hdmi dongle or dock for alternative docking solution.\ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-19-2017, 08:25 AM - Thread Starter
david8613's Avatar
Quoted: 318 Post(s)
Liked: 67
what do you guys think, simple hdmi dongle or dock for alternative docking solution. trying to figure our what is better and why?
david8613 is offline
post #2 of 4 Old 12-19-2017, 11:29 AM
jhoff80's Avatar
Quoted: 402 Post(s)
Liked: 370
So Nintendo attempts to lock you out from using non-official docks. However, there's quite a few Chinese docks on the market that skirt around that by imitating the Nintendo device ID.
So for best results, you'll want to use the official Nintendo dock. I personally bought an extra of those, and put the guts into a smaller 3D printed plastic shell:
https://www.myminifactory.com/object...-station-32264
That being said, I've got one of these no-name Chinese docks in my daily bag also:
https://www.amazon.com/gp/product/B074P5F7NY/
It seems to work well, and also supports DeX mode on my Galaxy Note. Plus I like how the cable sort of seats in place.
There is also the Nyko portable dock kit, but I've read stories about the power adapter included with that portable dock kit frying people's Switch ports.
One thing to note is that the docks do not work unless powered by a 45W USB-PD adapter. I use the official Google Pixelbook one, since there's a ton of poorly made USB-C chargers that can damage devices.
https://store.google.com/product/45w..._power_adapter
XBL/Steam: JHoff80
jhoff80 is offline
post #3 of 4 Old 01-30-2018, 07:04 AM
EM3
EM3's Avatar
Quoted: 140 Post(s)
Liked: 67
EM3 is offline
post #4 of 4 Old 01-31-2018, 01:12 PM
jhoff80's Avatar
Quoted: 402 Post(s)
Liked: 370
It's a little bit amusing to me that that FastSnail adapter says:
DISSIPATE HEAT - The heat dissipation of Nintendo Switch Dock is not so good and it makes the console hot. But use our HDMI adapter, you will never worry about this problem.
...when in order to use it, you place the Switch on its back which then blocks intake vents. Whereas if you use the official dock there's a small gap between the Switch and the dock so it can still pull air in.
XBL/Steam: JHoff80
jhoff80 is offline
Reply Nintendo
