xbox 1X in media closet - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By CURX8
  • 1 Post By newfmp3
  • 1 Post By mutelight
  • 1 Post By newfmp3
post #1 of 14 Old 04-14-2019, 10:37 AM - Thread Starter
Quoted: 48 Post(s)
Liked: 8
Quick question,
Can you place the Xbox 1x in an AV closet and still play? I am setting up a home theater and all the other components will be in an AV closet/room. I was wondering if this works. Or do I need line of sight?
john.odonnell01 is offline
post #2 of 14 Old 04-14-2019, 01:03 PM
Nillaz's Avatar
Quoted: 393 Post(s)
Liked: 223
Originally Posted by john.odonnell01 View Post
Quick question,
No line of sight needed. You will most likely be OK, but may run into issues depending on how far away you are from the Xbox and the construction of the closet.
82Q90R / 75Q9FN / Denon X6400H / Polk Audio LSI 7.1.4 / Nvidia Shield / Panasonic DP-UB820 4K BluRay / Xbox One X / PS4 Pro / Nintendo Switch / Custom Gaming PC / Custom VR PC / HTC Vive Pro HMD (Wireless)
Nillaz is online now
post #3 of 14 Old 04-14-2019, 02:09 PM
kevin g.'s Avatar
Quoted: 387 Post(s)
Liked: 167
Wouldn't the updated controller (bluetooth) work better,now, with improved range? I have not tested in my theater, (my X is in my main viewing area with my 4K TV). I have had terrible luck with the standard XB1 and it's poor implementation of it's own WiFi based controller. Constant drops and loss of communication have plagued me since launch.
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
post #4 of 14 Old 04-15-2019, 11:25 AM - Thread Starter
Quoted: 48 Post(s)
Liked: 8
Just a drywall wall and a wooden door at about 20'. Thank you for the reply
post #5 of 14 Old 04-15-2019, 03:10 PM
CURX8's Avatar
Quoted: 113 Post(s)
Liked: 99
In my experience with my 1X and Elite controller, that is on the fringe of this unit's range. If this were a 360 you wouldn't have an issue but with the One, MS really screwed up with their controller connection protocol.
kevin g. likes this.
Sony 65" 950B | Marantz AV8802a | Marantz MM8077 | Rotel RB-1572
MartinLogan Theos | MartinLogan Motif X | MartinLogan Motion 4 | MartinLogan ElectroMotion IC
Sony PS4 PRO | XBox One X | Oppo 203 | NVidia Shield | Roku Ultra | Pioneer Elite SC-79 | Monoprice 6.5" Alpha In-Ceiling | DefTech AW6500
CURX8 is offline
post #6 of 14 Old 04-15-2019, 06:47 PM
Nillaz's Avatar
Quoted: 393 Post(s)
Liked: 223
I've never had any serious issues with my Elite at 20' as long as I am on the same floor as the xbox but I have noticed that if I try to take my controller upstairs to the kitchen I will lose voice comms, but in this circumstance the signal is now beaming through a wall and the floor (as the crow flies). I agree I wouldn't try to press the issue too much further distance-wise.
post #7 of 14 Old 04-18-2019, 06:32 AM
newfmp3's Avatar
Quoted: 415 Post(s)
Liked: 348
My original Xbox One, launch console had to be in the same room. Pissed me off. All my equipment is in a room directly below my living room. The X I have zero issues. get about 30 feet away, but it drops off quick. I'm probably about 18' in my usual couch distance and I'm fine. Don't forget 4k needs good cables for long distance too. Monoprice certified 4k is what I'm using. My Ps4 Pro has same range. My 360 I could probably walk to my neighbors house. Whatever MS did with the Xbox one Sticks ruined them.
newfmp3 is offline
post #8 of 14 Old 04-27-2019, 04:57 PM
Liked: 0
I've got plenty of range on my OneX, but I'd be a bit concerned if you say you're keeping it in a cabinet. Make sure you've got ventilation, or leave the door open when it's on. That thing pushes heat out!
elwappo99 is offline
post #9 of 14 Old 04-29-2019, 01:19 PM
JonnyVee's Avatar
Quoted: 264 Post(s)
Liked: 162
Mine is in a separate room, but at 10-15' away. Work fine.
Rec Room: JVC x790 w/120" Silver Ticket screen, Denon x4400H 5.1.4 with Kef Q100 L/R, Q200 centre, T101 surrounds, Ci160er rear atmos, Energy Rc-Mini - front atmos, SVS PC-2000. Family Room: LG 65B7P OLED, Denon s730H 5.1 - Kef Q500, Q200c, Energy v-mini - surrounds. Calibration Gear: X-Rite i1Display Pro, Calman Home Enthusiast, trial & error, and a patient wife.
JonnyVee is offline
post #10 of 14 Old 04-30-2019, 09:52 PM
mutelight's Avatar
Quoted: 2132 Post(s)
Liked: 2415
While the new controllers have a BT radio in them, they still connect to the Xbox console itself via their proprietary method.
The BT radio was added to allow connections to PCs with BT radios but they still connect in the traditional sense.
mutelight is offline
post #11 of 14 Old 05-03-2019, 12:03 PM
mcrommert's Avatar
The new controllers have just slightly longer range, but not due to bluetooth. Xbox One still does not use bluetooth to connect controller to console no matter which version you have. They instead use their own superior wifi direct connectivity tech. The bluetooth has been added for easier connection to pcs or mobile phones.
mcrommert is offline
post #12 of 14 Old 05-04-2019, 08:19 AM
kevin g.'s Avatar
Quoted: 387 Post(s)
Liked: 167
"superior" is laughable. Longer range as compared to what?
I have had a ridiculous number of drop outs this generation.
Now, I do have one of the new controllers in my theater since just upgrading to the X in my upstairs setup...(my son had just received one of the custom-built controllers for Christmas). I stole the included "X" controller for myself, and haven't played enough to know if it is any better than my original.
kevin g. is offline
post #13 of 14 Old 05-10-2019, 04:51 AM
newfmp3's Avatar
Quoted: 415 Post(s)
Liked: 348
No way they have a longer range. They changed them not due to range, but LAG. They wanted lower lag. That was at the cost of distance. I can literally walk more than twice the distance away with my 360 controller.
newfmp3 is offline
post #14 of 14 Old 05-23-2019, 09:22 PM
Liked: 7
Really wish there was a way to extend the controllers....
Jetski6 is offline
Reply Xbox Area
