Local Dimming on or off during calibration? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ConnecTEDDD
post #1 of 2 Old 10-10-2019, 07:16 AM - Thread Starter
BigCoolJesus's Avatar
Quoted: 2194 Post(s)
Liked: 1733
What is the general consensus regarding Local Dimming for LCD TV's and calibration? I know on my x940E, if I calibrate grayscale with it off and with it on, I get different offset values. And I also know, at least for the x940E, calibrating with LD on is a little bit of a challenge (the offsets don't quite match up with the % GS being displayed).
However, if one is going to be using local dimming during playback (especially for HDR), is it more accurate to calibrate with it on?
BigCoolJesus is online now
post #2 of 2 Old 10-10-2019, 09:41 AM
ConnecTEDDD's Avatar
Quoted: 3276 Post(s)
Liked: 4061
If you want the truth, any Local Dimming will alter any calibration.
Local Dimming will dynamically change your picture (to look better to the observer), but it will alter/distort your calibration.
Any display, for proper playback content, it should not have any ABL or Local Dimming active.
Think that broadcast LCD display which cost some thousand dollars, don't have any local dimming algorithm.
What is better to the eyes, its a different story.
For SDR, try to calibrate for 100 nits reducing your backlight with gamma 2.4 without local dimming, you can use a D65 bias light behind to your screen.
Madmax67 likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
Reply Display Calibration
