ΔEITP is Now ITU-R BT.2124--Is the Industry Ready to Move on From ΔE2000? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By WiFi-Spy
  • 1 Post By Anger.miki
  • 2 Post By bobof
post #1 of 11 Old 08-12-2019, 01:57 AM - Thread Starter
Anger.miki's Avatar
Quoted: 371 Post(s)
Liked: 394
I am very, very interested in this subject. As I can't be present at this EVENT:
Is there any possibility that it will be streamed or, at least, that the various speeches will be transcribed on the SMPTE website? Are the event and/or speakers confirmed? Because Miss Meininger deleted from her Facebook profile any reference to her work experience at Portrait Displays. She's no longer working for CalMAN? If so, it's really a pity. I was excited about her hiring, she looks like a person who knows profoundly color science.
When she got the job (July 2018):
Now (August 2019):
TVs: Pioneer PDP-LX5090H, LG OLED55C8PLA | SintoAmp: Pioneer VSX-921 | BD Player: Panasonic DMP-BDT260EG | External LUT box: Entertainment Experience eeColor | Softwares: Light Illusion Lightspace HTP, Portrait Displays CalMAN Home Enthusiast 2018 R3, HCFR, DisplayCAL | Probes: x-rite i1 Pro 2 - i1 Display Pro OEM B-02, basICColor DISCUS | Test Pattern Generator: DVDO AVLab TPG
Anger.miki is online now
post #2 of 11 Old 08-12-2019, 05:15 AM
Light Illusion's Avatar
Quoted: 756 Post(s)
Liked: 1099
dEITP is not suitable as a replacement for dE2000.
They are aimed at very different applications when it comes to error reporting.
(No dE formula should be used when actually performing calibration.)
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #3 of 11 Old 08-12-2019, 04:50 PM
WiFi-Spy's Avatar
Quoted: 1469 Post(s)
Liked: 2084
Yes, Catherine and myself will be presenting this technical paper at the 2019 SMPTE Conference in LA. They will be recording a video of the presentation and publishing it on YouTube sometime after the event.
bobof likes this.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #4 of 11 Old 08-12-2019, 05:05 PM
AnotherDude's Avatar
Quoted: 986 Post(s)
Liked: 608
Steve
Can you please elaborate on that, Steve?
Samsung 75Q9FN, OPPO UDP-205
Win 10 Pro x64 1903
HT Enthusiast Extended Custom WF v19.3.0 - 7/5/2019
HT Enthusiast Essentials Custom WF v1.2.0 - 7/5/2019
AnotherDude is offline
post #5 of 11 Old 08-12-2019, 06:35 PM
WiFi-Spy's Avatar
Liked: 2084
I can’t wait for everybody to read this paper.
bobof likes this.
WiFi-Spy is offline
post #6 of 11 Old 08-12-2019, 10:10 PM - Thread Starter
Anger.miki's Avatar
Quoted: 371 Post(s)
Liked: 394
Cool. Please, link the video in this thread when it will be available.
I created an Excel spreadsheet for dE2000 and dEITP to have a faster tool to compare the “ΔΙΑΦΟΡΑ* (Diafora)” between FCCM and TMC results. That’s why I’m sincerely interested.
*Greek word from where the Δ (Delta) symbol originates. It means “difference”.
Steve’s assertion is correct. A Delta formula is only used to determine the difference between 2+ points. Frankly, I don’t even know how it could be used to build a display profile or a LUT.
Miki
ConnecTEDDD likes this.
post #7 of 11 Old 08-13-2019, 04:49 AM
aka jfinnie
Quoted: 2451 Post(s)
Liked: 1577
As far as I know, some autocal mechanisms work by changing parameters and using the improvement in dE to judge whether or not to keep the change or carry on tweaking. I don't know about the inner workings of Calman, but I did have Chromapure and this appears to be how it generates 3DLUTs in the Lumagen advanced autocal it has; by changing single LUT values and checking the measurements. When you watch the log you can see it behave in this way. I was never very impressed with the LUTs coming out of the Chromapure process.
Rolls-Royce and ConnecTEDDD like this.
bobof is offline
post #8 of 11 Old 08-13-2019, 07:31 AM
Quoted: 986 Post(s)
Liked: 608
Miki
After switching my workflow from De2000 to DEITP I ended up creating a layout comparing the De2000 and DEITP values for the grayscale and color checker post-calibration readings. I found it interesting that the differences by reading are not uniform, though DEITP tended to be visibly higher.
Win 10 Pro x64 1903
post #9 of 11 Old 08-13-2019, 07:43 AM - Thread Starter
Anger.miki's Avatar
Quoted: 371 Post(s)
Liked: 394
Yes, the problem with dEITP, at least for me and my Excel spreadsheet, it is that it starts with a RGB to LMS conversion. So I have to convert my XYZ readings to RGB and that gives me frequently negative values and, therefore, errors.
post #10 of 11 Old 08-13-2019, 02:38 PM
WiFi-Spy's Avatar
Liked: 2084
The ITU document talks about negative values.
WiFi-Spy is offline
post #11 of 11 Old 08-13-2019, 11:49 PM - Thread Starter
Anger.miki's Avatar
Quoted: 371 Post(s)
Liked: 394
Yes, it says to “not clamp” them throughout the conversion to ITP. My problem is that excel returns “#NUM” with negative numbers. I will recheck the implementation of the formula and report back.
The document talks about negative numbers in Annex 4, paragraphs 3&4. Short story: if you want to analyze only colors within BT.2100 color volume, then negative numbers must be clamped to 0 and, I guess, numbers>1 to 1 (?). But, if you want to consider colors as they are actually measured, then negative numbers should not be clamped.
EDIT: Ok, the formula I used for XYZ-RGB conversion is different from the one suggested in the ITU-R BT.2124 document, probably it has the correct matrix for the BT. 2100 color space while I was using the Rec.709 inverse matrix. After I've implemented that, all is fine. Cheers.
Reply Display Calibration
