sony vpl HW30 + I1display pro problem - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 34 Old 06-18-2020, 06:22 AM - Thread Starter
alessandro@3belli.it's Avatar
Liked: 1
I've used the firt time I1display + HCFR t to calibrate a LCD tv and it was quiet easy.
then I try to calibrate my sony vpl HW30 , it's a reflesive LCD, but something doesnt work
With the Projector HCFR always show that all gray tone are too rich on BLUE and missing on RED. To have the 3 RGB values closer each other I heve to set the RGB projector control to the end of the scale (blue to miniminu and red to maximun), and the images are owful.
If put on the screen then "Pattern windows" (where HCFR send the color pattern the colorimeter will read) and "reference windows" they look identical, but if I compare with "measured windows" (that show what the I1 read) always show a more rich in blue. So it seems to me that the I1 reads a lot ok blue that is not present.
What is the problem?
Thank you
[email protected] is offline
post #2 of 34 Old 06-18-2020, 09:57 AM
Quoted: 6285 Post(s)
Liked: 2646
Thank you
Most info is needed. Post the HCFR data file (.chc) that contains the greyscale sweep.
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #3 of 34 Old 06-18-2020, 11:22 PM - Thread Starter
Liked: 1
I upload the chc file (zipped).
I've put the sensor at 1.5 mt from the screen where the screen image height vas 1 mt
room was dark
HCFR was set as default
thank you in advance
post #4 of 34 Old 06-19-2020, 01:08 AM
mpyw's Avatar
Quoted: 105 Post(s)
Liked: 32
How many hours is your HW30?
I have a HW30 myself and the projector is unwatchable after only 600 hours due to panel degradation / display panel issue. As the projector had passes its' warranty period, Sony won't show any sympathy to me.
I have tried calibrate it (hired 2 different pro-calibrator) with pro equipment and software, both also end up giving up on the unit.
You might want to check on the Sony projector panel degradation thread.
To be or NOT to be......YOU are WHO you ARE
mpyw is offline
post #5 of 34 Old 06-19-2020, 01:41 AM
Liked: 2646
room was dark
Unfortunately, as mpyw mentioned, the projector exhibits significant panel degradation and the conventional 2-point gain/offset adjustments won't be able to adequately correct it.
Multi-point RGB gamma adjustment can help somewhat, but you need Sony's Image Director software to make such adjustments.
post #6 of 34 Old 06-19-2020, 03:24 AM - Thread Starter
Liked: 1
If I look on the screen pattern (the big one the sensor point to), reference and measured windows closed each other, Reference and pattern color looks identical but measured show much more blue. This tell me that the sensor read someting different.
When I look a film from BD the color looks quiet good
If I correnct with the projector control to have correct RGB values, the image became always very red.
Sony's Image Director software does not work on this prj model
post #7 of 34 Old 06-19-2020, 04:29 AM
Liked: 2646
Can you also post the .chc file for the post-calibration measurements?
post #8 of 34 Old 06-19-2020, 05:01 AM - Thread Starter
Liked: 1
Have you used Sony's Image Director ? Because on sony webpage this model is not mentioned as compatible one
post #9 of 34 Old 06-19-2020, 05:24 AM
Liked: 2646
The Sony website only lists HW50ES (in addition to the VW models), and yet I had no problems using it with my HW45ES.
post #10 of 34 Old 06-20-2020, 06:58 AM - Thread Starter
Liked: 1
800 hrs
post #11 of 34 Old 06-20-2020, 07:02 AM - Thread Starter
Liked: 1
I've tryed with imagdirector, it connect to the projector but does not allow to select any gamma preset
See attachment
post #12 of 34 Old 06-20-2020, 07:06 AM
Liked: 2646
See attachment
You have to click something on the screen first; I think it’s the arrow icon.
post #13 of 34 Old 06-20-2020, 07:24 AM - Thread Starter
Liked: 1
See attachment
Sorry,, I find the way to use imagedirector
Archibald1 likes this.
post #14 of 34 Old 06-21-2020, 01:13 AM - Thread Starter
Liked: 1
Thank's to all your suggestions: I was able to adjust che color level with imagedirector, but is clear that the LCD panel is degradated as the single color on the full screen is not uniform: the center of the screen is clearly different from the border
I have one more question. At this moment I am calibrating with grayscale only: With imagedirector, changes on a single color curve has visible effet (on HCFR measurement) untill 2/3 of the scale. Is possible that the color range that HCFR generate il less extended as the projector can show?
Thank you
post #15 of 34 Old 06-21-2020, 05:37 AM
Liked: 2646
If you’re adjusting greyscale HCFR will be sending out grey patterns between full black (0,0,0) and full white (256,256,256), or the limited range equivalent. What do you mean by “less extended than the projector can show?”
post #16 of 34 Old 06-21-2020, 01:09 PM - Thread Starter
Liked: 1
As the gamma color modification made with imagedirector has no visible effect over 2/3 of the gamma scale I suppose that HCFR does not use the full color wide range
post #17 of 34 Old 06-21-2020, 01:18 PM
Liked: 2646
I still don’t follow. It’s easier to see HCFR data file together with the adjustments that you made that had no effect.
If you’re increasing the output when adjusting the gamma curve and see no difference in the measurements, it would mean the projector output is clipping, not because HCFR.
post #18 of 34 Old 06-24-2020, 12:02 PM - Thread Starter
Liked: 1
I've forced a blue curve with a lot reduction on low level then it rise up after value 100 (vertical axes), on imagedirector. If you look the compared data of HCFR blue curve you see that this raise up after 60%. This tell me that the value of 300 on image director is over what hcfr measure
I hope il clear. Or I am wrong?
post #19 of 34 Old 06-24-2020, 12:25 PM
Liked: 2646
Sorry, still don’t understand. Need to see the Before and After HCFR files.
post #20 of 34 Old 06-24-2020, 12:46 PM - Thread Starter
Liked: 1
Why the BLUE curve on HCFR does not look like the blue curve on image director?
post #21 of 34 Old 06-24-2020, 12:59 PM
Liked: 2646
Why should they look the same? They are not plotting the same information.
If you look at the "Before" pair, Image Director would show three perfectly linear diagonal lines superimposed on one another, whereas HCFR would show R/G/B having very different shapes and levels. However, if you increase/decrease any curve in Image Director, you should see a corresponding change in HCFR. That's why I asked you to post the Before shots.
post #22 of 34 Old 06-24-2020, 01:09 PM - Thread Starter
Liked: 1
Why should they look the same? They are not plotting the same information. If you look at the "Before", ImageDirector would show three perfectly linear diagonal line superimposed on one another, whereas HCFR would show R/G/B having very different shapes.
i've reset the gamma curves as default flat on imadirector: flat.zip contain the relative chc file
then I've modified only blue as on the image and modif.zip contain the relative chc file
On the second you can see that the blue curve on Imagedirector raise up around 300 that is 1/3 of the full range. But on chc file you can see that here the blue curve rise up around 60% of hcfr scale. Why?
post #23 of 34 Old 06-24-2020, 01:31 PM
Liked: 2646
You cannot compare the "shape" of the Image Director curve with the curve in HCFR, as one is a relative gamma (relative to gamma 2.2, diagonal line), whereas the other is % RGB relative to the reference (horizontal line).
If you look at the Before (dotted) and After (solid) RGB graph, you can see that the changes are consistent with the adjustment you made in Image Director.
% change in the gamma curve does not translate into the same % change on the RGB graph. It’s a non-linear relationship.
post #24 of 34 Old 07-02-2020, 10:29 PM - Thread Starter
Liked: 1
Thank you.
I do many test and discover that color wide space parameter on projector is the trick. If set to standard (SRGB) the gamut is more smaller then the reference and changes on imagedirector values over 2/3 of the scale has no visible effect. If I change to wide2-3 the gamut is bigger and changes on imagedirector has more visible effect.
Is not clear to me what % values on HCFR RGB graph means. What is the reference value for 100%? If I change the prJ brightness the values goes up and down, but to have values around 100% I have to set the lam to low, close the diaphragm and move down the bright slider that is not the normal working condition.
post #25 of 34 Old 07-03-2020, 06:10 AM
Liked: 2646
The reference for % RGB is shown under Y Target. In the example below reference 33.887 nits for white, and the projector's red channels measured 73.5%, blue channel measured 131.8%, relative to that.
post #26 of 34 Old 07-03-2020, 11:20 AM
SirMaster's Avatar
Quoted: 1377 Post(s)
Liked: 1032
If you want to calibrate your Sony with HCFR.
1. Measure the gamut of all the custom gamut modes to find the widest gamut mode.
2. Use RGB gain controls in custom color temp to balance 100% white to 6500K.
3. Use image director gamma editor to bring all 3 colors in line to 100% from 1% to 99%. Make sure you have include gamma enabled in HCFR white balance graph.
4. Edit the primary and secondary colors on the Sony’s CMS, do most of the adjusting against the 75% saturation pattern, but check the full saturation sweep periodically.
5. Use black and white clipping patterns to set your brightness and contrast controls.
Here is a 55ES I did.
https://nicko88.com/misc/sony55es/stock.pdf
https://nicko88.com/misc/sony55es/calibrated.pdf
The result was stunning.
(If you are wondering, I intentionally let my 100% white be above 1.0dE to allow it to be slightly brighter)
SirMaster is online now
post #27 of 34 Old 07-03-2020, 02:04 PM
Liked: 2646
To calibrate my HW45ES I use the narrowest gamut that covers BT.709.
post #28 of 34 Old 07-03-2020, 07:07 PM
SirMaster's Avatar
Liked: 1032
Yeah that makes sense.
I am used to 40ES, 50ES, 55ES which are older and I guess with more hours and panel degradation all 3 custom gamut modes were all always less than 100% rec709 so I go with which of the 3 is the widest.
The 45ES are newer and hopefully doesn’t have as much degradation.
post #29 of 34 Old 07-04-2020, 02:42 AM - Thread Starter
Liked: 1
So Y target is the nit value the sensor read?
post #30 of 34 Old 07-04-2020, 02:49 AM
Archibald1's Avatar
Quoted: 2905 Post(s)
Liked: 1991
I have used Image Director on a VW60 and a VW760, so as long as you can interface with the HW30 via LAN or RS232 you should be able to make use of the software.
Edit: I have now seen you managed to get it to work. As you were.
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up." Stephen Hawking.
"Be water my friend." Bruce Lee.
Archibald1 is offline
Reply Display Calibration
