AVS HD 709 - Blu-ray & MP4 Calibration - Page 155 - AVS Forum | Home Theater Discussions And Reviews
 113Likes
post #4621 of 4660 Old 07-20-2018, 06:43 PM
echo419's Avatar
Quoted: 27 Post(s)
wow thanks Ted for that in-depth explanation. I got a lot to figure out tonight.
Jason
ConnecTEDDD and mrtickleuk like this.
echo419 is offline
post #4622 of 4660 Old 07-28-2018, 05:22 PM
tsunami2311's Avatar
Quoted: 21 Post(s)
I made DVD of this AVCHD (.7z)
I play this on ps4 I dont have acccess to bluray burner nor did I really want to buy bluray disc calibrator
So here I am trying to calibrate my TCL S517 2018 due to I keep seeing the faces looks smeared like water color some times it on HD pictures some time its on SD pictures some times it it not. other times the image looks amazing, its just seem all over like if there 720p with to much compression or video feed for 1080p, if there to much compression in the feed, I using Dish and hopper 3/4k joey setup set for 1080p/4k but that dont mean every feed is really 1080p or 720p or it isnt compressed to hell, cause not all channels are equal. true 720p/1080p with no compressions looke amazing the more compression then lower the res the more it happens.
Now my PS4 and PC outputs look amazing, maybe the color a lil less vibrate then I like. And I can only calibrate Brightness and Contrast, thing Is I need to use Movie preset other settings, Normal, Sports, Vivid, ( wont use lower power as it just makes thing way to dark, TV Brightness is Normal and setting I gona use.
I currently using this settings
Preset Movie
Backlight 80
Contrast at 99
Brightness at 50
Color at 65
Color Temp Normal ( I can use warm which make this to yellow an but and cool make thing more blue on white, I setting on Normal cause it was close I could get to color being way I like not washed out)
1. Black Clipping
3. White Clipping
These are the settings I need to use to get the closest to 17 to 25 flash on 1. while still have 2. 230-234 flashing any other seeing I tried so far I can even get Black clipping right or the White clipping or pick middle group. 2. APL Clipping is is about as close as I gona get it with messing up 1 and 2 But above is best I can get for white and darks.
Colors
Now I can't do much of anything with color set up due to not having glass filters needed. Most the gray scale and black from other option from the DVD look right to me. Color look good too on the shades test,But like I said I dont have blue filter glasses to really fine tune thing, and most of stuff is beyond me I read patters-manual, and I not follow how to actual how to fine tune the colors. even IF i had glass filters
I tried using the expert mode settings here
https://www.rtings.com/tv/reviews/tc...-s517/settings
Preset Movie
Backlight 80
Contrast at 99
Brightness at 50
Color at 65
Color Temp Normal
but didnt really help with the water color/clay faces weather I use all these seeting under movie and warm temps
but for most Brightness and blacks look great, and my ps4 and pc have good colors slightly less vibrate then I like but darks and bright seem right its just some time faces and and things look like water color/clay and that most on faces on Dish feeds.
My OCD been going crazy about the water color/clay faces. Other thing I notice is the TCL S517 I need to have gamemode on or latency is just bad, but I noticed IF gamemode is on I have to set sharpness to 0 any other setting then 0 cause the sharpness flickers for clear and blurry which is mostly noticeable on icons. I vaguely remeber this happening on my old LN35a550 tv too but I never used gamemode on that. is this PS4 issue or what?
I thinking a good portion of water color/clay faces is do to amount compression bing used by dish on there channels.
jmccrack650 likes this.
tsunami2311 is offline
post #4623 of 4660 Old 08-05-2018, 07:47 PM
Liked: 0
Sorry guys in advance but english is not my first language!!
And sorry for the stupid question
So i just heard about this free calibration software and wanted to use it to calibrate my TV.
What i usually do is watch movies from my Laptop linked with my TV via a HDMI cable.
The problem is my TV doesnt have a USB port so i can plug in the mp4 calibration file.
From my understand i can not run this calibration tool on my laptop and calibrate my TV via HDMI cable right?
IF i try to run the tool from my laptop that would require to calibrate the color settings of the laptop first right?
Ryuyru is offline
post #4624 of 4660 Old 08-05-2018, 09:22 PM
Quoted: 4372 Post(s)
Liked: 1609
Note that the AVS HD 709 files are only test patterns, not the calibration software. You can use HCFR for the latter.
If you play movies using your laptop, then you can (or even should) play the mp4 test patterns from your laptop as well.
It’s not necesssary to calibrate the laptop on its own.
Dominic Chan is online now
post #4625 of 4660 Old 08-06-2018, 07:02 PM
Liked: 0
It’s not necesssary to calibrat pe the laptop on its own.
OK my level of knowledge on this subject is pretty low.
I play movies using my laptop but i watch it on my tv via HDMI. IF my TV had a USB port i would just put the mp4 files on a flash driver and use it to adjust my TV settings. I cant do that. I could however run the test patterns from my laptop and use it to adjust my TV settings.
What im failing to understand is that the picture i see on my TV (color, contrast, brightness) is a result of both my TV settings and my laptop settings. For example, when i play one of the test patterns of avs hd tool from my laptop, i see completly diferrent images depending on the player im using to play the file (vlc, kodi, etc.).
How can i be certain that im correcting adjusting my TV? Maybe my TV is already fine and the "bad" quality of the image i see is not due to the TV been incorrect calibrate but due to my laptop outputing incorrect levels of brightness, contrast, etc.
Ryuyru is offline
post #4626 of 4660 Old 08-06-2018, 09:30 PM
Liked: 1609
That's precisely why you should always use the same setup (hardware and software) to display the test patterns, as the setup you use to watch movies.
For people who watch movies on disc, they should use the disc-based patterns. Not in your case.
Madmax67 likes this.
post #4627 of 4660 Old 08-10-2018, 08:40 AM
p5browne's Avatar
Quoted: 3978 Post(s)
Liked: 3136
Every TV I've ever owned, had a USB Port ?
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is online now
post #4628 of 4660 Old 08-11-2018, 06:59 AM
ConnecTEDDD's Avatar
Quoted: 2919 Post(s)
Liked: 3552
Hi, if you have only a calibration disk, then you don't need any software, just playback the patterns you can use for calibration without meter from inside the software players you are using and make the adjustments (if you see different results per player post what you see or look their settings), see there what you can change without meter/software: https://www.avsforum.com/forum/139-d...l#post56609032
You can setup from your laptop the TV to work as extended desktop, so the TV to display only the software player window in full screen while to your notebook to see your normal desktop.
If you have plans to get a meter and software then you will need to use it as extended desktop, to view the calibration software charts from your notebook and display patches from the TV.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #4629 of 4660 Old 08-11-2018, 08:42 AM
mrtickleuk's Avatar
Quoted: 4358 Post(s)
Liked: 6606
What, even this one?
arcspin likes this.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #4630 of 4660 Old 08-11-2018, 06:57 PM
Rolls-Royce's Avatar
Quoted: 1019 Post(s)
Liked: 1154
Wow, look at the size of that VCR!
mrtickleuk likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #4631 of 4660 Old 08-11-2018, 07:12 PM
p5browne's Avatar
Liked: 3136
USB wasn't even a twinkle in it's inventor's eye back then.
UN65KS9800 - Mine
post #4632 of 4660 Old 09-25-2018, 08:28 AM
p5browne's Avatar
Liked: 3136
HDTV patterns bring up a different set of settings when input through the USB, off my Samsung UHD Video Pack versus the AVHD 709 Calman patterns. Mystery is, why, and where are these settings used ? (KS9800). Not used for SDR Video playback, which instead uses the Calman settings from patterns on the same Video Pack.
UN65KS9800 - Mine
post #4633 of 4660 Old 11-21-2018, 12:32 PM
Liked: 0
Pattern manual link is Broken
Hello, pattern manual link is broken, someone know how i can get it?
Guillaume Gadbois Gervais is offline
post #4634 of 4660 Old 11-21-2018, 01:03 PM
Liked: 1609
Use the alternate links listed in the same post.
post #4635 of 4660 Old 12-10-2018, 12:53 PM
Lend27's Avatar
Quoted: 220 Post(s)
Liked: 60
Hi Guys!
I would like to be able to put the calibration files onto a USB flash drive and insert it into a USB port on the back of my tv.
What download option should I select for that to be possible?
Also, a basic step by step to properly get the files onto the usb would be helpful.
Thanks again guys!
Len
Lend27 is offline
post #4636 of 4660 Old 12-10-2018, 01:35 PM
Liked: 1609
Originally Posted by Lend27 View Post
Hi Guys!
Thanks again guys!
Len
Just download the mp4 files.
post #4637 of 4660 Old 01-02-2019, 11:58 AM
PhantomCage's Avatar
Liked: 1
Primary colors pattern question
Hello, and thank you for the work put into these. I have read the provided guide as well but still got some questions.
I used the primary colors pattern to setup my TV. There is a clear difference between grey and red under a red filter on uncalibrated TV settings, same with green so I increased chroma I believe, until they matched. Is this the correct way to proceed? I left saturation at standard 50.
My expert settings look something like this now
Red 6
Tint 0
Green 6
Tint -6
Blue 0
Tint 0
Yellow 4
Tint -2
Cyan 4
Tint 0
Magenta 5
Tint -5
PhantomCage is offline
post #4638 of 4660 Old 01-07-2019, 12:21 AM
Liked: 3552
For AVSHD thread subscribers, the answer for this post is available there: https://www.avsforum.com/forum/139-d...l#post57375096
post #4639 of 4660 Old 01-09-2019, 12:38 PM
Quoted: 21 Post(s)
is there HDR calibration files or patterns? This tcl s517 support hdr but only way I found to calibrate it is threw windows 10 and have HDR enabled, And I only calibrated the White/Black using the MP4-2c Patterns.
According to that blacks and whites are were they should be, but that is for SDR those files.
HDR looks fine on my PC and Consoles for the games that support it, colors pop out tad less then I like though, only game look wierd in hdr is FFXV in area where the sun glaring it unbarring bright by that mean thing extramely washed out and blues be come more purple with hdr on, but Horizon Zero Dawn look pretty good,
post #4640 of 4660 Old 01-09-2019, 12:49 PM
Liked: 1609
You can download HDR patterns here
https://www.avsforum.com/forum/139-d...terns-set.html
If your PC is compatible, or if your TV can be placed in HDR mode manually, you can even use HCFR’s internal patterns to calibrate HDR.
post #4641 of 4660 Old 01-09-2019, 01:02 PM
Quoted: 21 Post(s)
yah I just noticed that, and checked it out, most the videos in those links dont play for me something about missing codec or somthing
post #4642 of 4660 Old 01-09-2019, 02:54 PM
Liked: 1609
With the appropriate graphics card you can use HCFR’s internal patterns for HDR.
For disc based patterns you can get this:
https://www.avsforum.com/forum/139-d...-patterns.html
post #4643 of 4660 Old 04-06-2019, 01:49 AM
Nordo's Avatar
Quoted: 33 Post(s)
I know this thread is almost dead, but it seems the best place to post my question (especially if ConnecTEDD is still lurking).
I have a HTPC setup - PC with Kodi and a NVIDIA GT1030 card; connected to an Epson EMP-TW2000 (same as a 1080B) via an AV receiver.
I want to calibrate the system using the basic patterns from MP4-2c (don't have a colorimeter yet).
I can alter most video settings in Kodi, the video card, and in the pj.
I've read that in the chain - Kodi/video card/projector - the best colour space (0-255 or 16-235) should be Full:Full:Full or at least Limited:Full:Limited.
I can set each up as either Full (0-255) or Limited (16-235), but based on ConnecTEDD's earlier posts, I'm now not too sure what is the best setup.
Can anyone recommend the best setup of colour space for a HTPC where all the video information is home movies or downloaded movies (mp4 and some avi)?
My other problem is that I want to do all the calibration in the projector, but (as well as the colour space) I don't know how to set up the other components (especially the video card), so that the best signal is getting to the projector.
Any help would be greatly appreciated.
Nordo is offline
post #4644 of 4660 Old 04-06-2019, 06:44 AM
FlynP5's Avatar
Quoted: 13 Post(s)
This might help you:
https://lifehacker.com/how-to-get-be...ate-1700412363
https://pcmonitors.info/articles/cor...-and-amd-gpus/
https://www.guidingtech.com/19148/op...ay-experience/
Panasonic TC-PS60 plasma • Anthem MRX 510 • OPPO DV-980H • Rogers Nextbox 2.0 8642 HD • Playstation 3 • HTPC (AMD A10-7850K APU, GTX 1060) • SVS Ultra Series Speakers • HSU STF-3 Subwoofer
FlynP5 is offline
post #4645 of 4660 Old 04-06-2019, 04:23 PM
Nordo's Avatar
Quoted: 33 Post(s)
Nordo is offline
post #4646 of 4660 Old 05-01-2019, 06:02 PM
Liked: 0
Hey guys a newbie here to calibration and this forum.
So I did the calibration for my Q8FN using the files in this thread. I am using the TV for PC monitor and for cable as well. PC mode, bluray, console and game modes look great with the new settings after calibration all with HDR enabled. I later saw that there is a HDR calibration topic. Should I also try those out and see what happens even with the great results from the current calibration techniques from AVS HD 709.
After the great results I wanted to calibrate the cable TV settings and the settings for the HBO app. So I put the files on a USB stick and did the calibration. Unfortunately, the results for those settings were way off. What could be the issue?
bacetonkich is offline
post #4647 of 4660 Old 05-02-2019, 03:24 AM
bustamelon's Avatar
Quoted: 30 Post(s)
Liked: 25
Odds are it's the super high compression ratio the cable company (and the app) are forcing on the video. Colors tend to wash together, and dark scenes are especially bad. If your monitor allows multiple calibration profiles, you can adjust accordingly for those sources, but I don't know if that's actually a thing.
bustamelon is offline
post #4648 of 4660 Old 05-02-2019, 05:52 PM
Liked: 0
Yeah I have for every source a different calibration profile. The bad thing is I did the TV and the app by eye. It look ok-ish, but I know it can be better. Is there another option which I can try to do the calibration?
post #4649 of 4660 Old 05-02-2019, 06:10 PM
bustamelon's Avatar
Quoted: 30 Post(s)
Liked: 25
Unfortunately I can't say -- it would depend on what type of compression is being used and what kind of artifacts you're seeing. And even if we knew, I could only guess. Honestly I haven't had much luck making bad compression look good. You can't polish a turd. What works for some scenes will make others much worse. Maybe someone more knowledgeable will chime in. I can only suggest playing around with noise reduction and contrast.
post #4650 of 4660 Old 05-14-2019, 08:57 AM
machavez00's Avatar
Quoted: 40 Post(s)
Liked: 59
It looks like some created an ATV app with the files, Calibr8
https://itunes.apple.com/us/app/cali...061996443?mt=8
machavez00 is online now
Reply Display Calibration
Lcd Hdtv , Led Hdtv , lg bp530
