LG Adjust Lumiance function i the RGB of 10p? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-23-2020, 07:13 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 5
Hi,
I was going to calibrate the 10P on my LG for SDR and I did find a function called adjust Luminace beside the RGB standard things.
Should I use it or will it only break more then it adjust?
rstolpe is offline
Reply Display Calibration
