windows laptop - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-27-2019, 03:46 PM - Thread Starter
Liked: 0
windows laptop
can i use windows 10 as a substitute for a blu ray player for calibrating using vlc? will i lose something in the encoding or anything??
Kid Poker is offline
post #2 of 3 Old 11-28-2019, 07:36 AM - Thread Starter
Liked: 0
so i open black clipping from avs and mp4 with vlc and every bar flashes i have to go to 41 to get 17 to barely flash which is obviously to dark if i open windows media player 54 is the correct setting
contast media player i cant even get 235 to show even with contast way down vlc well i dont care based on black clipping results man im so confused right now. do i have any options with windows 10 hooked up via hdmi to my 4k uhd hdr tv???
post #3 of 3 Old 11-30-2019, 02:51 AM
ConnecTEDDD's Avatar
Quoted: 3467 Post(s)
Liked: 4293
The level clipping you are experiencing is related with the fact that all HTPC software players are expanding by default the video signal (patterns/movies aka 16-235) to data signal (PC's are using aka 0-255), so when they are expanding, all levels 1-16 are becoming 0 and all levels 235-254 are becoming 255.
So you will never see bars below 16 to black (if you have incorrectly configured your brightness slider) or above 235 (headroom is clipped).
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
Reply Display Calibration
