The Surge - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-27-2019, 11:33 AM - Thread Starter
Arutha_conDoin's Avatar
Quoted: 748 Post(s)
Liked: 694
The Surge
Has anyone played this on the Xbox X? I picked this up on the Gamepass today and gave it a spin. The game while not bad has a video bug where it acts like it is trying to go into screen saver mode. So every 30-45 seconds the screen darkens (dark grey) then goes back to normal. I have tried both Quality and performance settings on the game and both do it. No other issues with any games, so I fairly certain it is specific to this game. Though googling for this gives me nothing as well.
Xbox Live: DaBeavers
PSN- Arutha_conDoin
Steam- An0mander
"Too much knowledge never makes for simple decisions."
-Ghanima Atreides
Arutha_conDoin is offline
post #2 of 5 Old 05-27-2019, 02:25 PM
HeadRusch's Avatar
Quoted: 233 Post(s)
Liked: 169
haven't experienced this, which mode are you playing? Surge gives you two options, 30fps with extra processing at 4K I think, or 1080p at 60fps.......
Xbox Live / PS3 / Steam: HeadRusch1
Keeping the world safe from the evil antics of Bernie Tanaka and Mel Fujitsu since 1986
HeadRusch is offline
post #3 of 5 Old 05-27-2019, 02:39 PM - Thread Starter
Quoted: 748 Post(s)
Liked: 694
I played both and it did it. Just started a movie on Netflix and it did the same thing. So it's not the game after all. Tried a gated reboot and no luck either. Look looked I had an update last night and I'm wondering if that screwed something up.
Sent from my SM-G965U using Tapatalk
PSN- Arutha_conDoin
Steam- An0mander
-Ghanima Atreides
post #4 of 5 Old 05-31-2019, 03:55 PM
HeadRusch's Avatar
Quoted: 233 Post(s)
Liked: 169
Cheapest "maybe it's this" try would be a new HDMI cable run, and use only one (assuming you're pushing 4K) that is just long enough to get the job done.......good luck.
post #5 of 5 Old 05-31-2019, 06:13 PM - Thread Starter
Quoted: 748 Post(s)
Liked: 694
I don't think it's the cable or receiver. I have no issues with the PS4. Hell, I just replaced the cable a few months ago for a different issue. I'm fairly certain the next update will fix it.
PSN- Arutha_conDoin
Steam- An0mander
-Ghanima Atreides
Reply Xbox Area
