Single in/on-ear headset for PS4? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-06-2016, 05:38 PM - Thread Starter
Ketnis's Avatar
Quoted: 173 Post(s)
Liked: 88
I bought a bluetooth headset only to discover that the PS4 basically has no support for them. Does anybody have a suggestion for a single in or on-ear solution that also allows me to hear my HT? All the headsets I can find are apparently meant to be used as headphones as well. The earbud headset that came with my PS4 failed long ago.
Ketnis is offline
post #2 of 4 Old 04-07-2016, 06:44 AM
SeldomSeen31's Avatar
Quoted: 23 Post(s)
Liked: 35
I use the Sony silver headset. Plugs in to the controller, has a single ear speaker a headband and a mic boom. Cheap and works nicely to be able to hear ge audio via home theater system.
Sent from my XT1585 using Tapatalk
PSN ID: Seldom_Seen
SeldomSeen31 is offline
post #3 of 4 Old 04-07-2016, 07:47 AM
Quoted: 175 Post(s)
Liked: 193
Turtle Beach Ear Force P4C- I have this set, uses the 3.5mm jack in the controller. I'm in the same boat as you and like my speakers way more than headphones.
Tritton Kaiken Mono- Here's another.
Crash44 is offline
post #4 of 4 Old 04-17-2016, 08:32 AM
Spike Forehand's Avatar
I use one of these:
http://www.amazon.com/TRITTON-Kaiken...ilpage_o01_s00
The ear pad is vented to allow surround sound in, and can vouch that it works great. Also very comfortable, has good voice quality, and doesn't transmit a lot of noise from my end to teammates.
Plugs into the PS4 controller so you don't need to worry about charging or anything.
"Blow, ye wind, like the trumpet blows. But without that noise."
Spike Forehand is offline
Reply PlayStation Area
