The Official Xbox One X thread - Page 247 - AVS Forum | Home Theater Discussions And Reviews
 3917Likes
post #7381 of 7412 Old 05-30-2020, 10:12 AM
Spewdom's Avatar
Quoted: 402 Post(s)
Liked: 319
Just use uncompressed 5.1 or bitstream Dolby/DTS. Use an audio codec that utilizes a discrete .1 channel for your subwoofer.
Spewdom is offline
post #7382 of 7412 Old 05-30-2020, 12:36 PM
Quoted: 28 Post(s)
Liked: 2
That’s a great point for the discrete .1 channel. And I would love to take advantage of the higher quality streams if possible. Thanks for pointing that out. I believe the 2.0 pcm is capable of carrying the Dolby bitstream in it correct but not sure how it would handle that .1
TuaDolphin is offline
post #7383 of 7412 Old 05-30-2020, 05:08 PM
UHD Addict
aaronwt's Avatar
Quoted: 10005 Post(s)
Liked: 6666
The subwoofer frequencies are in the 2.0 signal. Which is the norm. Your receiver will take those lower frequencies and route them to the subwoofer.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #7384 of 7412 Old 05-31-2020, 04:11 AM
Spewdom's Avatar
Quoted: 402 Post(s)
Liked: 319
That’️s a great point for the discrete .1 channel. And I would love to take advantage of the higher quality streams if possible. Thanks for pointing that out. I believe the 2.0 pcm is capable of carrying the Dolby bitstream in it correct but not sure how it would handle that .1
Nah, you can tell a huge difference. Just switch back and forth yourself with any game that has low end bass. You'll get some output from the sub in 2.0, but it's not being utilized the same.
Spewdom is offline
post #7385 of 7412 Old 06-22-2020, 10:58 PM
FIVE ONE SIX's Avatar
Originally Posted by FIVE ONE SIX View Post
ok, so i got a new xbox one x about 3 weeks ago and a new Vizio D-Series 65" 4K HDTV about one week ago. for some reason, about one out of every 5 or 6 times i turn on the xbox one x and then switch to the game input on the tv (which is connected to HDMI 1) it doesn't recognize the xbox one x (says there is no signal). then, if i remove the cable and reconnect it, the tv will recognize the xbox one x (which will be on the home screen). this happened a few times with my hdmi cable, so i switched the cable and tried the cable that came with the xbox one x system, and the same thing happened tonight...
i'm just trying to determine if this is an issue with the new xbox one x or an issue with the new Vizio HDTV...
i have the Full UHD Color setting on the tv input set to on, the xbox one x video setting is set to 4K, and the tv input say it's displaying at 2160p when i switch to it when the xbox one x is on...
when i turn on the xbox one x and switch to it, and the tv doesn't recognize it, if i hold down the xbox button on the controller and then hit up and hit the X button, the system will shut off like it would if the tv recognized it...
when i first got the xbox one x and was using it on my old 40" Vizio 1080p tv, i connected my cable box to the xbox one x and used OneGuide and this no signal issue never happened. i don't have it connected like that now on the new 65" tv because the best settings for my cable box and the best settings for playing games are completely different. and i highly doubt the tv will switch them between OneGuide and playing games, unless i manual switch them myself, which sounds a little annoying...
any help on this issue would be greatly appreciated...
don't mean to get in the middle of anyone's threads, but i just wanted to post an update. so i returned the original xbox one x because i thought there was a problem with the hdmi port on the system, because i tried 3 different hdmi cables on the system (the original one that came with the system, and 2 different monoprice 4k hdmi cables)...
couldn't find a new xbox one x anywhere (everyone was out of stock cause parents bought them all up for their kids home from school cause of covid-19) so i got a used xbox one s cheap. i was honestly disappointed because i just got a 4k hdtv and the one x looked much better in 4k, and when stores here (in NY) started reopening i was able to find a Fallout xbox one x bundle new at a somewhat local Gamestop for $299, so i snatched that one up and sold the one s for literally what i paid for it a week later...
to make a long story short, the new one x system does the same thing. i've come to realize it's probably just a handshake issue between the one x 4k settings and the particular Vizio model tv, but i'll deal with it because the tv was dirt cheap and the one x looks much better in 4k than the one s did. unplugging the hdmi cable and plugging it back in on either the system or the tv got kinda annoying, so i noticed after the 2nd time it happened that all i have to do is go to tv settings and just change the UHD Color setting to off then on for that input every time the no signal screen shows up then the one x displays fine. no idea why it only happens once in a while...
thanks for the help everyone...
aaronwt likes this.
Xbox Live: KoNtRoL MaNiAk
FIVE ONE SIX is offline
post #7386 of 7412 Old 06-23-2020, 11:50 PM
Liked: 9
What is the best way to run my direct tv box through the xb 1x or straight to the receiver it seems like the xb makes the sound lounder I don't know i just want the best sound for my set current setup pioneer lx701 xbox 1x
Daddyduke is offline
post #7387 of 7412 Old 06-24-2020, 03:08 AM
Quoted: 348 Post(s)
Liked: 474
i suppose it depends on if you want your xbox to be a media center or not, i.e. if you want to use the guide function in your xbox and not the directv box. that means your xbox will have to be on for watching tv as well.
i tried it that wat and WAF got in the way, so i have had stand alone activities ever since. then again, have had the cord cut for 3 years now....
LG 55C8, Pioneer Elite VSX-LX503, Panamax M5400, Microsoft Xbox One X, Nvidia Shield Pro
Definitive Technology: BP9060 Front left/right/CS9040 center/A90 front Atmos/ProMonitor 800 rear Atmos/SR9040 surround left/right
Rythmik FVX15
MATTHEW PATIENT is offline
post #7388 of 7412 Old 06-24-2020, 05:55 AM
Ario816's Avatar
Quoted: 151 Post(s)
Liked: 43
Quick question. My Sony HW700 surround headphones are dying and won’t hold a charge. Thinking of a new headphone setup.
Do people here like the Dolby Atmos headphone feature? If that works well for movies maybe I’ll just get a good pair of headphones and use that. Otherwise was thinking of the Astro A50’s. This is mostly to be used for movies btw hence my curiosity in Atmos headphones.
Ario816 is offline
post #7389 of 7412 Old 06-24-2020, 08:19 AM
Quoted: 348 Post(s)
Liked: 474
i believe there is either a one time charge or monthly fee to use the atmos headphone ability.
i could be wrong, but if i remember correctly, i had to download the dolby app to enable atmos for the receiver, and i think it said $11.99 or $12.99 to use the headphone option.
Rythmik FVX15
post #7390 of 7412 Old 06-24-2020, 08:27 AM
Ario816's Avatar
Quoted: 151 Post(s)
Liked: 43
I think it’s a one time fee. That being said did you find the atmos headphone experience good? Preferable to any other headphone experience you have?
Ario816 is offline
post #7391 of 7412 Old 06-24-2020, 08:35 AM
Quoted: 348 Post(s)
Liked: 474
i personally did not pay for it because i would rather use my theater system for sound than headphones, but i have friends that use it. some have better headphones than the others, but the consensus was rhey liked it, although one of my friends went out and spent quite a bit of money on a headset. he then said the atmos was much better.
so take that for face value
aaronwt likes this.
Rythmik FVX15
post #7392 of 7412 Old 06-24-2020, 10:34 AM
Liked: 9
Okay thx I just want the best sound for watching TV I guess I have to just compare the too sound wise,The only thing I've notice is that the directv box sounds way louder when hooked up though the xb1,but I don't if it passes the audio out to different channels better than being connected to the receiver thats my only problem what do you think or does it piggy back to what you replied earlier 🤔
post #7393 of 7412 Old 06-24-2020, 03:16 PM
Liked: 2
XBox One X Color Settings, Nits
Should I adjust the One X console brightness settings according to the eye icon in the set up menu or should I just leave it to the settings I normally use on my TV? Also, should I be reducing the nits from the default? Will default brightness cause damage to the pixels?
NateinMpls is offline
post #7394 of 7412 Old 06-24-2020, 03:47 PM
DaverJ's Avatar
Quoted: 2079 Post(s)
Liked: 4270
If your Xbox is on a separate input directly into your C9, you should adjust the C9's SDR levels using the Xbox's eye icon setup settings. There's no option to adjust HDR this way, unlike PS4. Here's hoping MS adds both SDR and HDR setups in the Xbox Series X.
aaronwt likes this.
DaverJ is offline
post #7395 of 7412 Old 06-24-2020, 04:11 PM
Liked: 2
Ok, I actually have the CX but it's basically the same. The Xbox and PS4 are both on separate inputs. As to the nits, I mean on the game options menus there are HDR settings for each game. I was wondering if those should be left at default or dialed back a little.
post #7396 of 7412 Old 06-24-2020, 04:29 PM
DaverJ's Avatar
Liked: 4270
I'm not sure the proper settings for each game's HDR setup, they seem to vary from game to game. Some games have confusing HDR settings, so I just eyeball it so that it looks decent to me.
DaverJ is offline
post #7397 of 7412 Old 06-24-2020, 04:31 PM
Liked: 2
Ok, thanks.
post #7398 of 7412 Old 06-30-2020, 12:03 AM
Quoted: 12 Post(s)
Liked: 2
I have a lg c9 and a nakamichi shockwafe ultra 9.2ch dts. I was wondering do you guys have the Xbox connected via hdmi 2.1 port directly from the TV or do you have it connected to the Nakamichi Soundbar.
If I connect it directly to the TV I get VRR and allm. I also get all the sound as dolby atmos dd plus
If I connect it to the soundbar I get dolby atmos mat but I lose the VRR and allm features.
What do you recommend I do for my setup?
Would the results be the same when the Xbox Series X console is released?
Taker13 is offline
post #7399 of 7412 Old 06-30-2020, 04:40 AM
Jrocker23's Avatar
Quoted: 974 Post(s)
Liked: 975
It depends on what you want honestly.
Your soundbar doesn't support allm & vrr that's why you lose those options when you connect the Xbox through it.
It will be the same for the series x too.
The only way to fix it is wait for a compatible HDMI 2.1 sound bar or a/v receiver which there are not really any right now. I think Dennon has a receiver out now but but sure.
If you want those features now, then you have to connect straight to the tv
Sent from my Pixel 4 XL using Tapatalk
Living Room: LG OLED65C9, AVR Pioneer SC-LX502, Xbox One X, PS4 Pro, Nintendo Switch
Bedrooms: LG OLED65C8, LG OLED55C6, LG Soundbar NB3530A, Xbox One X
LG C6PUA Firmware Link https://www.lg.com/us/support/product/lg-OLED55C6P.AUS
LG C8PUA Firmware Link https://www.lg.com/us/support-produc...5C8PUA#manuals
LG C9PUA/AUA Firmware Link https://www.lg.com/us/support/produc...LED65C9PUA.AUS
Jrocker23 is offline
post #7400 of 7412 Old 06-30-2020, 06:17 AM
mboojigga's Avatar
Quoted: 794 Post(s)
Liked: 1012
The only receivers I have seen announced for HDMI 2.1 is Denon which releases their series in a couple of weeks(15 July) and Yamaha sometime this year.
The 5.0 is here
mboojigga is offline
post #7401 of 7412 Old 06-30-2020, 08:26 AM
avernar's Avatar
Quoted: 1269 Post(s)
Liked: 1547
That soundbar doesn't have eARC nor will Nakamichi be adding eARC to it.
I recommend plugging it into the TV and getting a SHARC https://thenaudio.com/ to change the eARC to regular HDMI audio.
Yes, it will be the same with the Series X, PS5, PC, etc.
avernar is offline
post #7402 of 7412 Old 06-30-2020, 08:49 AM
deveng's Avatar
Quoted: 111 Post(s)
Liked: 147
Rather than starting a new thread:
But can it run Crysis? https://www.microsoft.com/en-us/p/cr...ot:overviewtab
Requirements will be 4 Xbox One X's connected together, but will also need to be kept in the refrigerator to prevent GPU from exploding. (hahaha).
Xbox and PS3 Gamertag = Xerostomia
Wii = I'm too lazy to get the number
deveng is offline
post #7403 of 7412 Old 07-02-2020, 03:31 PM
macmane's Avatar
Quoted: 1400 Post(s)
Liked: 963
Strange thing going on with my x1x and lg cx dolby vision is greyed out now anyone knw how to resolve that?
macmane is online now
post #7404 of 7412 Old 07-02-2020, 04:38 PM
NismoZ's Avatar
Quoted: 151 Post(s)
Liked: 60
Have you done the CX settings to enable the deep color mode on the correct HDMI port? In the X1X, is DV output check marked in the settings?
NismoZ is offline
post #7405 of 7412 Old 07-02-2020, 04:40 PM
macmane's Avatar
Liked: 963
I actually just toggled through the resolution and it switched back to normal thankfully lol thanks though
post #7406 of 7412 Old 07-05-2020, 02:26 PM
yellowcanary73's Avatar
Quoted: 28 Post(s)
Liked: 32
Xbox Controller Joystick
Haven't been around gaming since I lost my arm years ago but grandson 13 is now living with us so I started searching for a new Xbox one x man it was eye opening with this Covid thing going on not one anywhere except for Ebay which I really don't ever use. But found a new sealed Cyberpunk 2077 of course cost me a little more but he has been through some stuff so its worth it. We received it yesterday fully as advertised was supposed to include receipt but she forgot but after 4 hours the left control stick started sticking in the lower right bottom we tried the alcohol and q-tip thing but didn't help.
Question is he just registered everything yesterday if we can't get receipt you think Microsoft will still honor the warranty if not any suggestions to fix this he is a little bummed out but has the one I bought him at Christmas to hold him over.
yellowcanary73 is offline
post #7407 of 7412 Old 07-05-2020, 06:38 PM
Jrocker23's Avatar
Quoted: 974 Post(s)
Liked: 975
You can try downloaded the Xbox accessories app on Xbox and see if the controller needs a firmware update.
If not, go online to xbox.com and put in a service request for the controller. If you already registered the console on xbox.com you don't need the receipt. If you didn't register, then register and then put in the repair request
LG C9, C8, C6 w/Pioneer SC-LX502 AVR, Xbox One X, PS4 Pro & Nintendo Switch
OddyOh likes this.
post #7408 of 7412 Old 07-06-2020, 04:53 AM
Ezra's Avatar
Quoted: 60 Post(s)
Liked: 51
My brother purchased one on ebay and had a problem with it as well. He went to the service web site and entered the serial number of the controller and based on that they repaired / replaced the controller.
aaronwt and OddyOh like this.
Ezra is offline
post #7409 of 7412 Old Yesterday, 08:31 AM
macmane's Avatar
Liked: 963
Does anyone else have raised black levels using the x1x? Particularly on transition scenes or loading screens it seems to have elevated blacks im using oled cx connected directly to the tv and i can't get true black levels at all mk11 rdr2 the division 2 as well all in the hdr game mode pm and every other mode as well. I dont have vrr or anything selected and even when I do select it its the same thing
post #7410 of 7412 Old Yesterday, 08:34 AM
Jrocker23's Avatar
Quoted: 974 Post(s)
Liked: 975
Its a known issue with xbox black levels. Always been an like that. There is no fix at this time
macmane likes this.
Reply Xbox Area
enhanced , xbox one x
