Colorimetry Research Instruments (Android App) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-07-2019, 10:05 AM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 3399 Post(s)
Liked: 4229
For users of Colorimetry Research instruments: CR-100, CR-250 and CR-300, there is an Android App available that can be used to take measurements from a smartphone.
The program does work, but can be a bit 'clunky'.
It is really an Alpha program which Colorimetry Research didn't had time to finalize.
If someone like to test, he can send me msg here: https://displaycalibrations.com/contact_us.html
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #2 of 4 Old 09-09-2019, 09:24 PM
Rayjr's Avatar
Quoted: 199 Post(s)
Liked: 241
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
Hey Ted,
This Android software came out in July of 2015 and was intended for when the user only needed quick x,y,Y info...mainly cinema projector work. If any CRI user has a need for it, just email CRI and they will email you the Android .APK file. If you have a newer CR meter, the android software is actually on the USB stick that comes with the meter.
The software works fine for what it was designed for.
I talked about the software back in Oct of 2017
Just my $.02
RayJr
Rayjr is offline
post #3 of 4 Old 09-10-2019, 05:19 AM - Thread Starter
Liked: 4229
Originally Posted by Rayjr View Post
Hey Ted,
Hey Ray,
The point of my post was to inform for something that was not available to the CR site.
I saw that you talked about this back to 2017 but you haven't informed about how someone can get this.
It has some random connection issues, but no big deal, since it will do the job for simple measurements.
post #4 of 4 Old 11-05-2019, 12:16 PM - Thread Starter
Liked: 4229
There newer version of CRI (1.0.5) released @ October 21, 2019.
The CRI App will run on a phone/tablet which will connect and control Colorimetry Research meters using a USB cable. All our meters such as CR-100, CR-250, CR-300, etc. are low power devices and can be powered from the phone/tablet.
The app is available @ Google's Store: https://play.google.com/store/apps/d...adge-Mar2515-1
Reply Display Calibration
