The Official Xbox One X thread - Page 217 - AVS Forum | Home Theater Discussions And Reviews
 3611Likes
post #6481 of 6624 Old 04-20-2019, 07:40 AM
Quoted: 48 Post(s)
Liked: 42
Originally Posted by Holmes108 View Post
Not sure the resolution of that monitor but I do know freesync on Xbox is limited to 1440p and not 4K, for what it's worth.
Sent from my SM-N920W8 using Tapatalk
Freesync (VRR) over HDMI works fine at [email protected] on X1X.
Sent from my iPhone using Tapatalk Pro
ShePearl is offline
post #6482 of 6624 Old 04-20-2019, 04:28 PM
Holmes108's Avatar
Quoted: 14 Post(s)
Liked: 6
Hmm, apologies if I spread misinformation. Now that I think about it, you're right, it was the 60 vs 120 that was the issue I ran into regarding resolution.
Holmes108 is offline
post #6483 of 6624 Old 04-20-2019, 05:00 PM
Viscious82's Avatar
Quoted: 154 Post(s)
Liked: 45
The xbox can't do freesync on 1440p @120 hz. It works at 4k60.
Sent from my SM-G960U using Tapatalk
Viscious82 is online now
post #6484 of 6624 Old 04-20-2019, 06:01 PM
Holmes108's Avatar
Quoted: 14 Post(s)
Liked: 6
Yep
post #6485 of 6624 Old 04-20-2019, 06:07 PM
rightintel's Avatar
Quoted: 900 Post(s)
Liked: 350
Is Freesync a setting on the Xbox?
Xbox Live: General PATT0N
rightintel is offline
post #6486 of 6624 Old 04-20-2019, 06:19 PM
Dr.Shankenstein's Avatar
Quoted: 674 Post(s)
Liked: 579
Yes, if your display is capable there will be a box to check in display settings.
Sent from my LG-G710 using Tapatalk
Dr.Shankenstein is online now
post #6487 of 6624 Old 04-20-2019, 06:35 PM
rightintel's Avatar
Quoted: 900 Post(s)
Liked: 350
I went into display settings, wasn't there. Interestingly enough, I unchecked 24Hz and 50Hz, and when I tried to check it again, it told me me TV is telling the Xbox it won't do that lol.
post #6488 of 6624 Old 04-20-2019, 07:36 PM
Quoted: 674 Post(s)
Liked: 579
Do you have a freesync capable display? Some older freesync displays would only work through display port if I'm not mistaken.
Compatibility doesnt appear to be guaranteed even with a freesync capable device.
post #6489 of 6624 Old 04-20-2019, 08:09 PM
Quoted: 48 Post(s)
Liked: 42
To be precise, X1X supports Freesync 2.
Freesync 2 allows VRR + HDR over HDMI.
ShePearl is offline
post #6490 of 6624 Old 04-20-2019, 11:38 PM
Arutha_conDoin's Avatar
Quoted: 733 Post(s)
Liked: 680
Yeah, I have done a bit of research. The display I am looking at is 1440p and over HDMI limited to 100hz freesync.
My set has been way to big for my viewing area for a long time, so between the heat of my console and heat of my TV from less than 4 ft away my side of the bed is an oven.
Good way of losing weight while playing games!
Xbox Live: DaBeavers
PSN- Arutha_conDoin
Steam- An0mander
"Too much knowledge never makes for simple decisions."
-Ghanima Atreides
Arutha_conDoin is online now
post #6491 of 6624 Old 04-21-2019, 02:30 PM
rightintel's Avatar
Quoted: 900 Post(s)
Liked: 350
Considering this portable SSD drive. I'd like your guys thoughts(and other recommendations):
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
post #6492 of 6624 Old 04-21-2019, 02:32 PM
Quoted: 674 Post(s)
Liked: 579
I had some success with quicker load times and transitions in game.
Quantum break and Anthem both loaded much faster with the use of an SSD.
post #6493 of 6624 Old 04-22-2019, 02:59 AM
P40L0's Avatar
Quoted: 189 Post(s)
Liked: 110
Lightbulb LG 2017 OLEDs - All Profiles Re-Calibration (April 2019)
  • ALL PROFILES UPDATED TO V7 ULTIMATE
  • Firmware 5.80.xx or above is required
  • Completely new re-calibration of all SDR/HDR/DV picture modes with new tools and after 4.000+ hours usage (based on new sonoftumble settings)
  • New Dolby Vision Custom Calibration file to apply via USB patch (updated on April 2019)
  • HDR Game mode back to a new custom profile based on HIGH Dynamic Contrast to match the new improvements
  • Added new in-game HDR suggested settings
Please not that this re-calibration goes in-depth also for all White Balance + CMS values, so do not forget to also update those sections when possible (and do not forget to also update the entire DV profile using the new USB Patch!)
Then give those completely fresh settings a try and let me know what you think...
P40L0 is offline
post #6494 of 6624 Old 04-22-2019, 07:59 AM
UHD Addict
aaronwt's Avatar
Quoted: 8855 Post(s)
Liked: 5643
It's much cheaper to get a bare SSD and put it in your own enclosure.
FilmMixer likes this.
53TB unRAID2--45TB unRAID3--35TB unRAID1a
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #6495 of 6624 Old 04-22-2019, 02:16 PM
Quoted: 56 Post(s)
Liked: 6
Hi! I’m a bit confused regarding the audio formats I should choose. I have a 5.1.2 setup with a Yamaha receiver that can handle Atmos and it supports a 7.1 setup.
My question is what audio format should I use for blu Ray, dvd, and for streaming showtime and hbo s. I noticed that for blu Ray that supports dts-hd master audio my receiver shows that when my Xbox sound settings is set for 5.1 uncompressed or bitstream Atmos. Is one better than the other? Thanks!
Do any of you guys think it is better to use a stand alone 4K DVD player? I bought a lg c8 65 inch which was ranked to have the best picture of 2018z. I’m wondering if it’s worth getting the Panasonic ub820. I thought about the 9000 but it sounds as though the difference between the two is the high fidelity outputs that you would use if you don’t use a receiver.
[email protected] is offline
post #6496 of 6624 Old 04-22-2019, 07:42 PM
rightintel's Avatar
Quoted: 900 Post(s)
Liked: 350
Any recommendations?
post #6497 of 6624 Old 04-22-2019, 07:58 PM
Quoted: 674 Post(s)
Liked: 579
You can grab a Sandisk Pro 1tb for a for about $99 at the moment and for about $15 a nice metal enclosure with USB C to USB 3 support.
rightintel likes this.
post #6498 of 6624 Old 04-23-2019, 05:52 AM
mtbdudex's Avatar
Quoted: 83 Post(s)
Liked: 1479
Hey beta testers / those in the "know", status on the Atmos fix??
Hey - any word on when this release will be made public?
I'm tired of "fake" Dolby Atmos from my Xbox 1 s / x
Article is from Feb-24-2019
https://www.forbes.com/sites/johnarc.../#739a01a97901
Fixing the fix
This approach to saving Xbox users from experiencing drop outs when using Dolby Atmos for Home Theater also meant that the consoles couldn’t apply Atmos upmixing to non Atmos sources - since they were essentially having to treat all audio for output as Atmos, even when it wasn’t.
The latest update rolled out to Xbox users on the Alpha Insider ring, though, means that the Dolby Atmos for Home Theater mode can now properly recognize when a game or disc isn’t delivering a true Atmos source, and apply Dolby’s upmixing algorithms to it.
It's true that AV Receivers often carry similar upmixing options, of course. But getting the Xbox to do it makes glitches in the audio playback much less likely.
The new upmixing feature for home theater setups will be set to ‘on’ by default - and actually, in the current build out with Alpha Insiders, it’s set to ‘on’ permanently. However, Xbox Audio Lead Steven Wilssens tells me that by the time the new feature is ready to roll out to the Xbox community at large, it will contain the option to toggle the upmixing on or off (for people who prefer to hear non-Atmos sources in their original format).
mtbdudex is offline
post #6499 of 6624 Old 04-23-2019, 12:59 PM
Quoted: 733 Post(s)
Liked: 680
I haven't seen that update yet in the Beta ring. Still might be an Alpha ring only at this stage. Not sure how many people in here are on the Alpha ring. I imagine there are a couple.
mtbdudex likes this.
PSN- Arutha_conDoin
Steam- An0mander
-Ghanima Atreides
post #6500 of 6624 Old 04-23-2019, 06:08 PM
thomasphoenix's Avatar
Quoted: 150 Post(s)
Liked: 104
I’m in beta and I’m not sure if the upmixing is active , I’m running 7.2.4, back ceiling 2 speakers and rear surrounds are inactive during normal 5.1 playback. I don’t know why the front ceiling is active though .
TV-Sony Bravia KD-65"A1, Pioneer SC-LX901 7.2.4 ATMOS/DTS-X, Polk DSW 660*2, Polk RTi A7*2, Pol Csi A6, Polk RtiA5*2, Polk Tsi300*2, Polk TSX 220B *2, Polk OWM 3*2, Zappiti-4kHDROne, Oppo UDP-203, XboxOneX, PS4, Oppo BDP-83, Darbee DVP-500s, ZidooX10, Sony Bravia HX925 55"
thomasphoenix is offline
post #6501 of 6624 Old 04-24-2019, 10:41 AM
portudork's Avatar
Can someone confirm to me if the Vudu app via Xbox One X supports outputting supported movies in Dolby Vision? I have a new Sony X950G TV with Dolby Vision support and the option was automatically activated via the Xbox when it detected the TV. My HDMI source is set to receive full signals. When I choose to play a DV supported movie in Vudu it doesn't activate DV. Netflix app works like a dream via the Xbox but nothing else does. I can't get Vudu to output DV via the native app either so I am grasping at straws trying to figure out if this a "not supported" problem or its the TV.
portudork is offline
post #6502 of 6624 Old 04-24-2019, 10:53 AM
Quoted: 78 Post(s)
Liked: 37
Use "uncompressed", bitstream only supports Dolby Digital and DTS.
cathodeRay is online now
post #6503 of 6624 Old 04-24-2019, 03:13 PM
mtbdudex's Avatar
Quoted: 83 Post(s)
Liked: 1479
Total sidebar ...6502 ... that number struck a chord with me ... hmm
Ahhh, my 1983 Engineering class microprocessor logic .... learned to program in machine code via the 8-bit 6502 .. gosh 36 years ago!
camd5pt0 likes this.
mtbdudex is offline
post #6504 of 6624 Old 04-24-2019, 03:18 PM
mutelight's Avatar
Quoted: 2120 Post(s)
Liked: 2391
That is incorrect. They want to use Bitstream for the Blu-ray app as that will pass TrueHD + Atmos as well as DTS-HD MA allowing their AVR to decode those formats. Using uncompressed will result in the Xbox doing the decoding internally and passing it to the AVR via PCM, dropping the Atmos metadata.
Arutha_conDoin likes this.
mutelight is online now
post #6505 of 6624 Old 04-24-2019, 03:21 PM
mutelight's Avatar
Liked: 2391
Currently only the Netflix app on the Xbox supports Dolby Vision and Dolby Vision is always active, even with SDR content. (Netflix's fault.)
Vudu should playback in HDR10 though.
post #6506 of 6624 Old 04-24-2019, 05:03 PM
xplizit's Avatar
Quoted: 70 Post(s)
Alpha Skip-ahead insider here and upmixing has not been added yet. I am looking forward to this. Must have been a delay for some reason. When I use CBS app, which most shows I watch are only in stereo, it only plays in stereo even though I have system settings for Atmos for Home Theater. Will update when that changes.
xplizit is online now
post #6507 of 6624 Old 04-25-2019, 04:04 PM
Quoted: 95 Post(s)
Liked: 34
Deleted
asabrag is offline
post #6508 of 6624 Old 04-25-2019, 04:22 PM
mtbdudex's Avatar
Quoted: 83 Post(s)
Liked: 1479
Truly thx for update
mtbdudex is offline
post #6509 of 6624 Old 04-25-2019, 04:23 PM
macmane's Avatar
Quoted: 1043 Post(s)
Liked: 616
Originally Posted by asabrag View Post
I need a hand:
I cannt get RDR to get the 4K patch. Anyone knows how to check if the patch is installed or better, how to force it to install?
RDR Info:
RDR2 Info:
There's a new rdr2 patch? When did that come out?
Sent from my SM-G975U using Tapatalk
macmane is online now
post #6510 of 6624 Old 04-25-2019, 04:26 PM
Quoted: 95 Post(s)
Liked: 34
No, RDR is the old one!!
macmane likes this.
asabrag is offline
Reply Xbox Area
enhanced , xbox one x
