If a meter can read up to 1000 nits? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-31-2020, 05:24 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
I haven't really seen any hdr calibration. I am little confused of the process.
So i have read that HDR can produce in a scene up to 1000nits of content. If were calibrating a display with pure white showing 120 nits for room viewing then how is it ever gonna hit 1000 nits? Or is the calibration process difference. Thanks.
12voltb is offline
post #2 of 3 Old 01-31-2020, 06:06 PM
Quoted: 5557 Post(s)
Liked: 2244
HDR uses a PQ EOTF (“gamma curve”) that’s very steep at the upper end (approximate values listed):
50% = 94 nits
75% = 1000 nits
90% = 4000 nits
100% = 10000 nits
The “diffuse white” level is about 90-200 nits, not very different from SDR (Standard Dynamic Range). Everything above that is for highlights. Most consumer TVs can not reproduce these highlights and have to “tone-map” them down to levels they can handle.
As for meters, the X-Rite i1Display Pro Plus can read up to 2000 nits.
Dominic Chan is online now
post #3 of 3 Old 02-01-2020, 09:57 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
Thanks! Just trying to understand more. I follow you though very much. I understand more now on how it works. I am calibrating my vizio m65c-1 to rec709 and finding that the grey scale, gamma, color luminace are good. Less then delta E of 3. But saurtations are little hard to get below delta E 14.1 15.5 5.4 1.3 accross the 0% 25% 50% 100% measures using the avs test patterns. I just keep playing though. Each time I get a little better. Then sometimes I make adujustment and it gets worse. I am assuming at that point it just can't hit the target and hitting the panel limitations. Thanks again for the reply. Time to look into a new tv LOL! Now that I am learning about all this I find myself want better and better panels. LMAO!
12voltb is offline
Reply Display Calibration
