youtube usb cal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-11-2019, 04:46 PM - Thread Starter
Liked: 0
youtube usb cal
its from https://www.audioholics.com/home-the...tv-calibration
can this be used can i just use silk on my firestick?
i tried the mp4 on usb stick but i cant even change settings in my usb input and theres no flashing at all just a grey square in the middle when viewed on usb
Kid Poker is offline
post #2 of 8 Old 11-11-2019, 09:13 PM
Otto Pylot's Avatar
Quoted: 3565 Post(s)
Liked: 2568
Originally Posted by Kid Poker View Post
https://www.youtube.com/watch?v=HKRcpCQJW8M its from https://www.audioholics.com/home-the...tv-calibration
Just download the free AVS HD709 file and burn it to a disk. You can't calibrate your panel with just a disk alone, only adjust, but it may be all you need. To calibrate you need a light meter and software.
I never trust an atom, they make up everything.
Otto Pylot is online now
post #3 of 8 Old 11-11-2019, 10:20 PM - Thread Starter
Liked: 0
dont have a blu ray yea sorry adjust
post #4 of 8 Old 11-12-2019, 01:06 AM
ConnecTEDDD's Avatar
Quoted: 3467 Post(s)
Liked: 4293
You can download the MP4 version:
https://www.avsforum.com/forum/139-d...libration.html
https://www.displaycalibrations.com/..._download.html
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #5 of 8 Old 11-12-2019, 09:58 AM - Thread Starter
Liked: 0
Originally Posted by ConnecTEDDD View Post
thanks for links, but it looks like u didnt read my post
post #6 of 8 Old 11-12-2019, 10:10 AM
Liked: 4293
What TV model you have?
post #7 of 8 Old 11-13-2019, 09:50 AM - Thread Starter
Liked: 0
philips 65pfl5602/f7
post #8 of 8 Old 11-27-2019, 04:51 AM
Liked: 4293
What is the pattern name where you are not seeing flashing bars?
If there is a Contrast pattern for example and your have very high your Contrast Slider then levels above 235 (100% White) should not be flashing.
It can happen also to have level mismatch, for example TV to expect PC (data) level patterns (so black is 0 and 100% white is 255) and the patterns you display are suitable for TV Video Legal range (16 black, 235 (100% White), 254 (109% Super White). The TV has to be configured to expect TV Legal Video Levels (RGB-Limited) and your player has to output YCbCr colorspace.
Another example, to the brightness pattern, it can happen your TV to have enabled a feature which will clip near black detail to provide you 'deeper' blacks, so when this feature is enabled, you will not able to see any flashing bar (17 bar and higher).
You can see some info about setting contrast and brightness.
Reply Display Calibration
