Calman won't talk to Murideo Six-G - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-26-2019, 05:40 PM - Thread Starter
mpyw's Avatar
Quoted: 103 Post(s)
Liked: 32
Unhappy Calman won't talk to Murideo Six-G
Just got myself a Murideo 6-G and after all the setup, my Calman Home Enthusiast ver 5.9.1 shows "COM failed" when try to connect.
My setup as follows:-
Win7 Home Premium SP1 64bits
.NET Framework 4.6
Calman 5.9.1
All Calman driver installed from their driver pack
Installed Murideo driver downloaded from their site
I have tried to change the COM port to higher number like COM 10, COM 14 and change USB port, but still it won't talk.
From Murideo Six-G free software 2.01, the PC can communicate with the 6G where I can change the output resolution and control from the notebook
I have tried uninstall all drivers (incl Calman and Murideo) and Calman then reinstall them but same result, but I notice when install Calman driver pack, Windows prompted that some of the drivers will be running under Windows compatible mode.
What else can I do to let Calman talk to the Murideo?
Upgrade to Win 10 will only be my last resort....
To be or NOT to be......YOU are WHO you ARE
mpyw is online now
post #2 of 9 Old 11-26-2019, 05:43 PM
WiFi-Spy's Avatar
Quoted: 1625 Post(s)
Liked: 2208
.NET Framework 4.6
Calman 5.9.1
Which firmware version are you running on the Murideo?
Also make sure that the device is not in “4K geometry mode”, Or else CalMAN cannot connect to it.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #3 of 9 Old 11-26-2019, 06:19 PM - Thread Starter
mpyw's Avatar
Quoted: 103 Post(s)
Liked: 32
The Murideo is on fw 3.01
Does the Murideo default in 4k Geometry mode?
I will double confirm that
mpyw is online now
post #4 of 9 Old 11-26-2019, 06:32 PM
WiFi-Spy's Avatar
Liked: 2208
The new hardware revision of the Murideo with firmware 3.xx Wasn’t supported in CalMAN Until 5.10.1.xxx
It is a new hardware revision that did not exist when CalMAN 5.9.x.x was released.
You might need to contact them and request a previous hardware revision device.
WiFi-Spy is offline
post #5 of 9 Old 11-26-2019, 06:53 PM - Thread Starter
mpyw's Avatar
Quoted: 103 Post(s)
Liked: 32
Will Calman updated the older version to support for the new equipment?
mpyw is online now
post #6 of 9 Old 11-27-2019, 02:43 AM
ConnecTEDDD's Avatar
Quoted: 3467 Post(s)
Liked: 4293
Hi, CalMAN Enthousiast has been discontinued, so you can't buy annual ''all access'' to get the latest CalMAN version which support the Six-G (GEN2) you have bought.
Six-G (GEN1) is bit-perfect only with 2.64 firmware installed (reseeased last month). All previous FW versions don't provide bit-perfect output to all colorspace output options.
If you will stay to your current CalMAN Enthusiast, Tyler has to find out and reply to you which will be the last FW version of GEN1 Six-G which can be confirmed that it will work with your current CalMAN, so to try to find out an older GEN1 unit with that specific FW. You can't downgrade your GEN2 as the hardware is different from GEN1.
Older FW versions are not available to download, you have to contact Murideo for such FW files.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #7 of 9 Old 11-27-2019, 06:22 AM - Thread Starter
mpyw's Avatar
Quoted: 103 Post(s)
Liked: 32
The new hardware revision of the Murideo with firmware 3.xx Wasn’️t supported in CalMAN Until 5.10.1.xxx
Hi, will Calman 5.9.1 support murideo six G with fw 2.6.4?
If the Gen2 can be loaded with fw 2.6.4, it can work with calman 5.9.1?
mpyw is online now
post #8 of 9 Old 11-29-2019, 10:48 AM
Liked: 4293
The GEN2 has different hardware and its not compatible with 2.x firmware (GEN1 FW).
post #9 of 9 Old 11-29-2019, 06:25 PM
WiFi-Spy's Avatar
Liked: 2208
Gen-3 runs the 3.xx I believe. I would contact Murideo to verify compatibility.
WiFi-Spy is offline
Reply Display Calibration
