How to correctly launch MadVR? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-05-2020, 08:14 PM - Thread Starter
Anderegg's Avatar
Quoted: 618 Post(s)
Liked: 361
I cannot get MadVR's GUI to display, the one with the check box buttons across the top. I open MadVR, but it only shows in the taskbar. It launches patters with HCFR, but with Calman it is unresponsive. MadVR is the only pattern generator I can use for Calman, and without the GUI, I cannot access the HDR toggle to calibrate HDR, so I am kinda stuck. I tried uninstalling and deleting and dowloading again, but same thing, only visable in the taskbar.
Paul
Sony X900F SDR and HDR Calibrations https://www.avsforum.com/forum/166-l...l#post57551552
Anderegg is offline
post #2 of 3 Old 03-06-2020, 12:12 AM
MMoser's Avatar
Quoted: 88 Post(s)
Right click on the madvr icon and edit settings. Icon is in the Taskbar next to the clock when you are playing a video configured to render with madvr.
Sent from my SM-N975U using Tapatalk
MMoser is offline
post #3 of 3 Old 03-06-2020, 04:31 AM
Quoted: 174 Post(s)
Liked: 33
I replied in the sony thread, but if you are talking about madTPG, you have to click on that separately.
toby5 is offline
Reply Display Calibration
