for the 100% primaries & secondaries, I guess this is normal?
post #34 of 180 Old 06-29-2019, 07:07 AM
Liked: 1678
These results look excellent. Care to post the settings, for those without the equipment and/or expertise?
The CMS adjustments in general cannot increase the 100% saturation levels (or maybe hue in some directions), as those are inherent limitations of the displays. However, they are often able to decrease the saturation.
AdamAttewell likes this.
post #35 of 180 Old 06-29-2019, 11:20 AM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
Sure I can post up my settings, I cant do it right now as I am not at home but I will be sure to later.
I did have a quick look at the other picture modes to see if they provide a better coverage of the color space & the Dynamic picture mode does as all the primaries are beyond the rec 709 triangle but when I tried to get the grayscale in line massive errors were present which the two point controls had little to no effect on correcting.
I remember when I first got this projector I used my Lumagen & its 3D LUT to calibrate & using the dynamic mode gleaned great results.
I guess because the Lumagen has a 21 point grayscale control & the 9x9x9 3D LUT to work with its no wonder even better results can be achieved.
I have attached the results I got back in 2016, amazing what autocal can do.
Shame I cant use the Lumagen now because of my setup & it being a HDMI 1.4 device.
Name:	After Saturation Sweep.jpg
ID:	2585602   Click image for larger version
Name:	After Luminance Sweep.jpg
ID:	2585604   Click image for larger version
Name:	After Grayscale.jpg
ID:	2585606   Click image for larger version
Name:	After Clourspace.jpg
ID:	2585608   Click image for larger version
Name:	After Clourchecker.jpg
post #36 of 180 Old 06-29-2019, 12:20 PM
Liked: 1678
I did have a quick look at the other picture modes to see if they provide a better coverage of the color space & the Dynamic picture mode does as all the primaries are beyond the rec 709 triangle but when I tried to get the grayscale in line massive errors were present which the two point controls had little to no effect on correcting..
Doesn’t Cinema mode also have wider gamut than Natural?
post #37 of 180 Old 06-29-2019, 03:22 PM
jt7272's Avatar
Quoted: 46 Post(s)
Liked: 42
Yes, it does, but at a significant cost to lumens.
Anyways, these calibration results look quite good. You probably won't do better on the 5040/6040. Nice work!
Epson 6040ub
Denon AVR-X3400H + Mirage OMD-5 surrounds
Home-made Hybrid PCB Electrostatic Floorstanding L+R Speakers (with built-in DSP + amps)
Home-made sub with 15" Ultimax woofer, Dayton SA1000 Amp
Sony PS4, Sony UBP-X800, Panasonic DP-UB820
jt7272 is offline
post #38 of 180 Old 06-29-2019, 11:42 PM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
Many thanks guys for all your help & feedback with this, it really has been a massive help to know I am on the right path.
I will watch some content to see how everything looks, the only thing that I was thinking about was setting luminance at 16fL & if that is bright enough but I guess I will only know until I start watching content.
Now onto what I have been dreading a little & that is HDR.
I am a little at a loss at where to start seeing as there seems to be so many ways to tackle HDR on low nit displays.
I would like to use the light filter to get the expanded color gamut as I am in a light controlled environment so probably can afford to lose the output.
I guess Cinema mode is the place to start if I want to use the filter.
Is the workflow for HDR similar to SDR or are they very different?
I read using gamma formula BT2390 is preferred for calibrating HDR on projectors. CalMAN has this function with you also being able to input the displays measured white level.
Is the best place to start with brightness & contrast? I have R.Masciola's HDR test patterns, I presume I can use these to check brightness & contrast?
post #39 of 180 Old 07-02-2019, 04:31 AM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
As promised here are my settings for my SDR calibration.
Color Mode: Natural
Brightness: 51
Contrast: 49
Color Saturation: 50
Tint: 50
Power Consumption: ECO
Auto Iris: Normal
Color Temp: 6000K
Skin Tone: 4
Colour Temp: Customized
Offset R: 48 Offset G: 49 Offset B: 49
Gain R: 50 Gain G: 47 Gain B: 48
Sharpness:
Standard: 5 Thin Line Enhancement: 5 Thick Line Enhancement: 5
Image Enhancement: Preset 3
Gamma: Customized
Color Tone 1: 0
Color Tone 2: -6
Color Tone 3: -12
Color Tone 4: -14
Color Tone 5: -16
Color Tone 6: -16
Color Tone 7: -17
Color Tone 8: -22
Color Tone 9: 0
RGBCMY
Red
Hue: 53 Saturation: 42 Brightness: 52
Green
Hue: 71 Saturation: 50 Brightness: 48
Blue
Hue: 57 Saturation: 42 Brightness: 45
Cyan
Hue: 48 Saturation: 63 Brightness: 38
Magenta:
Hue: 57 Saturation: 47 Brightness: 42
Yellow
Hue: 49 Saturation: 37 Brightness: 59
Epson Super White: On
Lens iris: -20
Color Space: Auto
Dynamic Range: Auto
Image processing: Fine
Also here is my rough understanding of how the gamma controls map to grayscale points.
Color Tone 1: N/A
Color Tone 2: 0%, 10% & 20%
Color Tone 3: 20% & 30%
Color Tone 4: 30% & 40%
Color Tone 5: 40%
Color Tone 6: 50% to 70%
Color Tone 7: 60% to 80%
Color Tone 8: 90%
Color Tone 9: N/A
Juboy and dimi123 like this.
post #40 of 180 Old 07-02-2019, 07:24 AM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
@Dominic Chan
Struggling a little with calibrating HDR can you point me in the right direction?
I found ViperLogic's workflow over on the HDR thread & have been following it but I struggling to get my EOTF curve to match the target even with maxing out the gamma controls except points one & nine.
Before adjusting gamma & contrast
After adjusting gamma & contrast
I have then maxed out the contrast control but I still cant match the EOTF curve.
I am using the Digital Cinema mode with power consumption on medium for this run.
I have followed his guide as closely as possible the only things I am unsure are about are as follows:
1. When using the two point grayscale controls I need to have the gamma formula “ST 2084 HDR” selected & then change to “ITU BT2390 EETF” when using the gamma controls like this?
2. In CalMAN there is no option to set “Diffuse White” but it is probably called a different name?
Would this be the “use measured white level” option?
“Set "Diffuse White[nits]" to what you personally would like, one school of thought is set it to what you use for 100% for SDR movies eg somewhere between 20 or 40 nits.”
3. Again there is no “Target MaxL” option in CalMAN, I am unsure if this is called “use measured white level” also or is something else?
“Set “Target MaxL” to your 100% measure from the grayscale run.”
4. Last but not least which Colorspace should I be using? BT.2020 HDR or D65 P3?
post #41 of 180 Old 07-02-2019, 04:35 PM
Liked: 1678
I don't use CalMAN, so take the following replies with a grain of salt.
The HDR ST.2084 PQ curve is supposed to be "absolute" (unlike SDR gamma which is relative). However, most people find it is far too bright for projectors in a dark room, and scale the curve down in luminance.
BT.2390 is for tone mapping of the highlights (and also the shadow details, but that's the topic for a separate discussion). If you don't use it, all the highlights beyond the projector's peak luminance will be clipped.
It's simply called "White Level".
"Use measured white level" would apply a multiplier to scale the target curve such that the measured white level becomes the target white level.You would normally only do that if the display already has an HDR curve that you're trying to fine-tune to match ST.2084.
If you're using a custom gamma curve the "measured white level" has no significance and you should set the White Level to a suitable level based on your preference and the peak luminance you're getting. 20-25 is a good starting point; a higher value will make the overall picture brighter, but less “HDR-like”.
You can't really set Target MaxL; it's whatever peak luminance you're getting.
HDR10 uses BT.2020 colorspace. However, most consumer displays can only reach P3 gamut, so you would aim for P3 during calibration. I'm not sure if that's built into the CalMAN workflow.
post #42 of 180 Old 07-02-2019, 06:50 PM
donetodeath's Avatar
Color Mode: Natural
Brightness: 51
Contrast: 49
Tint: 50
Auto Iris: Normal
Color Temp: 6000K
Skin Tone: 4
Sharpness:
Gamma: Customized
Color Tone 1: 0
Color Tone 2: -6
Color Tone 3: -12
Color Tone 4: -14
Color Tone 5: -16
Color Tone 6: -16
Color Tone 7: -17
Color Tone 8: -22
Color Tone 9: 0
RGBCMY
Red
Green
Blue
Cyan
Magenta:
Yellow
Lens iris: -20
Color Space: Auto
Dynamic Range: Auto
Color Tone 1: N/A
Color Tone 5: 40%
Color Tone 8: 90%
Color Tone 9: N/A
Thanks for posting your sdr settings, your methodology looks solid. It’s a huge help to those of us without calibration equipment equipment! May I ask what screen you used when doing this calibration?
donetodeath is offline
post #43 of 180 Old 07-03-2019, 03:05 AM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
The screen material is TecVision® XT1000X White from Draper & has a gain of 1.0
post #44 of 180 Old 07-03-2019, 03:26 AM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
Big thanks Dominic, so I need to be targeting a white level of around 20 to 25 nits & not using the "measured white level" option.
I presume this nit level is so low because of the filter being in place? Without the filter I can get around 140 nits, would I set the white level at 140 nits for picture modes without the filter active?
I will have another try calibrating the Digital Cinema piture mode which has the filter active but from my first run it was very dark & will probably be leaning towards using Bright Cinema or Natural for the brightness as I dont want to use high power consumption due to fan noise.
I did complete a calibration run with the Bright Cinema mode & the results look very good with content but I was not able to get the errors all under a Delta E of two with the CMS controls which is what ViperLogic's guide suggests, I understand in this mode the 100% saturation points are never going to be on target due to the filter not being present but I had hoped for a little less error upto the 50% saturation points.
Grayscale from Bright Cinema Run
Saturation Sweeps from Bright Cinema run
Is this amount of error normal for the saturation sweeps in the Bright Cinema picture mode? I had colorspace set to D65/P3.
With my Digital Cinema run I again struggled with the CMS, the saturation points were way off & I guess becuace luminance is factored into the error this is why I cant hit the targets?
post #45 of 180 Old 07-03-2019, 05:05 AM
Liked: 1678
This would be the peak luminance (at 100% input). You cannot use it for the reference white level (~50% input) as all highlights will be clipped.
Why don’t you measure Epson’s HDR curves to get an idea what is achievable in terms of white level?
post #46 of 180 Old 07-03-2019, 05:57 AM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
So do grayscale sweeps with default settings on the picture modes I plan to use? Also with HDR & BT.2020 modes active on the projector?
Like this?
Bright Cinema
Digital Cinema
Cinema
Natural
post #47 of 180 Old 07-03-2019, 06:05 AM
Juboy's Avatar
Quoted: 31 Post(s)
Liked: 74
Thank you. Look forward to trying these.
Juboy is offline
post #48 of 180 Old 07-03-2019, 06:44 AM
Liked: 1678
Yes
post #49 of 180 Old 07-03-2019, 06:48 AM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
Yes
I edited my post above with the measurements using ST 2084.
post #50 of 180 Old 07-03-2019, 06:59 AM
Liked: 1678
Looks like Natural and Bright Cinema are the only two with bright enough white levels. What do you think when watching actual contents?
post #51 of 180 Old 07-03-2019, 07:11 AM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
When I back to back tested Bright Cinema against Digital Cinema I have to agree that Digital Cinema was to dim.
Not tried them with the picture modes at their default settings.
post #52 of 180 Old 07-03-2019, 07:22 AM
Liked: 1678
That’s to be expected. My question was what you think of the Bright Cinema mode.
post #53 of 180 Old 07-03-2019, 07:24 AM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
I like Bright Cinema its give you that HDR effect which is nice.
Just checked between Natural & Bright Cinema and a prefer Bright Cinema, I guess because its brighter.
post #54 of 180 Old 07-03-2019, 07:30 AM
Liked: 1678
The white level is almost 40 nits
post #55 of 180 Old 07-03-2019, 07:34 AM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
Where do I see that info?
I can see 100% white is 136 nits or 39 fL but where does it tell you the white level or am I being stupid?
Is that the 50% white reading?
post #56 of 180 Old 07-03-2019, 08:09 AM
Liked: 1678
Yes, as I mentioned in post 45 above.
EDIT:”Yes” to your second question, not the first
post #57 of 180 Old 07-03-2019, 08:26 AM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
I see what you did there
So I need to set the "White Level" in CalMAN to 39 nits with the gamma formula BT 2390 before starting to adjust the gamma controls?
For the two point controls I just use the gamma formula ST 2084.
I guess this is where I have been going wrong as I have been using the peak luminance as my white level in my previous run.
One other thing, when using the CMS controls is the Brightness control still used to bring the Y value into line?
I found that when trying to calibrate the CMS for the Cinema picture mode all the points were deficient in luminance & I ended up maxing out the Brightness control & still did not hit the Y target, I guess this is because of the lack of nits produced in this picture mode?
post #58 of 180 Old 07-03-2019, 08:39 AM
Liked: 1678
It doesn’t have to be 39 nits. That’s just a point of reference in terms of how bright the image will be.
post #59 of 180 Old 07-03-2019, 09:01 AM - Thread Starter
Quoted: 644 Post(s)
Liked: 132
I see, well my SDR calibration has 100% white at 56.5 nits so I suppose I could use that.
post #60 of 180 Old 07-03-2019, 09:25 AM
Liked: 1678
Most people would aim for lower, to allow for the HDR highlights.
Reply Display Calibration
