Samsung 85" Q90T - Calibration Advise? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-25-2020, 10:32 PM - Thread Starter
Liked: 0
Hello -
I am, after 10 years, upgrading from a Mitsubishi 65C9 to a Q90T set. I have two calibration sensors that are probably not supported anywhere, and I have never calibrated a TV, I used them on monitors when I was doing photo/print work. But since I went all out on the TV, I am hoping I can get some guides/help to get this tuned as well as possible.
The two sensors I have are Spyder Pro, and Spyder 2 to calibrate it.
Thanks in advance, and if this is post isnt allowed, feel free to delete.
wickedgtr is offline
post #2 of 2 Old 06-28-2020, 11:46 AM
chunon's Avatar
Quoted: 3950 Post(s)
Liked: 3988
Originally Posted by wickedgtr View Post
Hello -
Pick up an i1d3 and then download the free hcfr software , from there you can decide if you are satisfied with the results or want to try other software or add a Spectro for profiling.
77”A9G Direct Tv AppleTv 4K Sony X800M2 Yamaha V685
LG 77C8
LG 55B7A
DirectTV/ ATV4k/Panasonic UB820/Sony Z9F Soundbar
Calman Enthusiast, Lightspace, C6 HDR 2000 I1Pro2
chunon is offline
Reply Display Calibration
