Is the PS5 APU a chiplet design? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-21-2019, 10:44 AM - Thread Starter
jeff_rigby's Avatar
Quoted: 59 Post(s)
Liked: 43
In support of this a paper on 7nm and smaller nodes has these points.
1) Clock speeds are not going to increase or will marginally increase with smaller nodes.
2) 7nm and smaller nodes can not support traditional IO currents at higher clocks without special treatment, GDDR6 alleviates this somewhat...HBM even more so.
3) TSMC states the 3nm node will be low power for the above reasons.
4) Since it supports 8K video and likely will need to support at least 4K @ 120FPS for VR which is 2K/eye, it has a HDMI 2.1 port which means something less or equal to 48 Gbs (6 GB/sec)data rates.
5) Given the Cerny statement that the game load times are 15 times the PS4 Pro with SSD drive we have a significant increase in IO speeds. The PS4 pro with a SSD drive maxes out at 510 MB/s and 15 times that is 7.650 GB/sec. The PS4 and Pro IO speeds are limited by the ARM southbridge. While it's likely the PS5 GDDR6 memory will have a ARM trustzone processor for trusted boot and encrypted memory (AMD Secure VM), the IO drivers for memory will not be low power ARM designs.
Speculation is the PS5 chip supports a maximum 3 Ghz CPU clock and 1.8 Ghz GPU clock, compare that to a PS4 Pro 2.13 Ghz CPU clock and 911 Ghz GPU clock. Digital foundry speculates, given various GCN CU counts, that results between 8 and 12 TF. Also in the Adored TV video above, the midrange Navi dGPUs have 8GB GDDR6. I suspect this means the PS5 will have 8GB but before you go off the deep end, Cerny showed how the SSD drive in the PS5 solves some of the small (8GB memory) issues.
it's possible it needs a separate IO chip @ 14nm.
jeff_rigby is offline
post #2 of 4 Old 04-21-2019, 11:24 AM
Dr.Shankenstein's Avatar
Quoted: 739 Post(s)
Liked: 662
Originally Posted by jeff_rigby View Post
Is the PS5 APU a chiplet design? Adored TV speculates on the Navi GPU as a chiplet design.
It will have to be a minimum 10ish Tflops. I know Tflops aren't the be all end all measure of hardware performance, but Google Stadia on paper offers 10.7 tflops on a best case scenario high speed connection.
Sent from my LG-G710 using Tapatalk
Dr.Shankenstein is offline
post #3 of 4 Old 04-22-2019, 04:57 AM - Thread Starter
jeff_rigby's Avatar
Quoted: 59 Post(s)
Liked: 43
I assume you feel the PS5 has to compete with Stadia, don't forget the SSD drive to compete with instant Game Load times for Stadia.
I've speculated that Stadia will also support VR360 and other VR/3D media. To support local VR360, you need most of the video in very fast local memory.
post #4 of 4 Old 04-22-2019, 05:12 AM
Quoted: 739 Post(s)
Liked: 662
It doesn't have to compete, but if it launches the weaker of the 3 platforms it could have an affect on fan perception.
Reply PlayStation Area
