For gaming, how big a difference is there between DDR3 and DDR4? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-13-2016, 01:47 PM - Thread Starter
Ketnis's Avatar
Quoted: 173 Post(s)
Liked: 88
It's been nearly 10 years since I last built a gaming PC, but I figured now is a good time to dive back in and put together a gaming and VR-capable machine. I've decided on everything but the CPU and motherboard. The AMD FX-8350 looks like a great deal but I'm not sure how future proof it's going to be. As for Intel's new Skylake, the best my budget will allow is the i5 6500 or 6600. For my purposes I assume the 8350 and i5 would be about equal so it comes down to is memory performance. I know DDR4 has greater bandwidth and DDR3 generally has faster timings/lower latency, but what about real world performance? Is there a performance gap and if so, how large?
Ketnis is offline
post #2 of 5 Old 06-13-2016, 02:18 PM
Budracin8's Avatar
Quoted: 134 Post(s)
Liked: 115
Linus' opinion.
Steam ID: Budracin88
Origin ID: Budracin88
Blizzard: Budracin88#1797
YouTube Channel
Twitch
Budracin8 is offline
post #3 of 5 Old 06-13-2016, 02:30 PM
Liked: 1
The difference between DDR3 and DDR4 is negligible when it comes to actual real world performance in gaming. I'd recommend the i5 because it performs better than the 8350 when it comes to gaming, this is because games generally use 2-4 cores and the i5 has much better per core performance. The i5 also consumes much less power and has integrated graphics if ever you have a problem with your graphics card. If you are planning to build a VR-ready system it'd be wise to wait for the full new graphics card lineups from AMD and Nvidia.
skyless_xx is offline
post #4 of 5 Old 06-13-2016, 02:35 PM - Thread Starter
Ketnis's Avatar
Quoted: 173 Post(s)
Liked: 88
That's my plan, though some of the sales on 390s has been tempting.
Thanks for the help.
Ketnis is offline
post #5 of 5 Old 06-13-2016, 05:43 PM
Yrd
Yrd's Avatar
Quoted: 769 Post(s)
Liked: 521
Don't confuse the lower numbers in timing for faster speeds like I did. I would see speeds like 9 9 vs 13 13 and thought, of course the 9s are faster. But I did a Google of timings and that's not the case anymore. I can't remember what I searched and what I found, but it made me realize I had been buying the wrong ram for a while. I just did a search and found something on crucial's site that explains a bit.
http://www.crucial.com/usa/en/memory...-speed-latency
Yrd is offline
Reply HTPC Gaming
