Monitor calibration and color management - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By Light Illusion
post #1 of 19 Old 05-06-2020, 07:58 PM - Thread Starter
Overrid3's Avatar
Quoted: 197 Post(s)
Liked: 104
Not sure if this is the appropriate section for this, but I'm running into some issues with my new wide gamut monitor. The colors appear overly saturated when viewing images, including the image I have set as my wallpaper. I'm comparing to a 2nd screen, which only has standard sRGB coverage. If I open an image in Firefox, and move it between screens, it looks about the same. Firefox is applying color management properly. However, if I open the same image in my default image viewer, a small program called jpegview, it looks drastically different. Here it is compared to window live view, which appears to be applying color management correctly. So I guess this jpegview program isn't color managed, or isn't reading tagged images correctly.
Finally, my windows wallpaper image has the overly saturated colors, so it appears windows 10 isn't applying the sRGB tag correctly either. Is there a way to force windows to color manage the wallaper image?
Overrid3 is offline
post #2 of 19 Old 05-06-2020, 11:58 PM
Quoted: 46 Post(s)
Liked: 31
You cannot force Windows OS to color manage the wallpaper. Instead you can pre-process your wallpaper beforehand converting it from sRGB to your Monitor's color space and then install it.
You can only have GreyScale (Gamma & White Balance) correction OS wide when using Windows OS. Gamut correction (or even complete color correction) can only be done through an application which supports Color Management. For GreyScale correction, a 1DLUT can be generated and loaded in the VCGT (Gamma Tables) of the graphics chip.
omarank is offline
post #3 of 19 Old 05-07-2020, 01:31 AM
Light Illusion's Avatar
Quoted: 972 Post(s)
Liked: 1546
The information here may help: https://www.lightspace.lightillusion..._profiles.html
Steve
omarank and Overrid3 like this.
Steve Shaw
LIGHT ILLUSION
Light Illusion is online now
post #4 of 19 Old 05-07-2020, 10:50 AM
Quoted: 6161 Post(s)
Liked: 2571
Steve
It says
See the Error!page of the website for further information.
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #5 of 19 Old 05-07-2020, 10:50 AM - Thread Starter
Overrid3's Avatar
Quoted: 197 Post(s)
Liked: 104
Thanks! Windows 10 appears to still be in the stone age, LOL. My workaround is to just use B&W images for my desktop wallpaper. I could give the color conversion a try, but probably won't bother. Now I see why people like Macs
Overrid3 is offline
post #6 of 19 Old 05-07-2020, 10:53 AM
Liked: 2571
Last time I checked, MacOS does not handle untagged images properly. It applies the monitor profile, rather than assume it’s sRGB which is much more likely the case.
post #7 of 19 Old 05-07-2020, 11:02 AM
Quoted: 972 Post(s)
Liked: 1546
[QUOTE=Dominic Chan;59608530]
It says
[IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Sorry, is there a bad link, or something?
You might want to be a bit more specific..
Steve
Steve Shaw
LIGHT ILLUSION
post #8 of 19 Old 05-07-2020, 11:05 AM
Liked: 2571
[quote=Light Illusion;59608610]
Steve
That is copied directly from the web page you listed.
post #9 of 19 Old 05-07-2020, 11:08 AM
Quoted: 972 Post(s)
Liked: 1546
Yes, and have you looked at the "Error!" Page of the website??? 🤔
https://www.lightspace.lightillusion.com/error.html
Steve
Steve Shaw
LIGHT ILLUSION
post #10 of 19 Old 05-07-2020, 11:50 AM
Liked: 2571
Steve
It would help if the “Error!” Page is a link.
post #11 of 19 Old 05-07-2020, 11:51 AM
Quoted: 972 Post(s)
Liked: 1546
That is kinda what I asked...
Steve
Steve Shaw
LIGHT ILLUSION
post #12 of 19 Old 05-07-2020, 12:13 PM
Liked: 2571
Steve
And the answer is “it’s currently NOT a link”, but should’ve been.
post #13 of 19 Old 05-07-2020, 12:14 PM
Quoted: 972 Post(s)
Liked: 1546
Indeed, and that is the answer you could have given...
Steve
Steve Shaw
LIGHT ILLUSION
post #14 of 19 Old 05-07-2020, 12:17 PM
Liked: 2571
Steve
It’s your website and you could at least check before asking for further clarification.
The answer would have been obvious.
post #15 of 19 Old 05-07-2020, 12:20 PM
Quoted: 972 Post(s)
Liked: 1546
And useful critiques would include useful information...
The link has been added.
Thank you for pointing it out, eventually...
Steve
Steve Shaw
LIGHT ILLUSION
post #16 of 19 Old 05-07-2020, 12:27 PM
Liked: 2571
Steve
I have never seen anyone so unappreciative. :sigh:
post #17 of 19 Old 05-07-2020, 12:31 PM
Quoted: 972 Post(s)
Liked: 1546
Never come across anyone who enjoys being so abstruse...
Steve
Steve Shaw
LIGHT ILLUSION
post #18 of 19 Old 05-08-2020, 05:44 AM
Quoted: 27 Post(s)
Liked: 2
You mean all the errors, bugs & IU elements issues in Apple's color management engine, the incompatibilities with complex profile types, the lack of OSD or programable LUT in their displays (exclude XRD) so all corrections need to be done in GPU, and the glossyness to see your face while you edit. Did you mean that?
Objectively it's difficult to see why people like macs for image editing if we exclude "showing status" motivation (and that is a good reason, really, no irony)
@omarank has explained it to you. Convert image from one colospace to your display profile (you can assume sRGB source if no explicit colorspace is provided). It is not "give a try", it is what any color managed app would do.
Vicent is offline
post #19 of 19 Old 05-10-2020, 06:45 PM - Thread Starter
Overrid3's Avatar
Quoted: 197 Post(s)
Liked: 104
Update: I ran a calibration for my monitor using the sRGB color space, and things are a lot better, IMO. Windows behaves "normally" again. The more I read, the more I feel I don't even need to use a wider gamut than sRGB. However, since the Eizo can store multiple cals, it's easy to flip back and forth if need be.
Overrid3 is offline
Reply Display Calibration
