AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Nintendo (https://www.avsforum.com/forum/144-nintendo/)
-   -   Wii causing interference on wireless laptop connection- should I call Nintendo? (https://www.avsforum.com/forum/144-nintendo/781531-wii-causing-interference-wireless-laptop-connection-should-i-call-nintendo.html)
colossus 01-05-2007 01:24 PM
Noticed an odd issue last night. Let me preface this by saying I'm kinda green at setting up wireless- but learning fast.
My wife's Dell laptop would connect to my wireless SMC router and, though showing a solid connection, would not get access out to the 'net. During this time, we got a Wii for my son. First time I connected, it found the router, did it's first update, no problems.
Since that time, the weather channel intermittently doesn't get a connection, and the internet channel never EVER works (is that operational yet?). I tried channels 6,1, and 11 for broadcast.
I'm using MAC filtering, when the Wii works, it works with it on or off. WPA/TKIP, b+g.
The laptop hanging was resolved by defeating the MS 'wireless zero' configuration in the services menu, installing the Intel software to run the connection, and using that to control the wireless connection. Problem with intermittent 'hangs' was resolved. In addition, the bandwidth was improved.
OK, so last night she said that she couldn't connect. I fired the laptop up and sure enough, it wasn't connecting. As I watched the 'connecting' window on the laptop, I unplugged the Wii. The laptop connected immediately. I cannot leave the Wii plugged in while using the laptop.
Should this be happening?
ajwillys 01-05-2007 01:40 PM
No that should not be happening.
Just off the top of my head it sounds like an issue where the laptop is looking for a specific IP address (from your router) and the router has already given that address to the Wii. One way to test is to connect the laptop, then the Wii. If that works, then that might be the issue.
If that is the issue, you need to set your laptop to 'discover' it's IP address automatically using DHCP. I don't know how to do this on the intel software you are using but the gist is that no IP address or DNS server should be configured and it set to discover automatically.
Here are instructions for Windows XP:
http://www.more.net/technical/win/dhcp.html#xp
If that's not it, it could be anything.
Jiffylush 01-05-2007 02:30 PM
Bluetooth can interfere with wireless, and shared wireless connections would result in a lower speed. But it should still work, you might want to try a different 'channel' on your router/access point.
I can't think of anyway for Nintendo to fix this, but you could call them for the hell of it.
zbose 01-05-2007 02:55 PM
I had a somewhat similar issue. My laptops (3 of them) all connected fine wirelessly as they have been for years. When I got the wii, it connected, did an update, then proceeded to be VERY unreliable for the next month. In fact, the internet portion of it has been nearly unusable, working for a few minutes, then stopping.
Last night my friend came by and mentioned that some people were having similar issues and that changing their wifi router to channel 1 or 11 (instead of 6) fixed the problem. I made the change and sure enough, it started working perfectly.
Give it a shot. Supposedly 1 and 11 are the only "real" channels for 802.11 and the rest of the channels in between are just spread across the two. Maybe having a "stronger" signal on one channel overcomes interference from the wii's bluetooth? I don't know, just wildly speculating.
-zb
Gigabit256 01-05-2007 03:50 PM
Actually 802.11 has three "real" channels, they are 1, 6, and 11. The numbers are only representative of the center frequencies. They're "fat" so they occupy several "channel numbers". Two channel numbers with a difference of less than 5 will overlap each other.
bdoyledimou 01-05-2007 05:10 PM
I have this same issue... i thought it was the WPA encryption (as my pc kept asking for me to reenter it) but if its the channel.. i will have to test that..
colossus 01-05-2007 06:20 PM
Thanks for all the pointers. DHCP or no, I can't get this thing to coexist w/the laptop.
Changing the channel didn't help. On a random connection, I got the web browser to actually work but the transfer rate was horrifically slow for a 350KBPS DSL. The laptop is much quicker, if that matters.
Still no luck- I've tried everything. Manual configurations, etc. It always causes the laptop to drop.
It seems though, one thing might be something I can't fix.
The Wii manual says that the IP assigned to the Wii needs to be 'ten' apart from anything else. I cannot set increments to IP addresses on my router (SMC 2804WBRPG) so I don't know if something as stupid as this '10' increment is the cause. The router simply adds one to the IP for the next incoming connection.
The frustrating thing is knowing the hardware works and it's simple configuration.
Any last thoughts? To be honest, I'd rather waste the money on an ethernet USB for the Wii than another f'ing router.
cantseetheclock1 01-05-2007 11:21 PM
There are so many things that could be wrong, it's like shooting rabbits with your eyes closed...
Anyway, have you tried checking to make sure that you don't have a limit set on the number of connecting devices to be 1? If you were ultra-secureanoid when you set up your wireless router, you might have thought "I only want my wife's laptop to use this"...
I didn't find the "ten apart" advice, so I can't comment on it other than it seems awfully weird--sorta like the advice we expect to get from a sys admin that's worried about job security (so he keeps everything broken!).
Finally, you could always check for firmware updates for your router (they don't always get it right the first time either...).
colossus 01-06-2007 03:24 AM
I hear ya...this is a PIA!
Firmware was updated before I got the Wii. No limits on number of connecting devices; and turning off MAC filtering doesn't make a difference either.
Thanks again for all the help.
Vr.Rice 01-06-2007 03:45 AM
Are you useing ICS?That can cause a problem.Switch to another Port on your lap top.Sounds like the Wii and your laptop are on the same port.Most of the time its 80 or 8080.Or you might have to give the laptop another ip.I bet its just needs to switch to a differnt port.Use you internet browser to change settings in your router.You can try typeing in the gateway+port address in File\\Inernet Options\\Connections\\Lan settings with IE.Do you have your internet connected to your router?What router do you have?If you are useing a proxie it 1080 for socks.
ajstan99 01-06-2007 05:21 AM
Couple of questions/ideas:
Can you go into the router management software and confirm that your Laptop and Wii have different IP addresses assigned?
Can other wireless devices simultaneously connect with no problem?
In the LAN IP Setup (or whatever it's called on your router) make sure you have "Use Router as DHCP Server" turned on and have set a sufficient IP address range (mine is 192.168.0.2 - 192.168.0.51).
As far as the "ten-apart" issue, for me, the Wii is using 192.168.0.8 which was the next available IP address assigned by the router.
colossus 01-06-2007 10:22 AM
Yeah, different IPs. Not certain about other wireless; all I've got is my wife's laptop and the Wii. I'll look into that. DHCP is on. The range of available IPs is 192.168.2.100 to 192.168.2.220.
My lease time is 'forever'- maybe I oughta change that?
cantseetheclock1 01-06-2007 12:57 PM
How about...
- Changing to to broadcast only in b, not b+g. The wii only does b. Things should work in mixed mode, but who knows?
- Change the network range to 192.168.1.xxx, not 2.xxx. I know, it's like the "ten apart" thing, but all the examples I've seen for the 192.168 private network use 1.xxx.
- Randomly change things until it works
- Put the question here on
http://forums.nintendo.com/nintendo/...rd.id=internet
or on one of the other related forums...
ajstan99 01-06-2007 05:56 PM
You can try to release and renew your lease for your laptop.
1. Make sure that the Wii is connected and running. Go to a command prompt in Windows on your laptop:
Click Start > Run then type in "cmd" (no quotes) and click "OK"
2. Type "ipconfig /release" (no quotes - leave a space between the "g" and the "/")
3. Type "ipconfig /renew" (no quotes - leave a space between the "g" and the "/")
colossus 01-07-2007 04:25 AM
How about...
I thought the Wii needed mixed mode.
I'll run the router in mixed, the laptop on 'g', and the Wii will stay on 'b'.
I'll let ya know how that works.
colossus 01-09-2007 04:01 AM
No luck.
Before I call Nintendo, I'll try one last thing. An 18dBi panel antenna.
If I've still got connection issues then, it'll be something else to blame.
colossus 01-16-2007 07:11 PM
The laptop is set to 'g', the Wii uses 'b', the router is set to 'b+g'
OK, getting a very solid signal by the Wii with the 18dBi antenna...the Wii is not staying connected.
It'll get connected to the router when first doing the test (setting up Wireless connection) and it disconnects shortly thereafter.
Sounds to me like the problem is the Wii itself.
Anybody else observe this happening?
DruKenjutsu 02-17-2016 04:08 PM
. . . and 9 years later, the issue is still there.
I'm having similar symptoms with a wii and a Linksys AC 1200 (EA6350) dual band, 30Mbps hooked to it. Wii is not connected to my network. And like before, every time the wii goes on and bluetooth connection between the remote and the sensor bar initiates, wi-fi signal gets distorted and either disconnects all 4 computers in my house (on channels 1 through 10), or leaves devices connected but the speed starts going up and down between 1.5 and 15Mbps (on channel 11).
If I set it to use only a 20MHz width, it's going up and down between 0 and 1.5Mbps, and if I leave it at Auto, router uses two channels (?) 11+7, and remains between 1.5 and 15 despite having more overlapping, but still crazy unstable.
I know it's been 9 years since the last post but maybe someone knows about a solution by now.
DruKenjutsu 02-18-2016 06:37 PM
It won't let me edit the post, so here's an update.
After 2 days spent on trying all possible setting changes on the router, and 2 hours spent on the phone with Linksys technical support, nobody could lay a finger on what causes the problem, ending up with the same assumption—somehow wii's bluetooth messes up wi-fi signal and the only suggestion I got was to move the router elsewhere in the house, away from the wii. I ended up pulling my cable coax in the basement to reach a spot where I could move the modem+router+cordless landline phone base. Now the wi-fi signal is stable and full-strength, only getting distorted for a moment when the wii goes on, then back to normal.
Looks like there is no solution to the problem other than that.
mboojigga 02-23-2016 02:11 PM
Well Bluetooth is a wireless signal. I haven't read all of the post but have you changed the channel in your router settings. Also have you used something like Airport Utility that can see other wireless networks I. Your area that use the same channel so you can use a separate channel from those?
DruKenjutsu 02-24-2016 10:20 AM
I used a program called inSSIDer to monitor channel traffic with other networks in my area as well as my wi-fi signal behavior on broad and 20MHz band width on all channels, to no avail. At first, channel 11 was the only one working, the signal regained stability and full strength and speed. After 30min the problem was back, not disconnecting wi-fi entirely, only cutting the speed and making the signal very unstable, so every 3 seconds pages won't load and ping would skyrocket.
After that, Linksys tech support had no idea what else to do but try to move the router further away and see what happens. I moved the modem-router setup to the basement, almost directly below the previous spot and the signal was back to normal. After an hour it went jumping again, so I switched channel selection in router settings to Auto, and since then the signal had no problems, for a few days now. When the Wii is on, it's slightly less than flat-even on the signal stability graph under speed test websites, but it can't be felt.
I also noticed, while trying different channel settings, that whenever I switch the band width to 20MHz, it cuts the speed in a half, regardless of the channel. But when I leave it as Auto, and under inSSIDer it shows my network operating on two channels (?), for ex. 11+7, the speed is back to max. Not sure why that is, I'm sure someone experienced would know.
DruKenjutsu 07-24-2017 05:22 PM
UPDATE: After a year and a half, I was still experiencing major wi-fi signal interruptions from the Wii's bluetooth, as well as a loss of almost 50% throughput. At some point it has gotten worse and there was no actual solution to the problem, until I realized what I should have done long ago: I tossed my router and reconnected my entire house and its 6 computers with Cat6 Ethernet cable and finally solved the actual problem instead of picking my compromises. Now I enjoy full internet speed, freedom from any outside signal interferences, and improved security since my network is now hidden and not listed under wireless networks in the area.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
