MadVR SDR and HDR setup for Calman - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-22-2020, 04:10 PM - Thread Starter
Anderegg's Avatar
Quoted: 699 Post(s)
Liked: 453
I am a bit confused how to use MadVR with Calman...the MadVR thread has a Calman setup link thatdownloads a Calman pdf which discusses needing to make a special 3D LUT????? Can I not just use MadVR for patterns like I do with HCFR, without any extra prrocesses? If so, what options should be selected for SDR calibration using HDMI FULL and TV set to LIMITED? I am not sure if I need to disable both lut options or not, and if I need to leave force PC levels off for feeding a limited TV with a full HDMI signal.
Also...trying to do some HDR readings, MadVR switches the TV to HDR and then the patterns and screen just strobe and flicker...never had that problem in the past with HDR MadVR.
Paul
Sony X950H SDR and HDR Calibration setting https://www.avsforum.com/forum/166-l...l#post59249362
Sony X900F SDR and HDR Calibration settings https://www.avsforum.com/forum/166-l...l#post57551552
Anderegg is offline
Reply Display Calibration
