Accupel Ultra discontinued :( - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ConnecTEDDD
post #1 of 4 Old 09-30-2019, 06:53 AM - Thread Starter
mombasa123's Avatar
Quoted: 150 Post(s)
Liked: 41
So, I was potentially in the market for an Accupel DGA-6000 but just heard from Tom Hoffman that it's been discontinued
Sadly, there doesn't seem to be anything comparable at a similar price point - or at least anything that does YCbCr 422 etc for both SDR & HDR. The VideoForge Pro only does RGB for HDR.
Sigh.
mombasa123 is offline
post #2 of 4 Old 09-30-2019, 09:17 AM
WiFi-Spy's Avatar
Quoted: 1556 Post(s)
Liked: 2157
Sigh.
VFP now supports YCbCr BT.2020 4:4:4 and 4:2:2 for HDR. The only thing we are still working on is 4:2:2 SDR BT.2020.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #3 of 4 Old 09-30-2019, 09:51 AM
ConnecTEDDD's Avatar
Quoted: 3265 Post(s)
Liked: 4055
Have you personally tested HDR REC.2020 YCbCr 2160p24 10 bit 4:4:4 and HDR REC.2020 YCbCr 2160p24 10 bit 4:2:2 and you find them as bit-perfect?
If yes, then what device model you used to verify for digital errors?
mombasa123 likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #4 of 4 Old 09-30-2019, 11:49 AM - Thread Starter
mombasa123's Avatar
Quoted: 150 Post(s)
Liked: 41
Thanks Tyler. Out of interest, is that via a firmware update or is it a new hardware revision?
Reply Display Calibration
