Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1384 - AVS Forum | Home Theater Discussions And Reviews
 435Likes
post #41491 of 41495 Unread 08-12-2019, 10:52 PM
porieux's Avatar
Originally Posted by LatheOfHeaven View Post
Yes. Any updates in the firmware erases the ISO DVD Region Unlock mod. You simply need to reload it and it should work as far as I know, unless there is any other reason that would change anything.
Thanks. I burned the iso image to dvd and put it in the Oppo but still can’t play region 2 dvds.
porieux is offline
post #41492 of 41495 Unread 08-13-2019, 12:39 AM
LatheOfHeaven's Avatar
Hmmm... there must be something else involved then. That is too bad if the latest firmware invalidates the Region Free software mod. I myself after having my BDP-83 for about 10 years had issues with it reading discs and the tray being kind of tweaked, so I also just sent it in to OPPO to be serviced. Since I was in the middle of moving, I only had a moment to throw in a commercial Blu-ray that it hadn't been able to read before. It played perfectly. But, although I do have several other Region DVDs in my collection, I haven't had opportunity to try to play one yet. With over 9000 films and only a handful of other Region DVDs, I don't get around to them too often...
LatheOfHeaven is offline
post #41493 of 41495 Unread 08-13-2019, 12:40 AM
Please DO post here if you find an updated Region Free Mod, thanks!
post #41494 of 41495 Unread 08-13-2019, 02:46 AM
porieux's Avatar
False alarm I guess. The dvd I burned using windows 10s built in tool didn’t work.
I just tried again making a dvd with ImgBurn this time and it worked. Thanks.
porieux is offline
post #41495 of 41495 Unread 08-13-2019, 01:41 PM
Ah, that's more like it, thanks mate!
You should know by now that if it is a choice between using a Windows utility and ANYTHING else...
Cheers!
porieux likes this.
Reply Blu-ray Players
105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
