I like the 'Normal' color temp on Vizio, but wish it was a touch less warm - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-05-2019, 08:22 AM - Thread Starter
kerj's Avatar
My Vizio P55 has three settings: Cool, Computer, and Normal. Cool is way too blue. I had been using Computer, but felt skin tones were too pink, and it was a touch too blue overall. Normal, which seems like Vizio's form of Warm, feels like the most accurate but I wish there was a middle ground between it and Computer.
What are the settings in the color tuner that I can tone it down a little? I'm given Hue, Brightness, Saturation, Gain and Offset for RGB, and then Hue Brightness and Saturation for Cyan, Magenta, and Yellow. I imagine I want to consult a SMPTE chart for this.
kerj is offline
post #2 of 2 Old 10-05-2019, 10:36 AM
ConnecTEDDD's Avatar
Quoted: 3265 Post(s)
Liked: 4055
Hi, do you have any calibration software or color instrument?
You will need them fro adjusting RGB balance/Gamma (RGB Gain/Offset) and the Color Gamut (Hue/Saturation/Brightness).
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
Reply Display Calibration
