Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1199 - AVS Forum | Home Theater Discussions And Reviews
 444Likes
post #35941 of 41511 Old 03-19-2011, 05:59 PM
djos's Avatar
Quoted: 29 Post(s)
Liked: 25
^^^ you should do a factory reset after each FW upgrade.
The impossible often has a kind of integrity which the merely improbable lacks.
djos is offline
post #35942 of 41511 Old 03-19-2011, 07:19 PM
oland's Avatar
Originally Posted by kitchen_space View Post
I just upgraded my player's firmware. Check this out - none of my user settings were changed by the update. Is that normal? Note that the pervious firmware I had in the player was at least 18 mos old. I verified the settings because I still my copy of Bill McClain's "Oppo BDP-83 Settings Checklist, Version 4."
Haha...yeah that's the kicker. You don't lose your settings but it's still recommended that you reset to factory default anyway.
by the way, why are we supposed to do this?
oland is offline
post #35943 of 41511 Old 03-19-2011, 07:38 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5830 Post(s)
Liked: 8304
^Because it is less messy than drawing a chalk pentagram around the player to ward off unexpected problems.
Too many times in the past we've had folks report problems after an install that were cured by a Reset and power cycle. So now it is habit.
--Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #35944 of 41511 Old 03-19-2011, 07:45 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4641 Post(s)
Liked: 4487
When going from firmware that old, I strongly suggest you reset factory defaults.
It's good luck.
There may be internal variables that benefit from a fresh start.
I recall a specific issue when shiftable subtitles were added. They are badly positioned until a reset. People have reported general crankiness resolved by doing a reset.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #35945 of 41511 Old 03-19-2011, 07:49 PM
kitchen_space's Avatar
OK. I reset to factory defaults. While going through the menus again to program the thing, I noticed there are some changes in the settings from my checklist Version 4, to checklist version 9. For example, what the heck is "HDCD," and do I want HDCD coding ON or OFF?
kitchen_space is offline
post #35946 of 41511 Old 03-19-2011, 07:55 PM
wmcclain's Avatar
Liked: 4487
http://en.wikipedia.org/wiki/HDCD
On or off I will leave to the audiophiles. It depends on your receiver.
-Bill
wmcclain is offline
post #35947 of 41511 Old 03-19-2011, 08:07 PM
Read the FAQ!
Liked: 8304
If your HDMI receiver decodes HDCD then you must turn off that decoding in the Oppo. Otherwise, turn it on in the Oppo.
The ability to decode is not something the Oppo can detect during the HDMI handshake, so that's why you have to set this correctly yourself.
If you decode in the Oppo and your receiver is also set to decode, then the receiver will get confused as the result of the decoding leaves enough clues in the HDMI audio output that your receiver will periodically think it has to switch into decoding mode itself.
This is just the way HDCD works with digital audio output.
--Bob
post #35948 of 41511 Old 03-19-2011, 09:43 PM
Rhythmx's Avatar
Quoted: 33 Post(s)
--Bob
Actually, according to Oppo, if you have you player connected digitally with the output set to bitstream, decoding of the track is left up to the receiver.
Mark
Rhythmx is offline
post #35949 of 41511 Old 03-19-2011, 10:00 PM
Read the FAQ!
Liked: 8304
That's correct. In the 83 and the 83se, if you have HDMI Audio Bitstream or HDMI Audio Auto set the HDCD Decoding setting is treated as OFF even though, of course LPCM is what's actually being output.
I consider that a bug, and indeed it is "fixed" in the new 93 and 95 players.
In the 83 and the 83se, to get the player to do the decoding you must set both HDCD Decoding ON and HDMI Audio LPCM. You should only do this if the HDMI Receiver does not, itself, do HDCD Decoding.
--Bob
post #35950 of 41511 Old 03-20-2011, 09:54 AM
--Bob
Got it guys, thanks. My pre/pro is a 2009 model Onkyo and it does not do HDCD. I guess Onkyo is not into HDCD as the latest 2010 model does not, either. I have the Oppo set to LPCM and it does all the decoding of the audio codecs. I also set HDCD = ON.
post #35951 of 41511 Old 03-20-2011, 12:35 PM
ckelly33's Avatar
Quoted: 26 Post(s)
I did the firmware update but have not done the factory reset yet. I'm no audiophile but have noticed that the center channel has changed and now is distorted with a 'tinny' pitch to it. After going through to see if anyone else has reported this (they don't appear to have), I'm gonna do the recommended factory reset and see what I get - but the factory reset choice is grayed out, what do I do to reset it?
ckelly33 is offline
post #35952 of 41511 Old 03-20-2011, 12:50 PM
wmcclain's Avatar
Liked: 4487
Make sure no disc is playing. Or: just eject the tray.
-Bill
wmcclain is offline
post #35953 of 41511 Old 03-20-2011, 01:37 PM
ckelly33's Avatar
Quoted: 26 Post(s)
DId a reset, put everything back they way it was, cleared persistent storage (nothing there anyway). Sound is still distorted.
Should I roll back? Will it allow me to do that?
ckelly33 is offline
post #35954 of 41511 Old 03-20-2011, 02:12 PM
ctviggen's Avatar
Quoted: 142 Post(s)
Liked: 36
I'm having a hard time getting more than 2 channels via HDMI when playing new Bluray audio formats. I have the output of the player connected to a video processor, which outputs to a Denon AVR (HDMI 1.1, will support 7.1 channel LPCM) and also to an overhead projector.
I assume what's happening is the video processor is reporting two channels due to the overhead projector for some reason. Does this sound reasonable? How can I test this? That is, if I remove the video processor from the path, put the Denon into the video and audio path, and get 5+ LPCM channels, does this mean my theory is correct? Thank you.
Bob
ctviggen is offline
post #35955 of 41511 Old 03-20-2011, 02:20 PM
rdgrimes's Avatar
Quoted: 3847 Post(s)
Liked: 3085
I doubt your audio distortion has anything to do with firmware, but it would help if you state how you are connected and to what.
rdgrimes is offline
post #35956 of 41511 Old 03-20-2011, 02:21 PM
Read the FAQ!
Liked: 8304
The simplest way to test this is to disconnect the cable going to the projector from the video processor. If the audio now works then that's your problem.
Try setting the video processor to not try to send audio to the projector. Also check that the processor isn't set to "pass through" the HDMI since that will mean the play sees the audio capabilities of the projector when it sets up the connection. Another possibility is to put the processor outboard of the Denon. That is, player to Denon to processor to projector.
--Bob
post #35957 of 41511 Old 03-20-2011, 02:27 PM
Read the FAQ!
Liked: 8304
Temporarily swap the speaker output wires from the amp to the Center and LF speakers. if the problem stays in Center then your Center speaker needs service. If the problem moves to LF, then put those speaker wires back normally. Now, if you are using a separate amp, swap the INPUT wires into the amp between LF and Center. If the problem stays in Center then your amp needs service for its Center channel. If the problem moves to LF, put those input wires back normally, and, if possible, try a different multi-channel source device through your receiver or pre-amp. This way you can isolate the problem and see if it really is the Oppo causing the problem.
--Bob
post #35958 of 41511 Old 03-20-2011, 04:06 PM
Mike_WI's Avatar
Quoted: 442 Post(s)
Liked: 326
Originally Posted by Neuromancer View Post
Release date: March 17, 2011
Category: Latest Official Release
Main Version: BDP83-55-0226
Loader Version: BE2800 or BT0500
Sub Version: MCU83-27-0326
1.Certain SACD discs with many short tracks or with a long track following several short tracks can cause the player to freeze during playback. This version fixes the issue. The crackles and pops that happened occasionally between tracks on some discs are also eliminated.
2. Fix for the issue of incorrect video size when playing some Blu-ray discs, such as "Patton", "Time Bandits" and "Date Night".
3. A small number of Blu-ray discs with Dolby TrueHD audio exhibit a momentary audio drop-out issue if the player is connected to an A/V receiver via HDMI and bitstream is selected as the HDMI Audio format. This version fixes the issue.
4. Support for LPCM audio streaming over home network is restored. The previous firmware did not carry this feature over from older versions. Please note that home network streaming is an experimental feature. You will need a computer running UPnP or DLNA streaming server software that can support transcoding to LPCM in order to use this feature.
5. The previous firmware version displays the time counter slightly too fast when playing SACD. This version fixes the issue.
6. Quieter laser head movement for CD playback.
7. Other general disc and media file compatibility improvement based on recent and upcoming Blu-ray releases as well as user-submitted samples.
The main difference if have already upgraded from the previous Beta Firmware is that CD-Audio playback will now be quieter. Previously you could hear a rhythmic clicking sound as the laser head moved forwards and backwards when reading CD-Audio titles. This ticking sound has been removed in this firmware.
All previous Beta Firmware errors are still present, which includes the incorrect aspect ratios of user created media.
I did the "Erase Persistent Memory" and "Reset to Factory Default".
Given that this is advised, any reason why the Oppo FW update doesn't save prior settings in another area, then erase memory, reset, and open a wizard with auto-populating the old settings?
Mike
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & 18 GHz output x1 cards} - "new (112818 FW)" 18 GHz microcode - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is offline
post #35959 of 41511 Old 03-21-2011, 08:32 AM
DM2006RI's Avatar
Quoted: 57 Post(s)
Liked: 84
Just wish they'd make it so that the player could stay on Underscan permanently without having to do that everytime I play a movie
DM2006RI is offline
post #35960 of 41511 Old 03-21-2011, 10:36 AM
lightbox's Avatar
Quoted: 42 Post(s)
Liked: 40
Aren't modern movies all shot with the assumption they will need to be viewed on overscan displays, so directors avoid putting meaningful content at the edges? Or do you just watch old movies?
lightbox is offline
post #35961 of 41511 Old 03-21-2011, 10:53 AM
Read the FAQ!
Liked: 8304
Movies are shot so that all CRITICAL content is inside the "safe" area, but that's not the same as saying all meaningful content is cropped. The composition includes the entire frame, and there's no good reason to tolerate a display that won't let you see all the pixels.
--Bob
post #35962 of 41511 Old 03-21-2011, 04:14 PM
jeff1967's Avatar
Quoted: 60 Post(s)
Liked: 870
Sucessfully updated firmware via ethernet today. Quick and easy as usual. Remembered to write down my settings before starting too! Total time to update was less than 4 minutes. Cleared persistent storage, reset to factory defaults, power cycled ans put my settings back in. Verified Blu, DVD, SACD, DVD-A, and cd playback. Everything A-Ok. Super happy Oppo!
Panasonic TC-P55ST50 Plasma 55"
Oppo BDP-203 Blu Ray, Toshiba A30 HD DVD
Onkyo RZ-900 Receiver (7.1 Config)
Klipsch R28F, RC64ii, RS400, RB600, R-12SW Sub
Mac Mini/PS3/Wii, Harmony Smart Control
jeff1967 is offline
post #35963 of 41511 Old 03-21-2011, 08:58 PM
oland's Avatar
I found this to be extremely helpful:
http://watershade.net/wmcclain/BDP-8..._Checklist.pdf
oland is offline
post #35964 of 41511 Old 03-22-2011, 06:23 AM
jeff1967's Avatar
Quoted: 60 Post(s)
Liked: 870
Me too! That's exactly what I used.
jeff1967 is offline
post #35965 of 41511 Old 03-22-2011, 07:53 AM
Immaculate Grand Phoobah
grubavs's Avatar
Location: on the noisy end of the Half Moon Bay, CA Airport
Quoted: 70 Post(s)
Liked: 55
Funny thing happened when I attempted to update beta firmware via enet, it updated the drive only, and then shut down So, I tried again and it reported could not work via network So I reset to factory defaults, downloaded the beta firmware to a USB stick, plugged 'er in, started the 83, and everything updated as appropriate
Are you talking' to me?
grubavs is offline
post #35966 of 41511 Old 03-22-2011, 09:44 AM
CochiseGuy's Avatar
This latest firmware disabled changing the BD region coding via my mod kit.
DVD region free was still there, but I had the player set to region B before the update and after updating it would only give me the region error message when I tried a region B BD, even after trying to re-program the player to region B several times. I rolled back to the last official firmware from April 2010 (big thanks for the links in post #1), as I wanted to make sure all 3 parts of the firmware would roll back. After rolling back to that firmware, my mod kit & region B works fine once again. So this latest FW sure disabled my multi region mod kit.
CochiseGuy is offline
post #35967 of 41511 Old 03-22-2011, 09:58 AM - Thread Starter
Neuromancer's Avatar
Quoted: 138 Post(s)
Liked: 475
Did you try doing a Reset Factory Defaults after installing the firmware?
Did you try changing the Remote Code from Code 1 to Code 2 or Code 3 and see if the results are the same?
Neuromancer is offline
post #35968 of 41511 Old 03-22-2011, 10:08 AM
CochiseGuy's Avatar
Yes, both after updating to the 3/17/11 FW and after rolling back to the 5/10 FW. Also cleared persistent memory both times just to be sure.
No, I've never fiddled with the remote code, so it's on factory default. It was responding to the remote. For my mod kit you press Pure Audio twice, and then once more for region A, twice for region B, and then Power Off (not the red one button). The LED display was blinking every time I pressed Pure Audio, just as it always does.
post #35969 of 41511 Old 03-22-2011, 10:32 AM - Thread Starter
Quoted: 138 Post(s)
Liked: 475
I would still try changing the Remote Code and see if Code 2 or Code 3 does not produce your desired results.
post #35970 of 41511 Old 03-22-2011, 11:34 AM
Read the FAQ!
Liked: 8304
If you already had the 0226 Beta installed. Then the only NEW thing was the new Loader firmware. Network update only gives you the pieces you need.
USB update installs whatever's on the stick, even if you already have it.
--Bob
Reply Blu-ray Players
105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
