Streaming Amazon with PS3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By taichi4
post #1 of 5 Old 09-01-2019, 08:29 AM - Thread Starter
taichi4's Avatar
Quoted: 535 Post(s)
Liked: 318
The PS3 does an okay job streaming Amazon video except for fast forwarding and reverse. I have no idea how to accomplish that. Controller buttons bring up the reverse forward play bar at the bottom of the screen, and I can highlight the reverse, play, pause, and forward buttons, but then I'm completely at a loss. Hitting X doesn't seem to do much of anything.
Can anyone help me with this?
taichi4 is offline
post #2 of 5 Old 09-01-2019, 05:38 PM
Mikazaru's Avatar
Quoted: 254 Post(s)
Liked: 380
Hitting X works for me.
Mikazaru is offline
post #3 of 5 Old 09-01-2019, 06:16 PM - Thread Starter
taichi4's Avatar
Quoted: 535 Post(s)
Liked: 318
Thanks for the response. So you highlight the forwards or backwards arrow and then hit X? Is there a progress bar to see how far you are advancing or rewinding? do you hold the X button down, or simply click on it?
taichi4 is offline
post #4 of 5 Old 09-02-2019, 04:38 PM
Mikazaru's Avatar
Quoted: 254 Post(s)
Liked: 380
Yes, you highlight (yellow) FF or Rewind and press X on the controller. You just click on it once. If you click on it a second time, the FF/rewind rate increases. If you click on it a third time, the rate increases greatly. There is a small window that opens up showing you the progress.
Mikazaru is offline
post #5 of 5 Old 09-03-2019, 08:03 AM - Thread Starter
taichi4's Avatar
Quoted: 535 Post(s)
Liked: 318
Yes, I got it. Thanks for your replies. Actually, it works pretty well if you're light on a touch.
Mikazaru likes this.
taichi4 is offline
Reply PlayStation Area
