Does X-Rite i1Display Pro retail edition need a matrix in HCFR? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Dominic Chan
post #1 of 6 Old 03-30-2020, 11:20 AM - Thread Starter
daMaster's Avatar
Quoted: 13 Post(s)
I currently have a Colormunki Display, which I purchased in 2014, but find that it results in a greenish tint for grayscale calibrations. So I am considering purchasing the X-Rite i1Display Pro retail edition from Amazon to use with HCFR. Does it require a correction matrix in HCFR and if so, how do I generate one?
daMaster is offline
post #2 of 6 Old 03-30-2020, 11:43 AM
Rolls-Royce's Avatar
Quoted: 1373 Post(s)
Liked: 1456
https://www.avsforum.com/forum/139-d...-software.html
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #3 of 6 Old 03-30-2020, 05:00 PM
Quoted: 5834 Post(s)
Liked: 2346
There are a number of “display types” you can select from (similar to the Colormunki Display). If none of those match your TV you need to generate a custom correction matrix, but you would need a spectrophotometer such as the i1Pro to do that.
Rolls-Royce likes this.
Dominic Chan is online now
post #4 of 6 Old 03-30-2020, 10:01 PM
CalWldLif's Avatar
Quoted: 342 Post(s)
Liked: 85
the munki is the lowest grade version of the i1display
it has been a while since i used hcfr but it has built in modes that support the meter.
is that what you want to know?
Loving D65
CalWldLif is online now
post #5 of 6 Old 03-31-2020, 11:16 AM - Thread Starter
daMaster's Avatar
Quoted: 13 Post(s)
Got it, thanks. Since I'm calibrating a Panasonic plasma and a Vizio LED then those should be covered by the "Display Types" in HCFR.
Is the i1 Display Pro a better colorimeter than the Colormunki Display and will it be worth the upgrade?
daMaster is offline
post #6 of 6 Old 03-31-2020, 11:19 AM
SirMaster's Avatar
Quoted: 1062 Post(s)
Liked: 694
For manual calibrations probably not as it should have the same accuracy.
For 3DLUT it might be worth getting the Pro as it measures significantly faster which you would want for measuring many patches in a 3DLUT.
SirMaster is online now
Reply Display Calibration
