Calman Home for Panasonic - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #61 of 75 Old 03-30-2020, 12:52 AM
Noloveformac's Avatar
Hey Tyler
Any chance of getting the HDR calibration tutorial up on YouTube?
Noloveformac is offline
post #62 of 75 Old 05-29-2020, 02:29 AM
Quoted: 24 Post(s)
Liked: 7
Hi. I bought Calman Home 2019 Panasonic yesterday. I already had Calman Home Theater on the same notebook. Mackenzie from Portrait Displays advised me to completely uninstall the old Calman Home Theater software before installing the new Calman Home 2019. What does "completely uninstall" mean? Is it not enough to select Windows 10 / Programs / Calman Home Theater and then select Uninstall? My real problem is I cannot start the autocal mode because the connection to my Panasonic GZC2004 (Swiss model) is not working. Either the message "Socket failed" or "Display model is not supported" appears continuously. The IP address of my TV is correct. As soon as I enter the code i085 and click on isfccc Network I get the message "Waiting for connection". Then I go to Find Source at Calman, select Panasonic GZ2000, enter the IP address, press Connect and shortly afterwards these messages come up. What am I doing wrong. Do I have to install the software in another way or do I have to completely clean the notebook of old Calman remnants? Or do I have to connect the notebook via HDMI? Is my TV (Swiss model GZC2004) compatible with GZ2000 at all? Thank you in advance for your answers.
Alexias is offline
post #63 of 75 Old 05-29-2020, 08:42 AM
WiFi-Spy's Avatar
Quoted: 1989 Post(s)
Liked: 2577
Check if your TV is running the latest firmware. Panasonic had some firmware versions that did not communicate to Calman what the model of the TV is. If the TV is running the latest firmware, then I’m not sure what a solution would be. At that point I would request a refund for Calman.
Tyler Pruitt - Technical Evangelist - Portrait Displays/Calman
WiFi-Spy is offline
post #64 of 75 Old 05-29-2020, 12:46 PM
Quoted: 24 Post(s)
Liked: 7
Hi Tyler, Thanks for your quick reply. I have emailed Mackenzie, because of this problem, my logging files and the exact type of my Panasonic TV and hope for an answer soon.
Alexias is offline
post #65 of 75 Old 05-31-2020, 06:18 AM - Thread Starter
Quoted: 131 Post(s)
Liked: 83
A quick question. Can Autocal in Calman for Panasonic be used to automatically calibrate the CUSTOM picture setting? Or is it limited to just the ISF DAY and ISF NIGHT settings? Can it also be used to Autocal the Dolby Vision presets?
tarbat is offline
post #66 of 75 Old 05-31-2020, 10:50 AM
WiFi-Spy's Avatar
Liked: 2577
Professional 1 & 2 picture modes for SDR and HDR. Plus calibration of Dolby Vision on the 2020 Panasonic HZ OLED TVs
WiFi-Spy is offline
post #67 of 75 Old 05-31-2020, 12:24 PM - Thread Starter
Quoted: 131 Post(s)
Liked: 83
Thanks for the reply. Because of the ineffective ambient sensor in the Pro1 & Pro2 modes, I use CUSTOM on my GZ1500 for regular daily use (wife friendly).
So a follow up question. Can I use Calman to control the TV’s inbuilt pattern generator whilst doing a manual calibration in CUSTOM picture mode?
tarbat is offline
post #68 of 75 Old 05-31-2020, 03:49 PM
WiFi-Spy's Avatar
Liked: 2577
I don’t believe so because of the fact that yo need to be in a professional 1/2 to connect to the pattern generator. But I can look into it this week.
WiFi-Spy is offline
post #69 of 75 Old 06-17-2020, 12:27 PM
Masterwarzombie's Avatar
Quoted: 90 Post(s)
I need to receive a panasonic HZ1000 this week.
Is the Calman 2020 version up to date with the new Panasonic range and in particular the Dolby Vision workflow?
Masterwarzombie is offline
post #70 of 75 Old 06-17-2020, 03:26 PM
WiFi-Spy's Avatar
Liked: 2577
Dolby Vision calibration is supported but requires an external pattern generator. Murideo 6G or VideoForge Pro.
Tyler
Masterwarzombie likes this.
WiFi-Spy is offline
post #71 of 75 Old 06-28-2020, 12:32 AM
Snowrisk's Avatar
Liked: 0
Question
Hi Tyler,
I bought "Calman Home for Panasonic" and have the problem that the error message
"Display model is not supported (in CalWinCom.CalSourceCom)" appears when I try to connect my device.
The TV is an OLED "GZN1508" from 2019.
What am I doing wrong? The IP address is correct and the device is prepared according to your instructions (isfccc Network).
According to your website the "GZ..." series is fully supported.
Can you help me please? I can provide a debug log if necessary.
Jens
Snowrisk is offline
post #72 of 75 Old 07-03-2020, 03:07 AM
Snowrisk's Avatar
Liked: 0
Any other suggestions regarding my problem?
(See the post before)
Snowrisk is offline
post #73 of 75 Old 07-03-2020, 06:45 AM
Rolls-Royce's Avatar
Quoted: 1505 Post(s)
Liked: 1598
Tyler is not always here. Your best bet is to submit a support ticket to Portrait Support via the website. Last time I did, they got back to me within 24 hours.
Snowrisk and mrtickleuk like this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #74 of 75 Old 07-03-2020, 07:23 AM
WiFi-Spy's Avatar
Liked: 2577
Yes please contact support, We are working with Panasonic on this issue.
WiFi-Spy is offline
post #75 of 75 Old 07-03-2020, 07:42 AM
Snowrisk's Avatar
Liked: 0
Thanks Tyler.
I've done this and I'm waiting for answer and hope the best
Jens
Snowrisk is offline
Reply Display Calibration
