Help using reference meter - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By jednc1
post #1 of 10 Old 03-03-2020, 08:35 AM - Thread Starter
jednc1's Avatar
Quoted: 13 Post(s)
I borrowed a ColorMunki Photo spectrophotometer in order to profile my xRite i1 Display Pro. I can't get CalMAN Home for LG to find it. I tried it without loading any xRite drivers or software, I tried it after installing the xRite drivers and software, and tried after installing the CalMAN driver pack from the CalMAN resource center. No luck. My computer recognized it as ColorMunki soon as I plugged in the USB cable, but when I search for the reference meter during the meter profiling workflow, CalMAN doesn't find it. The search only lasts about 1 second.
Does anybody have suggestion as to what I am doing wrong or not doing? According to the CalMAN supported meters document xRite ColorMunki Photo is a supported meter.
jednc1 is offline
post #2 of 10 Old 03-03-2020, 09:23 AM
CalWldLif's Avatar
Quoted: 342 Post(s)
Liked: 85
if you installed the xrite software it creates a service, this will block other software.
this is the simple explanation.
right click my computer>manage>services and look.
Loving D65
CalWldLif is offline
post #3 of 10 Old 03-03-2020, 09:53 AM - Thread Starter
jednc1's Avatar
Quoted: 13 Post(s)
Thanks. I'll take a look, but my first attempt was before I had loaded any software.
jednc1 is offline
post #4 of 10 Old 03-03-2020, 11:41 AM
Rolls-Royce's Avatar
Quoted: 1373 Post(s)
Liked: 1456
You will want to "disconnect" CalMAN from the I1D3 on the meter tab before you tell the program to search for the Munki. Once it has found both meters, you can continue with profiling and switch back and forth. Also make sure CalMAN isn't running before you physically connect the meter.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #5 of 10 Old 03-03-2020, 12:24 PM - Thread Starter
jednc1's Avatar
Quoted: 13 Post(s)
Thanks. My first attempt to meter was without the i1D3 connected, the ColorMunki was connected before starting CalMAN. I was using the CalMAN Profile Meter workflow so the first step is to connect the reference meter. That is where I'm stuck. On "Find Meter" I check the "All meters except those listed below" option. I then click "Search". After less than a second it has finished and found nothing, still shows "Simulated Meter". It appears to expect the meter to be on com3?
CalMAN has no problem finding the i1D3, but I'm going to verify that I don't have any residual xRite stuff running in the background on my laptop.
jednc1 is offline
post #6 of 10 Old 03-03-2020, 12:43 PM
shoman94's Avatar
Quoted: 5619 Post(s)
Liked: 3791
I would contact portrait display tech support. Mine connects no problem.
Sent from my Pixel 4 XL using Tapatalk
2018 Sony LCD Master Series Calibration Thread
Sony XBR-75Z9F, Vizio M50-E1, Pioneer Kuro 5020, Marantz SR6013, AppleTV-4K, XBox One & (X), NVIDIA SHIELD.v1, FireTV 4K-HDR, HDHR Connects, QNAP 431+
shoman94 is offline
post #7 of 10 Old 03-03-2020, 02:22 PM
Liked: 1456
The com port selection is usually only needed for RS-232 based devices, not USB. I'd try the find meter function from within another workflow to see if it works there (I haven't had consistent results trying to find a meter from within the meter profile routine, seems like it really wants the meters to be tallied beforehand). It should allow you to choose from the meters it has found with any workflow.
...Royce...
post #8 of 10 Old 03-04-2020, 06:22 AM - Thread Starter
jednc1's Avatar
Quoted: 13 Post(s)
Update. Last night when I got home from work I tried a couple of things and now I'm up and running. Unfortunately I can't sure which one actually fixed my issue. First I did not have the meter dial in the correct position. It was in the position for calibrating the meter. (If using the iProfiler software this is the position you put the meter in to calibrate it to a reference white square) I switched it to the correct position. I also found where there was indeed still a driver loaded for xRite so I uninstalled that. After doing those the meter was recognized by CalMAN.
Thanks for your input and helping me track this down.
Rolls-Royce and shoman94 like this.
jednc1 is offline
post #9 of 10 Old 03-04-2020, 07:07 AM
CalWldLif's Avatar
Quoted: 342 Post(s)
Liked: 85
safest to unistall that.
Loving D65
post #10 of 10 Old 03-05-2020, 07:42 AM - Thread Starter
jednc1's Avatar
Quoted: 13 Post(s)
All is well now. I was able to create a profile for my i1D3. Once I recalibrate my TV (probably this weekend) I'll let you know if the results are better. BTW, I don't have the iProfiler software on my laptop, I was merely referring to it in order to explain the position I had the meter in. I think I may put together a video on how to use the ColorMunki to create a profile in CalMAN for others that may have the same questions/issues I had.
jednc1 is offline
Reply Display Calibration
