Calibration hardware - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-18-2020, 08:52 AM - Thread Starter
Quoted: 272 Post(s)
Liked: 26
Hi,
I have a JVC LX-UH1 projector. I use a HTPC with MadVR.
I want to calibrate it, but I don’t know what hardware I need to measure color, brightness, etc.
I see people talking about 3D LUTs. I’m not sure if this is required but any info would be great!
Thank you.
I am trying to calibrate for HDR.
cowbodude99 is offline
post #2 of 11 Old 04-18-2020, 10:26 AM
Rolls-Royce's Avatar
Quoted: 1462 Post(s)
Liked: 1545
You may want to ask in the main MadVR thread. You'll likely get more info on supported meters and how to do your LUT there.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #3 of 11 Old 04-18-2020, 11:32 AM
Light Illusion's Avatar
Quoted: 972 Post(s)
Liked: 1546
The hardware is just the probe you want to use.
Most calibration systems can use the i1D3, which is the cheapest, viable probe.
https://www.lightillusion.com/i1display_pro.html
And then you need to decide on the calibration software.
For example: https://www.lightillusion.com/madvr_manual.html
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #4 of 11 Old 04-19-2020, 04:59 AM - Thread Starter
Quoted: 272 Post(s)
Liked: 26
Im a bit confused.
I was looking at the Displaycal Getting Started guide in their site.
It says to click calibrate, and that’s it.
Don’t I need to make the changes on the projector’s settings?
post #5 of 11 Old 04-19-2020, 08:40 AM
Quoted: 6161 Post(s)
Liked: 2571
Originally Posted by cowbodude99 View Post
Im a bit confused.
You’re using the wrong software. DisplayCAL is used primarily for computer displays, and the calibration software generates and saves the necessary corrections on the computer.
To calibrate a TV or projector you will need to use HCFR, CalMAN, ChromaPure, LightSpace etc.
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #6 of 11 Old 04-19-2020, 09:27 AM - Thread Starter
Quoted: 272 Post(s)
Liked: 26
Oh! Would I still use the color meter?
Do I also need ArgyllCMS? Install this first, then hcfr?
Then hcfr can use the ArgyllCMS supported colorimeter?
At the point I would use the colorimeter in HCFR and work from there?
Is there a guide for this program?
post #7 of 11 Old 04-19-2020, 04:06 PM
Liked: 2571
There’s a dedicated thread on HCFR. The first post includes links to tutorials and other useful information.
post #8 of 11 Old 04-19-2020, 05:13 PM - Thread Starter
Quoted: 272 Post(s)
Liked: 26
Thanks! I see the thread.
post #9 of 11 Old 05-08-2020, 06:39 AM - Thread Starter
Quoted: 272 Post(s)
Liked: 26
Hi there,
I finally got my color meter.
What correction would you use for the JVC DLPs? I see other JVC devices listed, but none for DLP.
post #10 of 11 Old 05-09-2020, 05:04 PM
Liked: 2571
Hi there,
The correction depends more on the light source than the panel technology. If it uses a UHP lamp then use the correction for projectors.
post #11 of 11 Old 05-12-2020, 10:06 PM
Quoted: 30 Post(s)
Liked: 7
but he is using MadVR on his HTPC so DisplayCAL is fine to use and will correct any problems with the video chain.
bogaboga is offline
Reply Display Calibration
