LCD from 2010 - RGB full or limted? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-24-2020, 10:36 PM - Thread Starter
2mg
Liked: 0
Question LCD from 2010 - RGB full or limted?
Help me with an old peasant (but serviceable!) LCD please.
I'll try to keep it tldr;
- old 2010 Samsung TN LCD BX2231
- HDMI only, Nvidia control panel sees it as HDTV, known NV issue
- tried 2 options: RGB full, YCbCr444
- both options increase perceived clarity/"cleanliness" of the screen
- "AVS HD 709" black-level/clipping calibration pattern shows more black colors
- bright material seems even brighter, and more contrasted to dark material
Issue:
- overall screen becomes darker
- dark material loses a lot nuance (aka gray becomes dark gray and so on)
- no gamma bumping (in-game or LCD OSD) is bright enough
- LCD's "HDMI black level" is Normal, because Low+RGB full = even more darkness
- contrast 75, brightness 100, gamma mode1 (I'm unsure it that's 2.0, 2.2, 2.4 or some else)
So, I'm confused. It's a PC monitor, on a PC, where RGB full makes sense. Screen gets overall cleaner, I can see more dark levels, but also loses a lot of perceived brightness, and dark stuff becomes even more dark.
Old panel, or a setting set wrong?
2mg is offline
post #2 of 6 Old 03-24-2020, 11:15 PM
markmon1's Avatar
Quoted: 6152 Post(s)
Liked: 4200
Match your source.
Sorry, but your answer got as much detail as your question provided.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #3 of 6 Old 03-25-2020, 09:28 AM - Thread Starter
2mg
Liked: 0
Originally Posted by markmon1 View Post
Match your source.
Thing is, I don't know how to match this panel, that's why I'm asking, and provided the behavior.
For the purpose of this conversation, source is a PC set to RGB full running a PC game, which AFAIK are in RGB full as is.
I can't post images for comparison...
2mg is offline
post #4 of 6 Old 03-28-2020, 07:43 AM
CalWldLif's Avatar
Quoted: 339 Post(s)
Liked: 85
sounds like an issue people run across from time to time
if "low" caused problems then try "high"
Loving D65
CalWldLif is offline
post #5 of 6 Old Yesterday, 11:22 PM - Thread Starter
2mg
Liked: 0
Limited + Low = Full + Normal, literally _in my case_.
But that's not the issue. Both options provide a cleaner image, but everything that isn't really bright gets really dark, and no amount of fiddling with monitor's settings can compensate.
2mg is offline
post #6 of 6 Old Today, 02:42 AM
CalWldLif's Avatar
Quoted: 339 Post(s)
Liked: 85
i am not quite clear on just what you are seeing.
sounds like gamma.
no gamma settings?
Loving D65
Reply Display Calibration
