Xbox 1 turns on and then off. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-20-2019, 05:35 PM - Thread Starter
Kensmith48's Avatar
Quoted: 124 Post(s)
Liked: 34
The xbox 1 console will turn on ok but then after 10 seconds turns itself off. The power brick light is white when on and orange when off, so I don't think the power supply is the problem. I read somewhere that pressing the on button repeatedly would fix it. It doesn't.
Thanks for any help
Ken
Kensmith48 is offline
post #2 of 6 Old 09-26-2019, 09:16 AM
mboojigga's Avatar
Quoted: 697 Post(s)
Liked: 930
Could have received a power surge
The 5.0 is here
mboojigga is offline
post #3 of 6 Old 09-26-2019, 10:24 PM
Liked: 1
Try plugging it into a different outlet. If that doesn't work, try getting a whole new power supply (I've seen them go bad).
MileHighAutomation is offline
post #4 of 6 Old 09-27-2019, 06:02 AM
moej's Avatar
Quoted: 18 Post(s)
Mine did the same thing, but I after it shut down, I could start it back up. I replaced the power supply brick and it was fine.
If you want, you can try taking it apart and cleaning out the dust.
IFIXIT is a good website that shows you step by step how to take it apart. The hardest part is taking out the rubber feet. You need an awl or a small eye glasses screw driver to poke the center and pry them out.
Panasonic 50" Plasma 3D Smart TV
HTPC/Gaming PC (i7 860, SSD, GTX 660 Ti+), Xbox One, Xbox 360, Wii-U, Wii, N64, NES
Nokia Lumia 928 W10M
moej is offline
post #5 of 6 Old 09-29-2019, 07:07 AM - Thread Starter
Kensmith48's Avatar
Quoted: 124 Post(s)
Liked: 34
Thanks for the replies. I ordered a new power brick today.
post #6 of 6 Old 10-09-2019, 09:44 AM - Thread Starter
Kensmith48's Avatar
Quoted: 124 Post(s)
Liked: 34
Update: Got the new power brick and tried it out. The same thing happened. Turns on and shuts off after 10 seconds. Returned the power brick.
Reply Xbox Area
