WiiU dual sensor bar help needed... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-08-2016, 06:21 PM - Thread Starter
Liked: 0
Hope someone can help me. I just installed a WiiU in a loft bedroom, the center of the room there is a column.There are 2 identical TVs installed 180 degrees apart on the column. Each TV faces 2 single kids beds.
How can I install 2 sensor bars so that each TV has a sensor bar to be used with the WiiU?
loudell is offline
post #2 of 7 Old 08-09-2016, 10:49 AM
JoshuaL's Avatar
Quoted: 27 Post(s)
Liked: 31
There is an existing thread about this, I believe. Try searching the forums.
JoshuaL is offline
post #3 of 7 Old 08-09-2016, 11:09 AM
JoshuaL's Avatar
Quoted: 27 Post(s)
Liked: 31
The existing thread (which is here) was more for 1 large screen than 2 smaller screens. I'd recommend just buying 2 wireless sensor bars (battery powered) for your circumstances - much simpler.
JoshuaL is offline
post #4 of 7 Old 08-09-2016, 07:22 PM - Thread Starter
Liked: 0
Because it's for smaller kids I would love for simplicity sake to have 2 sensor bars that will turn on when the console turns on. Rather than turning on the console and then turning on 2 separate sensor bars. I wonder if it is just as easy as splicing a sensor bar cable to another sensor bar cable which plugs into the WiiU console?
loudell is offline
post #5 of 7 Old 08-09-2016, 08:51 PM
JoshuaL's Avatar
Quoted: 27 Post(s)
Liked: 31
If you'd rather try connecting two sensor bars together I'd recommend reading through the thread I referenced in my previous post. It's not simple, but I've done it and it works.
JoshuaL is offline
post #6 of 7 Old 08-10-2016, 07:57 PM - Thread Starter
Liked: 0
I think I found the thread. Is this it?
Multiple Wii Sensor Bar Hack for Projector/TV Combos-AVS Forum...
Sorry, it's not a hyperlink cause I don't have 5 posts yet...
loudell is offline
post #7 of 7 Old 08-10-2016, 08:18 PM
JoshuaL's Avatar
Quoted: 27 Post(s)
Liked: 31
The link was in my previous post (#3 above) hyperlinked to the word 'here' in the phrase "which is here".
I don't know what info the other thread contains.
JoshuaL is offline
Reply Nintendo
