Why the gap between 32 and 43 inch monitors? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-14-2020, 03:54 AM - Thread Starter
jake51's Avatar
Quoted: 364 Post(s)
Liked: 116
The gap is huge if you want a monitor with the 16:9 aspect ratio
I have an great ultrawide 35 inch monitor but it doesn't support HDR
Why is there no 16:9 monitor in, say, 37 inches? 32 inches is too small where you're used to 35 inches ultrawide
43 inches is too big for normal desktop use (internet browsing)
jake51 is offline
post #2 of 8 Old 05-22-2020, 04:01 AM - Thread Starter
jake51's Avatar
Quoted: 364 Post(s)
Liked: 116
So I got the Philips 436M6 today
Coming from an ultrawide monitor there's a VERY long way to the upper corners
HDR doesn't seem to do much, very real possibility that I'm doing it wrong
I'll try stuff tonight
I have been playing Ghost Recon Breakpoint as it supports HDR
Adaptive sync (Freesync) should work with my RTX 2070 S but it doesn't (maybe I forgot to tick a box somewhere)
I'll spend a week with it and decide then whether to keep it
It's HUGE
If I do decide to keep it I'll wall mount it to get needed extra space
jake51 is offline
post #3 of 8 Old 05-22-2020, 12:09 PM
Quoted: 162 Post(s)
Liked: 217
For numerous games, you have to first enable HDR in the desktop environment before you can enable it in-game. As such, in Windows, go to Settings -> System -> Display and you should see an option to enable HDR under Windows HD Color. Do not use the desktop environment as an indicator as to how HDR should look, unless you are running actual HDR content.
NewAger is offline
post #4 of 8 Old 05-22-2020, 10:22 PM - Thread Starter
jake51's Avatar
Quoted: 364 Post(s)
Liked: 116
Yeah, I tried turning it on and off as one of the first things
Now I just leave it on
Freesync seems to be working, there's no tearing
jake51 is offline
post #5 of 8 Old 05-23-2020, 01:00 AM - Thread Starter
jake51's Avatar
Quoted: 364 Post(s)
Liked: 116
This morning the game looked very pale
When I exited the game and turned off the PC and the monitor yesterday, apparently HDR was disabled everywhere
So I had to turn it on again in the game, in Windows and on the monitor
This could get old very fast
What am I doing wrong?
This is my first monitor with HDR
jake51 is offline
post #6 of 8 Old 05-23-2020, 07:00 AM
Quoted: 162 Post(s)
Liked: 217
My only experience with HDR for PC gaming is with Sony TVs. For me, the HDR settings for the OS and games stick and do not require re-enabling.
The only advice I can offer is to do some research on your monitor and see what others have said about it.
NewAger is offline
post #7 of 8 Old 05-25-2020, 11:36 AM - Thread Starter
jake51's Avatar
Quoted: 364 Post(s)
Liked: 116
Switched back to the ultrawide after three days with the big one
I was kinda hoping the 43 inch would be much too big so that I could return it
But I like it more than expected
Besides being bigger the image is sharper and brighter - even without HDR turned on
jake51 is offline
post #8 of 8 Old 05-25-2020, 10:56 PM - Thread Starter
jake51's Avatar
Quoted: 364 Post(s)
Liked: 116
... but my eyes like the wide 21:9 aspect ratio better
Gimme a 40 inch ultrawide with VA panel and Gsync/Freesync
All 38 inch ultrawides have the same IPS panel (as far as I know)
Whatcha gonna do
jake51 is offline
Reply HTPC Gaming
