Murideo Six-G Pattern Generators Firmware Updates - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By ConnecTEDDD
post #1 of 7 Old 11-05-2019, 02:51 AM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 3399 Post(s)
Liked: 4229
Murideo Six-G has received a firmware update which provides bit-perfect output for the YCbCr 4:2:2 also... which was not bit-perfect until now.
This FW update number is 2.64 for 2.xx units (most users are using).
Some users has been downloaded that 2.64 FW last month when its been available to Murideo page: https://www.murideo.com/downloads.html
...while the file name was named as 2.64, it was installing the 2.63 FW. (the PDF was for 2.63 release also)
For example, inside to that folder ''Firmware_2.64\V2.64\(PART2) MCU Update'' it had 2.63 FW file.
Before some days, Murideo has updated the 2.64 FW link and its now including the correct FW update (with updated PDF which say that now the YCbCr 4:2:2 output is bit-perfect).
As always, the 'usual suspect' calibrator Maciej Koper, had to test that to see if its really bit-perfect using his Accupel DVG-6000 Ultra Plus (with Pro Engineering Option)... he tested and confirmed that now the Murideo has bit-perfect YCbCr 4:2:2 output with 2.64 FW.
Maciej has found at past several in inaccuracies which its been fixed from Murideo:
https://www.avsforum.com/forum/139-d...l#post57110944
https://www.avsforum.com/forum/139-d...l#post57806718
https://www.avsforum.com/forum/139-d...l#post56983420
So after 4 years from the release of Murideo Six-G (ISF certified), now is finally bit-perfect
Since AVPRO manufactures Murideo Six-G, SpectraCAL VideoForge PRO, Portrait Display's VideoForge PRO and Fox & Hound (they have the same output), users of other devices have to expect to receive similar updates.
Rumble Devo and Plutotype like this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #2 of 7 Old 11-05-2019, 04:01 PM
sillysally's Avatar
Quoted: 1182 Post(s)
Liked: 1053
Hi Ted.
I hope the link I posted was correct. I called Murideo several times about 2.64 and they kept posting 2.63. Here is the link to my post that they sent me for 2.64. https://www.avsforum.com/forum/139-d...l#post58658526
ss
"Don't worry be happy"
LG77C8, Klein K10-A, Jeti 1211, CMS Lightspace, Calman home plus licence for K10-A, Murideo 6G.
sillysally is offline
post #3 of 7 Old 11-05-2019, 04:07 PM - Thread Starter
Liked: 4229
Originally Posted by sillysally View Post
Hi Ted.
ss
Hi SS,
I remember your post @ CM thread.
But the 2.64 FW ''SG01H-H22-004-V2.64(90BC).hex'' file has been created @ 01 August 2019, so I don't really understand why it took so long to be released for Murideo users where they are waiting for that fix, as the problem was known at public for the inaccurate YCbCr 4:2:2 patch generation issue.
post #4 of 7 Old 11-05-2019, 04:36 PM
sillysally's Avatar
Liked: 1053
Originally Posted by ConnecTEDDD View Post
Hi SS,
AVPro did post what was said to be 2.64 back in early October maybe sooner, but it was 2.63 labeled as 2.64. The first two or three times I called they kept reposting 2.63 as 2.64, finally they posted the correct 2.64. From what was posted back in August AVPro was waiting for feedback from Calman and a few others. What troubles me is why they kept telling me they reposted the correct firmware but in fact they kept posting the old firmware 2.63 but tagging the zip folder as 2.64.
ss
post #5 of 7 Old 11-05-2019, 04:43 PM - Thread Starter
Liked: 4229
Does AVPRO company don't have their own way to verify the output of the generators? Why to wait feedback from testers, as testers don't have waveform monitors or any list of the correct YCbCr triplets etc.
post #6 of 7 Old 11-12-2019, 05:59 PM
Gregg Loewen's Avatar
Quoted: 43 Post(s)
Liked: 102
On a related note, PVA video test patterns are also now available for the 6G. Please go to the forum area of the PVA site to download (if you are a PVA Certified Video Professional).
Founder, Professional Video Alliance
Gregg Loewen is offline
post #7 of 7 Old 11-13-2019, 04:28 AM
aka jfinnie
Quoted: 2729 Post(s)
Liked: 1875
Could you explain a bit more about what there is of note in the PVA test pattern set? I couldn't see any (public) specifics on your website.
bobof is online now
Reply Display Calibration
