Hcfr and display type - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-21-2020, 08:41 AM - Thread Starter
Liked: 0
Hi all,
I've been tweaking with my tv, a Sony Bravia KD-49XD7004, which I presume is a model for the Europe market.
I was using a i1Dpro plus with Hcfr as:
rec709 75% bt1886 De2000
Now the question and my doubts, I've choosen non refresh display type,due the only info I get is a direct led from other sources?
Because I'm aiming for a grayscale De below 1( I know I'm just crazy), at 40% and 70% the De is over 1.7 and at 10% gray the blue is at 110 when I make full grayscale reading.
Or should I check other things like Y target and Gamma?
I'm no professional, just got curious and over the months I've read a lot of material, so any more help would be welcome.
Thank you all in advance.
Marco2020 is offline
post #2 of 4 Old 06-22-2020, 11:41 AM - Thread Starter
Liked: 0
Bump
post #3 of 4 Old 06-22-2020, 01:47 PM
CFC
CFC's Avatar
Quoted: 86 Post(s)
Liked: 46
You'll probably have better response in the HCFR thread here: https://www.avsforum.com/forum/139-d...-software.html
I am very much an amateur, so what I'm saying is just as I understand it so far
The i1Display Pro is commonly referred to as i1d3 (not i1Dpro )
non refresh is the correct choice for an LED type set.
Ideally you would want to profile your set using a spectro to your i1d3 colorimeter
Next best is to use a spectral file for your display technology if available.
For proper calibration, yes, you want to align your luminance to the Y target. This will ensure you calibrate to your desired gamma.
Good luck and have fun.
CFC
Signature goes here
CFC is online now
post #4 of 4 Old 06-22-2020, 06:56 PM - Thread Starter
Liked: 0
Thanks a lot for all the help CFC, much appreciated 😁
Reply Display Calibration
