Using AV receiver to switch HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-24-2018, 08:56 AM - Thread Starter
Liked: 0
I am not sure if this is the correct forum.
I have a
Yamaha RX-V677
Mitsubishi WD-92840 92" 1080P
I am using the Receiver to switch the following items
xfinity cable box
firestick
PS3
Xbox
This all seems to work fine.
I tried to hookup the Wii using the Wii2HDMI adapter.
When I switch it through the receiver it pushes the image to the right. I hooked it directly to the TV and it doesn't push the image to the right. I switched up the cables and port that is used for the PS3 and it still has this issue.
I feel like I have ruled out the cables and a bad port on the receiver.
I have not run a firmware update on the receiver because I have heard horror stories. I can do that if it may help but everything else seems to switch fine.
I understand this converter is cheap and comes from Hong Kong but it does work when not switched through the receiver.
Any help is greatly appreciated.
Bill
s4bill is offline
post #2 of 6 Old 04-24-2018, 01:21 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 519 Post(s)
Liked: 376
If you got the WiiStar model, it (apparently) requires a direct connection, and can’t be used through a switch or receiver:
https://nerdtechy.com/guide-best-wii-hdmi-converter
Sent from my iPhone using Tapatalk Pro
giomania is offline
post #3 of 6 Old 04-24-2018, 02:43 PM
JoshuaL's Avatar
Quoted: 27 Post(s)
Liked: 31
Maybe I misread that link you posted, but it seems to indicate that the KCOOL adapter is the one that must be used directly. I didn't see anything about Wiistar needing that. Maybe the OP has a defective one?
JoshuaL is online now
post #4 of 6 Old 04-24-2018, 06:23 PM
Quoted: 115 Post(s)
Liked: 35
How far to the right? Like, halfway off the screen or just a little bit? Most consoles have an adjustment to center the image, but it will only work if it's just a little off. Honestly, I can't understand why a direct connection would be any different than plugging into a receiver. Maybe make sure your video processing is off (pass through), or if it's off, try and turn it on?
James Babin - System designer myEasytek
Last Post: Low Voltage Wiring Guide
JT Babin is offline
post #5 of 6 Old 04-25-2018, 05:20 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 519 Post(s)
Liked: 376
Thanks. I probably I read it too fast.
giomania is offline
post #6 of 6 Old 04-25-2018, 10:47 AM - Thread Starter
Liked: 0
Its about a 1/5 or 1/6th of the screen. Its more than the adjustment can fix.
I bought the adapter from ebay. It only took several weeks to get here. lol
s4bill is offline
Reply Nintendo
