For 77CX : I1 Display Pro or Pro plus ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-23-2020, 10:21 PM - Thread Starter
Quoted: 33 Post(s)
Liked: 6
Hello,
Will I see a advantage with the Pro Plus ? If yes which ?
Is it better / are the units as consistent as the Display Pro ?
Also, can you **** up your TV with a bad calibration ? Is it reversible ?
Cheers
Gloum is offline
post #2 of 2 Old 06-23-2020, 10:37 PM
rajendra82's Avatar
Quoted: 203 Post(s)
Liked: 212
The only benefit of a pro plus, that I know of, is the rated sensor up to 2,000 nits. This is not beneficial with a 77 CX, which tops out at around 700 nits, 800 if you get lucky.
As for your second question, if you mess up a calibration, just reset the picture mode, and you are back to factory settings. It is 100% reversible.
rajendra82 is online now
Reply Display Calibration
