Official Blu-Ray Player Audio Setup Thread - All Audio Questions Go Here - Page 61 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #1801 of 1818 Old 01-20-2019, 02:28 AM
timcat4843's Avatar
Liked: 1
My Sony UBP-X800 player is stuck on muting.
How do I disengage it?
I want to watch movies late at night, while wearing headphones.
But my player is stuck on muting.
Repeatedly pressing the mute button, on the remote control, does nothing.
ViewSonic PX727-4K UHD DLP Projector
Sony UBP-X800 4K Ultra HD Blu-ray Player
Onkyo TX-RZ1100 Dolby Atmos/DTS:X (9 Channel) Receiver
Pioneer Floor Standing Dolby Atmos Enabled Speakers
PSA XS15se Subwoofer x 4 and Crowson Tactile Transducers
timcat4843 is offline
post #1802 of 1818 Old 01-20-2019, 09:25 AM
mdavej's Avatar
Quoted: 2951 Post(s)
Liked: 1320
The mute button on the Sony remote would control whatever TV you programmed it to control as shown on page 10 of the manual:
https://docs.sony.com/release//Manual_4687309111.pdf
If your headphones are not plugged into your TV, those buttons will have no effect on your headphone volume.
If your headphones are plugged into your AVR, use the AVR remote to control the volume.
See page 18 for using OPTIONS to control bluetooth volume if you're using bluetooth headphones.
mdavej is offline
post #1803 of 1818 Old 02-09-2019, 09:35 AM
Liked: 0
Dialague too Quiet - Sounds Effects too Loud
Hello,
I recently purchased the Sony Blu-ray Player BDP-56700. This issue I'm having is the dialogue is very hard to hear, so I turn up the volume, but then, the other sound effects are far too loud, so I turn the volume down, but I have trouble hearing the dialogue again. I am trying to figure out what audio setting(s) will help solve this problem, so I don't have to adjust the volume during the whole movie. My main uses are streaming Amazon Prime movies as well as watching Blu-ray discs and DVD's. I use the Digital Out (Coaxial) cable that goes in to my Yahama HTR-5940 receiver. Please see the attached screen shot of my audio setting options for the player. Thanks ahead of time for the expert advice!
Name:	Blu-ray Audio Settings.PNG
jmbtexas4 is offline
post #1804 of 1818 Old 02-11-2019, 12:13 PM
Selden Ball's Avatar
Quoted: 4804 Post(s)
Liked: 2842
Originally Posted by jmbtexas4 View Post
Hello,
This problem is designed into the soundtrack of the video that you're watching. You have to compensate for it in your receiver. You can either turn up the sound level of your center-channel speaker (where most dialog is) and then turn down the over-all volume control, or you can turn on the receiver's "night listening mode" feature. This feature boots quiet audio (like dialog) while dampening loud audio (like sound effects). For details, see page 32 of your receiver's owner's manual, which can be downloaded from https://usa.yamaha.com/files/downloa...m_htr-5940.pdf
Selden
Selden Ball is offline
post #1805 of 1818 Old 02-22-2019, 07:27 AM
mdavej's Avatar
Liked: 1320
Hello,
Turn BD Audio Mix OFF.
mdavej is offline
post #1806 of 1818 Old 03-06-2019, 12:03 PM
velocci's Avatar
Quoted: 594 Post(s)
Liked: 42
blu-ray audio vs UHD audio
Hi all, i'm not sure if I have the right forum. Is the audio on blu-ray discs and UHD discs the same? or is it higher definition on UHD discs?
Family Room: Onkyo TX-NR 646 AVR, Polk Audio RtiA3 fronts, Polk Audio CSiA4 center, BIC America F12 sub, Polk Audio RC-65i rears
Basement: Denon AVR-X3400 AVR, Klipsch RP280f fronts, RP450c center, SVS PB-2000 sub, Polk Audio RC-85i rears & surrounds
Www.jvpix.com
velocci is offline
post #1807 of 1818 Old 03-07-2019, 12:29 AM
Worf's Avatar
Quoted: 774 Post(s)
Liked: 498
In general, it's the same.
However, a trend is often the Blu-Ray has regular 7.1 audio while the UHD BD has Dolby Atmos audio. If you don't care about Atmos, then they're effectively the same. If you do, then you need to invest in a UHD player (they can downscale to 1080p if that's all you have).
Worf is offline
post #1808 of 1818 Old 03-07-2019, 05:22 AM
velocci's Avatar
Quoted: 594 Post(s)
Liked: 42
ok thanks.
Www.jvpix.com
velocci is offline
post #1809 of 1818 Old 03-11-2019, 07:38 AM
Liked: 0
Panasonic DP-UB420EBK Bluray Yamaha RX-V479
Hi guys, newbie member so please go easy. I recently purchased the Panasonic DP-UB420EBK BLURAY player, plugged it in to my Yamaha receiver, I'm not getting any sound whatsoever out of the TV speakers, I don't have any surround speakers set up yet, I've messed around with the settings but nothing. My receiver is connected to my television via an Atlona HDBaseT device, all other devices connected to the receiver transmit sound perfectly but nothing from the Bluray, I have connected the Bluray player directly to the TV and sound is perfect so there is definitely an issue when connecting via the receiver. The television is also a Panasonic TX-75EX750B. The Bluray player has 2 hdmi ports one is Video and Audio and the other is Audio only. If anyone could shed any light I would be eternally grateful it is really doing my brain in.
Thanks in advance
Sent from my SM-G965F using Tapatalk
midas_dj is offline
post #1810 of 1818 Old 03-12-2019, 11:05 AM
Liked: 2842
Thanks in advance
You need to post your question in the thread associated with your specific Yamaha receiver model, which you don't mention. However, similar problems often are caused by using inadequate HDMI cables. The cable from your BD player to your receiver must be "Certified Premium". Standard "High Speed" cables are insufficient for 4K signals.
This thread is for discussing how to choose a 1080p Blu-ray player. How to choose a 4K UHD Blu-ray player is discussed in the thread https://www.avsforum.com/forum/149-b...er-thread.html
midas_dj likes this.
Selden
post #1811 of 1818 Old 03-29-2019, 02:29 PM
bigdaddy999's Avatar
Quoted: 16 Post(s)
Confused about Codecs - Downmix to DD5.1/DTS/PCM
Reposting as I didn't see the note about putting audio questions here.
I ran into the first situation where I got a Blu-Ray that did not have an option to output DD5.1, DTS OR PCM to my Anthem D2 5.1 system. The Anthem is old, but only does DD5.1 / DTS. So any new stuff that isn't dd5.1 or DTS is downconverted from my Panasonic DMP-BD85 blu-ray to PCM which has been fine. The GREEN BOOK blu-ray offered only ATMOS and no PCM option, so I watched it in French with DD5.1 and subtitles. There was no other English soundtrack on the disc.
So I need help undestanding my options, assuming this might be the future of codecs on blu-rays. If I upgrade the blu-ray player to a current model, will it do a the job of decoding/downmixing. say ATMOS to DD5.1 or DTS? Or will I have to update the Anthem as well, which I really don't want to do. Will blu-ray players do this for current codecs? I'm trying to "future proof" as much as I can w/o spending a ton.
OR - just thinking about it now that I wrote this - did I have a PCM track, but had to switch the player to output that to the Anthem manually, and it was there after all?
bigdaddy999 is offline
post #1812 of 1818 Old 03-30-2019, 02:34 AM
Worf's Avatar
Quoted: 774 Post(s)
Liked: 498
The player should be able to read the "core" data and send it on. So if you have a Dolby Digital TrueHD soundtrack, the player can extract the core Dolby digital track and play it in 5.1. Same for DTS-HD Master Audio, the player can extract the DTS core track for playback.
About the only issue might be the bitrate might be higher than what your receiver is capable of since it exceeds the 640kbps of DVD for Dolby digital and 1.5Mbps for DTS.
You can test it today since all players have had this capability since the beginning.
Atmos is an extended form of TrueHD.
Worf is offline
post #1813 of 1818 Old 03-30-2019, 07:14 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5733 Post(s)
Liked: 8177
Selection of Bitstream vs LPCM output when you have told the disc to play a Bitstream track and the player to use Bitstream output should be automatic in the player -- part of the "HDMI handshake" which negotiates the format to send across the HDMI cable according to what the source device is playing and the receiving device can handle. Similarly, down mix of tracks with more than 5.1 channels of content to 5.1 should also happen automatically in the source player if the receiving device can't handle that larger number of channels. Again part of that automatic handshake. Lastly, the "lossless" Bitstream formats (e.g., Dolby TrueHD and DTS-HD MA) are always paired on disc with a "compatibility" track -- DD 5.1 or DTS 5.1 -- in case you aren't connecting to a device which can accept the full TrueHD or DTS-HD MA Bitstream. And once again, the player automatically selects to send the compatibility Bitstream track, instead of the original lossless Bitstream, whenever that is necessary.
An Atmos track is actually a Dolby TrueHD 7.1 track with extra data (for the expected Height speakers) which is ignored unless the track is being processed by an Atmos capable AVR (which your Anthem is not). So what the player is actually playing in this case is a Dolby TrueHD 7.1 track. Again, getting that across the cable to your Anthem should be handled automatically according to what the Anthem says it can accept during the HDMI handshake.
If you tell the player to use LPCM output instead of Bitstream output, it will decode the Atmos track into LPCM 7.1. (There are no Height speaker channels in that.) Furthermore, the LPCM 7.1 will be down mixed as necessary for output if the receiving device can't accept the full 7.1 channels
Since your Anthem D2 can not accept Dolby TrueHD or DTS-HD MA Bitstreams, and can only accept LPCM up to 5.1 channels, you should set your player to LPCM output (even if the track you are playing on the disc is *NOT* an LPCM track). Why? Because the player will then decode the original, lossless Bitstream track (Atmos, which means Dolby TrueHD 7.1 in your case) into LPCM -- followed by down mixing that to LPCM 5.1 for output to match what you D2 can accept. If you tell the player to use Bitstream output, on the other hand, it will send the compatibility (lossy) Bitstream track paired with the original TrueHD or DTS-HD MA track -- i.e., DD 5.1 or DTS 5.1 -- since your Anthem can not accept the original TrueHD Bitstream. The audio decoded into LPCM from the original lossless Bitstream track will be HIGHER QUALITY than what gets included in the compatibility DD 5.1 or DTS 5.1 track. So telling the player to send LPCM output gets you better quality audio.
For details on all of this, see my Blog post here:
Digital Audio 101 (...01010,,,)
--Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #1814 of 1818 Old 03-30-2019, 08:47 AM
Quoted: 16 Post(s)
--Bob
Bob, thank you very much. My player only offers "PCM" and "Bitstream", no "LPCM", so hopefully that is not a concern. But I changed both to PCM based on your comments. I also realized I had PCM downconversion on, which in this player forces the audio to 48hz, so I was giving up something there as well in sound quality.
The other thing I enabled was the "Secondary Audio Track" which appears to force EVERYTHING to DD5.1? I'm looking at this table for my player and have to figure out the conversion settings to make sure I'm doing the right thing. I'm connected to the Anthem via HDMI for both audio and video. Given the table below, should I still be set for PCM for both? Seems to me, wth the secondary audio enabled, maybe I want Bitstream for both options? Or stick with PCM only and turn OFF the secondary track? Please see table here:
https://www.manualslib.com/manual/11...page=33#manual
I guess what I still don't understand is why I had no audio output from the ATMOS track. If I understand your post here, there still should have been audio processed in the player and output via PCM OR Bitstream to the Anthem. But it was a Red Box rental so I don't have the disc at this point.
But thank you for your informative post. I'll also check out the link you included.
post #1815 of 1818 Old 03-30-2019, 06:33 PM
Read the FAQ!
Liked: 8177
^ I discuss Blu-ray “Secondary Audio” in that same post.
What you want is LPCM output on HDMI with Secondary Audio OFF (except whenever you really want to hear a disc feature such as a picture in picture Commentary track which only produces audio for the Commentary while Secondary Audio is enabled).
As discussed in that Blog post, enabling Secondary Audio with Bitstream output will indeed result in a lossy Bitstream, because the original Bitstream has to be decoded to LPCM in the player prior to mixing in the Secondary Audio, and the combo then has to be re-encoded BACK into a Bitstream for output. And players do not have the horsepower to do that re-encode as a lossless Bitstream.
Linear PCM — LPCM — is the only flavor of PCM used in home theater gear. So it is not unusual for manufacturers to just say “PCM” expecting anyone who cares will know they mean LPCM.
—Bob
post #1816 of 1818 Old 03-31-2019, 03:16 AM
Worf's Avatar
Quoted: 774 Post(s)
Liked: 498
The only caveat with PCM decoders is many lower end players only have a stereo decoder, so selecting PCM output will give you a 2.0 output. You will need to invest on a higher end player like a modern UHD player to get one with a multichannel decoder. Older players will often have multichannel decoders but as prices dropped, corners have been cut.
So PCM will give the best quality if your player can do multichannel decoding, but if you bought a cheap $100 player (even top of the line models in that price range) today, it will likely feature a stereo decoder, at which point if you want surround sound, you might have to compare against a matrix decoder with the stereo output versus the core tracks at lower quality.
Worf is offline
post #1817 of 1818 Old 03-31-2019, 07:07 AM
Quoted: 16 Post(s)
—Bob
Thank you. I read your article and updated the settings to be PCM and no secondary channel. So in the case of the ATMOS BD with no sound, if I had Bitstream enabled for the Dolby TrueHD option in the player with secondary audio OFF, then it would have been sending the TrueHD to the Anthem which had no idea what to do with it. So to hear it, I had to either switch that Bitstream to PCM, OR enable the Secondary Audio (but you say that's a lower quality option).
Do I have that right now?
Thank you again. Very helpful.
post #1818 of 1818 Old 03-31-2019, 08:47 AM
Read the FAQ!
Liked: 8177
^ The player SHOULD have sent the “compatibility” DD 5.1 track if you played an Atmos track with Bitstream output enabled, since your Anthem can not accept a TrueHD 7.1 Bitstream as input, and would have said so during the HDMI handshake. That’s even with Secondary Audio OFF in the player.
If the player failed to do that it could be a bug in the player (not handling this case correctly) or it could have been a temporary HDMI handshake failure — cure by forcing a new handshake. (And consider updating your HDMI cables.)
—Bob
Reply Blu-ray Players
audio , Blu Ray Players , blu-ray , disc , Samsung , Samsung Bd P1600 Blu Ray Player , sound , uhd
