Projector Calibration (6040UB) - Second Look - AVS Forum | Home Theater Discussions And Reviews
 95Likes
post #1 of 270 Old 06-26-2019, 11:30 PM - Thread Starter
AdamAttewell's Avatar
Quoted: 831 Post(s)
Liked: 205
Hello all,
I calibrated my Epson 6040UB some time ago now & am looking to re-calibrate whilst also digging deeper into the HDR side of things but I first want to get my SDR calibration nail down first.
Before I go any further here is what I will be using:
CalMAN 2019
X-Rite i1 Pro
X-Rite i1 Display Pro
Lumagen Radiance 2021 (Pattern Generator)
Seeing as the CalMAN forums have been taken down my threads & info has been lost that I used the first time round & am also looking to confirm I am doing all the steps required in the right order.
I have already setup both meters just over a foot from the screen tilted up slightly so they are not measuring their own shadow, side by side and have created a profile before starting. I let the projector run for just over two hours before creating the profile.
From my first run I know the Natural picture mode is the best for SDR so I will be using this picture mode.
Then I started looking at the color temperature setting, default is 6500K but using CalMAN it seems the 6000K setting is closer to 6500K
Onto the gamma & the closest I can get to a gamma of 2.4 is using a gamma setting of -2 but I only get a gamma of around 2.3, not sure if this is an issue or not but other than using the custom gamma option I dont see how I can get this any closer.
I have been using the test patterns on the AVS 709 disk to set brightness & contrast, switching back & forth between both of them until both are set correctly.
Grayscale controls are limited just a basic two point adjustment, I have been calibrating these at 20% & 80% & can get both under 1 dE
From here if what I have done above is correct I start to get a little lost on how to go about things, would the CMS be the next step or should I be looking at gamma?
EDIT: Here are my settings for SDR, I ended up going for a peak luminance of 20fL instead of 16fL as I prefer the brighter image and this also builds a buffer for bulb wear & the inevitable decrease in luminance.
SDR 2.4 20fL
Color Mode: Natural
Brightness: 51
Contrast: 49
Color Saturation: 50
Tint: 50
Power Consumption: ECO
Auto Iris: Normal
Color Temp: 6000K
Skin Tone: 4
Colour Temp: Customized
Offset R: 49 Offset G: 50 Offset B: 50
Gain R: 50 Gain G: 49 Gain B: 46
Sharpness:
Standard: 5
Thin Line Enhancement: 5
Thick Line Enhancement: 5
Image Enhancement: Preset 3
Gamma: Customized
Color Tone 1: 0
Color Tone 2: -8
Color Tone 3: -13
Color Tone 4: -15
Color Tone 5: -17
Color Tone 6: -17
Color Tone 7: -17
Color Tone 8: -20
Color Tone 9: 0
RGBCMY
Red
Hue: 54 Saturation: 38 Brightness: 57
Green
Hue: 68 Saturation: 57 Brightness: 43
Blue
Hue: 55 Saturation: 36 Brightness: 48
Cyan
Hue: 50 Saturation: 57 Brightness: 44
Magenta
Hue: 58 Saturation: 46 Brightness: 45
Yellow
Hue: 50 Saturation: 36 Brightness: 60
Super White: On
Lens iris: -6
Color Space: Auto
SDR 2.2 20fL
Color Mode: Natural
Brightness: 51
Contrast: 49
Tint: 50
Auto Iris: Normal
Color Temp: 6000K
Skin Tone: 4
Colour Temp Customized
Offset R: 49 Offset G: 50 Offset B: 49
Gain R: 49 Gain G: 47 Gain B: 46
Sharpness:
Standard: 5
Gamma: Customized
Color Tone 1: 0
Color Tone 2: -4
Color Tone 3: -6
Color Tone 4: -8
Color Tone 5: -9
Color Tone 6: -9
Color Tone 7: -10
Color Tone 8: -12
Color Tone 9: 0
RGBCMY
Red
Hue: 53 Saturation: 49 Brightness: 47
Green
Hue: 68 Saturation: 54 Brightness: 44
Blue
Hue: 54 Saturation: 52 Brightness: 35
Cyan
Hue: 48 Saturation: 57 Brightness: 42
Magenta:
Hue: 57 Saturation: 50 Brightness: 39
Yellow
Hue: 50 Saturation: 42 Brightness: 53
Super White: On
Lens iris: -6
Color Space: Auto
Dynamic Range: Auto
Image processing: Fine
HDR settings, clipping at 500 & 1000 nit clipping points. I use a Panasonic UB820 with the HDR optimizer switched on using the HDR TV Type "Basic Luminance LCD & Projector" which tone maps content to 500 nits.
HDR 500 nits (Medium)
Color Mode: Natural
Brightness: 60
Contrast: 50
Tint: 50
Power Consumption: Medium
Auto Iris: Normal
Color Temp: 6500K
Skin Tone: 4
Offset R: 50 Offset G: 50 Offset B: 50
Gain R: 50 Gain G: 47 Gain B: 44
Sharpness
Standard: 5
Gamma: Customized
Color Tone 1: 0
Color Tone 2: -3
Color Tone 3: 0
Color Tone 4: -1
Color Tone 5: 1
Color Tone 6: 4
Color Tone 7: 12
Color Tone 8: 0
Color Tone 9: 0
RGBCMY
Red
Hue: 59 Saturation: 41 Brightness: 72
Green
Hue: 60 Saturation: 67 Brightness: 39
Blue
Hue: 57 Saturation: 62 Brightness: 42
Cyan
Hue: 59 Saturation: 75 Brightness: 35
Magenta:
Hue: 60 Saturation: 54 Brightness: 70
Yellow
Hue: 50 Saturation: 61 Brightness: 55
Super White: Off
Lens iris: 0
Color Space: Auto
Dynamic Range: Auto
HDR 1000 nits (Medium)
Color Mode: Natural
Brightness: 54
Contrast: 47
Tint: 50
Auto Iris: Normal
Color Temp: 6500K
Skin Tone: 4
Gain R: 50 Gain G: 45 Gain B: 42
Sharpness
Standard: 5
Gamma: Customized
Color Tone 1: 0
Color Tone 2: -5
Color Tone 3: -6
Color Tone 4: -10
Color Tone 5: -9
Color Tone 6: -4
Color Tone 7: -8
Color Tone 8: -29
Color Tone 9: 0
RGBCMY
Red
Hue: 56 Saturation: 45 Brightness: 72
Green
Hue: 61 Saturation: 67 Brightness: 39
Blue
Hue: 58 Saturation: 38 Brightness: 57
Cyan
Hue: 60 Saturation: 58 Brightness: 50
Magenta:
Hue: 70 Saturation: 62 Brightness: 50
Yellow
Hue: 51 Saturation: 56 Brightness: 56
Super White: Off
Lens iris: 0
Color Space: Auto
Dynamic Range: Auto
HDR 500 nits (High)
Color Mode: Natural
Brightness: 60
Contrast: 58
Tint: 50
Power Consumption: High
Auto Iris: Normal
Color Temp: 6500K
Skin Tone: 4
Offset R: 49 Offset G: 49 Offset B: 50
Gain R: 50 Gain G: 44 Gain B: 43
Sharpness
Standard: 5
Gamma: Customized
Color Tone 1: 0
Color Tone 2: -3
Color Tone 3: -4
Color Tone 4: -4
Color Tone 5: -4
Color Tone 6: -4
Color Tone 7: -6
Color Tone 8: -3
Color Tone 9: 0
RGBCMY
Red
Hue: 51 Saturation: 51 Brightness: 61
Green
Hue: 57 Saturation: 58 Brightness: 50
Blue
Hue: 55 Saturation: 55 Brightness: 50
Cyan
Hue: 58 Saturation: 71 Brightness: 50
Magenta
Hue: 54 Saturation: 71 Brightness: 63
Yellow
Hue: 54 Saturation: 60 Brightness: 50
Super White: Off
Lens iris: 0
Color Space: Auto
Dynamic Range: Auto
3D Settings
3D Cinema
Color Mode: 3D Cinema
Brightness: 53
Contrast: 50
Tint: 50
Auto Iris: Off
Color Temp: 4
Skin Tone: 3
Offset R: 48 Offset G: 50 Offset B: 50
Gain R: 51 Gain G: 50 Gain B: 51
Sharpness
Standard: 5
Image Enhancement: Preset 4
Gamma: Customized
Color Tone 1: 0
Color Tone 2: 2
Color Tone 3: 3
Color Tone 4: 1
Color Tone 5: -2
Color Tone 6: -5
Color Tone 7: -9
Color Tone 8: -31
Color Tone 9: 0
RGBCMY
Red
Hue: 55 Saturation: 29 Brightness: 49
Green
Hue: 27 Saturation: 14 Brightness: 66
Blue
Hue: 50 Saturation: 24 Brightness: 50
Cyan
Hue: 69 Saturation: 14 Brightness: 58
Magenta:
Hue: 71 Saturation: 29 Brightness: 43
Yellow
Hue: 53 Saturation: 38 Brightness: 51
Super White: On
Lens iris: 0
Color Space: Auto
Dynamic Range: Auto
3D Setup (Signal Settings)
3D Display: Auto
3D Format: Side by Side
3D Depth: 0
Diagonal Screen Size: N/A
3D Brightness: Medium
AdamAttewell is online now
post #2 of 270 Old 06-27-2019, 06:06 PM
inspector's Avatar
Quoted: 269 Post(s)
Liked: 178
Those of us with 6040s appreciate your posts, especially this thread you've started.
AdamAttewell likes this.
...finally retired and spending time in my dedicated HT!!!
SPARKSPLEX HT - Epson 6040 3D/4K UB Projector; 110" 16x9 Dalite HD Progressive Screen; Sammy 3D/4K K8500 (r-free); Panny ub420; 7.2.4. Def Tech speakers, Earthquake P12v2 Subs; Auto Source 100vs Amp; Denon 4300H; MX990 Remote; 5 Bello chairs; Coaire Mini-split.
inspector is online now
post #3 of 270 Old 06-27-2019, 06:19 PM
Quoted: 5584 Post(s)
Liked: 2250
You may also be interested in the existing thread on HDR calibration for the Epson 5040/6040:
https://www.avsforum.com/forum/139-d...l#post55190846
Dominic Chan is online now
post #4 of 270 Old 06-27-2019, 08:56 PM - Thread Starter
Quoted: 831 Post(s)
Liked: 205
Appreciate you guys coming over from the Epson thread, picking up from where we left off I have reset the Natural picture mode to its default & have taken my baseline measurements.
First off here is the meter profile I created & applied before taking measurements.
Here is the Natural picture mode with default settings applied.
With Epson Super White turned off which is the default white is being clipped.
Seems that there is room for improvement with these measurements, looks like I will have to turn Epson Super White on to stop the white clipping.
I have a question, with default settings on ECO lamp mode I am getting around 26.5 fL which from my research this should be around 16 fL?
Using the lens iris I can get this down to 18.8fL, I presume I should be doing this before contrast & brightness?
post #5 of 270 Old 06-27-2019, 09:10 PM
inspector's Avatar
Quoted: 269 Post(s)
Liked: 178
Thanks to you too Dominic!
post #6 of 270 Old 06-28-2019, 03:59 AM - Thread Starter
Quoted: 831 Post(s)
Liked: 205
OK so a little progress, after turning on Epson Super White the white clipping issue was resolved.
I went ahead with leaving the iris closed right down to get to 16fL.
I adjusted the colour temperature to the 6000K setting as this seems to be closer to 6500K that the 6500K setting.
6000K
6500K
7000K
After that I moved onto the two point controls for the grayscale.
Now with the 10 point grayscale Gamma is way off 2.4 which I guess accounts for the large amounts of error.
Now after using the gamma controls.
I can see what you guys were saying about the gamma controls, there is quite some overlap between the controls with controls 1 & 8 no serving any purpose at all but making small adjustments & remeasuring every time you soon build a picture of how the controls work & I was able to get a pretty good result in terms of gamma.
So that leaves the CMS, what do you guys think of these?
post #7 of 270 Old 06-28-2019, 05:05 AM
venkatesh_m's Avatar
Quoted: 92 Post(s)
Liked: 55
After thinking about it, you seem to have very good light levels and using the super white function is not really a penalty even though for SDR and projectors I'm not sure its necessary.
Sent from my ALP-L29 using Tapatalk
venkatesh_m is offline
post #8 of 270 Old 06-28-2019, 07:22 AM
jt7272's Avatar
Quoted: 75 Post(s)
Liked: 61
6000K
6500K
7000K
Your gamma looks great after adjustment! Now you understand the pain of the manual gamma adjustment on these projectors...
Regarding your CMS you can probably get it dialed in almost perfect. Most of my dE levels are less than one on my saturations/luminance.
This is actually pretty easy to do. For each saturation level you adjust the "Hue" which moves the data point between two colors (imagine a line between them, the data point moves along it). The saturation moves the data point away from the center/white. Finally, the brightness affects the Y (luminance) value. Keep in mind that Y will also be affect by saturation and sometimes hue. So I do the following for each color in the CMS:
1. Go to the 80% saturation level and adjust hue and saturation until the point is as close to "in the box" as possible.
2. Then adjust brightness to get Y close to target.
3. If the data point has moved outside of the box go back to 1 and repeat until you get as close as possible x,y and Y.
4. Verify that the other saturation levels are good. Maybe make some adjustments to move the whole color a bit to compromise and get the best overall results.
It is important not to sacrifice accuracy on lower saturation levels in order to get 100% to match. Try to get 20-80% very accurate and hope that 100% is close.
AdamAttewell and Dominic Chan like this.
Epson 6040ub
Denon AVR-X3400H + Mirage OMD-5 surrounds
Home-made Hybrid PCB Electrostatic Floorstanding L+R Speakers (with built-in DSP + amps)
Home-made sub with 15" Ultimax woofer, Dayton SA1000 Amp
Sony PS4, Sony UBP-X800, Panasonic DP-UB820
jt7272 is offline
post #9 of 270 Old 06-28-2019, 08:02 AM
Liked: 2250
This is the exact issue with the posted results. The saturation levels were over-adjusted in an attempt to get 100% to match (it didn't help much), resulting in over-saturation of the 20-80% points. In particular, look at the green colour - the 80% and 100% saturation points almost blend into one:
Before:
After:
post #10 of 270 Old 06-28-2019, 06:09 PM - Thread Starter
Quoted: 831 Post(s)
Liked: 205
Many thanks jt for explaining how to adjust the CMS, I never done this part before so your instructions are very much appreciated just like your instructions for gamma as I dont know where I would have started without them.
How do I go about moving the whole color if needed, what controls would I use to do this?
I presume these errors have be caused by adjustments I have made because they were not present in the baseline measurements?
Is there anything I can do to prevent this or are these errors caused by faults in how the controls are implemented?
post #11 of 270 Old 06-28-2019, 06:54 PM
jt7272's Avatar
Quoted: 75 Post(s)
Liked: 61
All that you need to do is go back and calibrate your CMS as I described above. You can reset it and start from baseline or just work from your current settings.
The obvious issue is that some colors are oversaturated (points fall too far from center). For other colors the hue could be adjusted slightly.
There is nothing inherently wrong or limited in the CMS. Your calibration is just flawed in that saturation levels below 100 seem to be skewed. This happens when you adjust the CMS to dial in the 100% saturation only.
Epson 6040ub
jt7272 is offline
post #12 of 270 Old 06-28-2019, 07:10 PM - Thread Starter
Quoted: 831 Post(s)
Liked: 205
I see, but I have not touched the CMS controls at all up to this point. Unless the CMS controls are related to the gamma or grayscale controls?
post #13 of 270 Old 06-28-2019, 07:11 PM
Liked: 2250
Most likely it’s caused by monitoring only 100% saturation when you did the CMS adjustments (although you seemed to be implying you didn’t adjust CMS). However, to be able to suggest how to prevent it, I need to know what changes you made, and what process you were following.
post #14 of 270 Old 06-28-2019, 07:23 PM - Thread Starter
Quoted: 831 Post(s)
Liked: 205
I have laid out above the steps I have done to get to this point.
I followed jt's instructions up to now.
1. Make a baseline measurement first.
2. Adjust your brightness and contrast using clipping patterns.
3. 2 point grayscale (rgb gain/offset) to dial in color temp (you can also use the color temp setting on the Epson to get it close before adjusting the RGB)
4. 11 or 21 point grayscale/gamma - what you're doing here is adjusting the gamma sliders to get Y to match target Y
5. Go back to 3 and repeat until your dE w/gamma is good
Make sure that the iris is off, and use windowed patterns (50% or less) rather than full screen.
I dont know if turning Epson Super White on could have caused this but I cant think of anything else I have done that could of caused this.
post #15 of 270 Old 06-28-2019, 07:30 PM
jt7272's Avatar
Quoted: 75 Post(s)
Liked: 61
It is normal for the CMS values to drift a little bit when calibrating grayscale. Also, this will happen if you make any adjustments using the "Color Temperature" setting.
Regardless, there's no harm done. Just go into your CMS and make adjustments as I described. None of your saturations are so far off that you cannot correct it. Just be aware that you may get very close on saturation levels 20%-80% and be off at 100%. This is OK.
In the end you cannot get it to be perfect. You just have to tinker until it is pretty good.
I calibrate the CMS first at 75% saturation and rarely do I have to make any adjustments after that. On the 5040/6040ub it seems to give the best results at all other saturations.
Epson 6040ub
jt7272 is offline
post #16 of 270 Old 06-28-2019, 07:36 PM - Thread Starter
Quoted: 831 Post(s)
Liked: 205
I see, thank you for the conformation. Do you know what color temperature setting you are using?
The default is 6500K but from measurements 6000K setting was closer to 6500K prior to calibration. I have not measured the color temperature after making adjustments to the grayscale & gamma.
I presume these adjustments could have caused the color temperature to be adjusted & the 6500K setting was the correct one after all?
post #17 of 270 Old 06-28-2019, 07:37 PM
jt7272's Avatar
Quoted: 75 Post(s)
Liked: 61
You should be able to get your 80% (I use 75) very close. After that the other saturations will fall into place. You may only need a small amount of adjustments to make some compromises to fix the other levels.
See my 75% saturations from my last calibration. They are spot-on. You should have no trouble replicating this, as your environment is better than mine (I have a screen that is not neutral, and a light-colored cathedral ceiling).
Name:	CMS at 75 percent.jpg
Epson 6040ub
jt7272 is offline
post #18 of 270 Old 06-28-2019, 07:38 PM
jt7272's Avatar
Quoted: 75 Post(s)
Liked: 61
You're fine using the 6000K. I actually have the same setting on mine. My screen runs a bit cool so it helps to get everything a bit closer using a single slider than to do it manually with each color.
Epson 6040ub
jt7272 is offline
post #19 of 270 Old 06-28-2019, 07:45 PM - Thread Starter
Quoted: 831 Post(s)
Liked: 205
OK, I will probably end up having a look at what I get with the 6500K setting after adjusting the CMS.
Will always bug me wondering if the 6500K setting would achieve better results
post #20 of 270 Old 06-28-2019, 07:48 PM
Liked: 2250
I really doubt it. I would suggest you check your Color and Hue Controls, plus the CMS controls, to make sure they are all at deafaut (usually 0), prior to a new round of CMS adjustments.
post #21 of 270 Old 06-28-2019, 07:49 PM
jt7272's Avatar
Quoted: 75 Post(s)
Liked: 61
Ha
I wouldn't worry about it. Trust your meter and you'll be fine. Your dE's are already pretty good. You should be able to get your saturation dE's below 1.0 at ~80% levels. At that point you'll be as good as you can get.
Then just sit back and enjoy it.
Epson 6040ub
jt7272 is offline
post #22 of 270 Old 06-28-2019, 07:52 PM
Liked: 2250
These are just “nominal” settings. You should start with the setting closest to D65 and find-tune it to get the lowest dE.
If you really want to investigate this, do it before you adjust CMS.
post #23 of 270 Old 06-28-2019, 07:52 PM - Thread Starter
Quoted: 831 Post(s)
Liked: 205
If these are the only CMS controls then they are all at their defaults.
post #24 of 270 Old 06-28-2019, 07:54 PM
Liked: 2250
Is there a “global” Color and Hue adjustment in addition to these? They may not be under CMS.
post #25 of 270 Old 06-28-2019, 07:56 PM - Thread Starter
Quoted: 831 Post(s)
Liked: 205
I guess looking at the Correlated Color Temperature in CalMAN was a bad idea then?
I should have just done grayscale sweeps to see which was closest to D65 instead?
post #26 of 270 Old 06-28-2019, 08:00 PM - Thread Starter
Quoted: 831 Post(s)
Liked: 205
Yes there is a global color control along with tint & under color temp there is a skin tone option, all of these have been left at their default values.
@jt7272
Just one quick question to both of you, if adjust the color temperature setting after performing grayscale & gamma adjustments I presume that with will affect the gamma & grayscale in a negative way?
Would be great if I could just adjust the color temperature right now before CMS adjustments but I get the feeling this is a bad idea.
post #27 of 270 Old 06-28-2019, 08:15 PM
jt7272's Avatar
Quoted: 75 Post(s)
Liked: 61
Stop thinking so much. After your grayscale calibration the gamma and grayscale look great. The CMS is off a bit but it should be fixable by adjusting the CMS. Just calibrate the CMS and see how it looks. There's no need to complicate everything and start over.
Epson 6040ub
jt7272 is offline
post #28 of 270 Old 06-28-2019, 08:18 PM - Thread Starter
Quoted: 831 Post(s)
Liked: 205
Will do, off to have a go now & will post my results later.
Many thanks again.
post #29 of 270 Old 06-28-2019, 08:19 PM
Liked: 2250
“Correlated 6500K” and D65 mean the same thing in this context. The latter is more precise.
post #30 of 270 Old 06-28-2019, 08:23 PM
Liked: 2250
Adjusting colour temperature will definitely affect greyscale, almost by definition.
If you’re really curious about it, do it before adjusting CMS.
Reply Display Calibration
