Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1385 - AVS Forum | Home Theater Discussions And Reviews
 449Likes
post #41521 of 41528 Old 01-07-2020, 09:07 PM
Mactavish's Avatar
Quoted: 156 Post(s)
Liked: 152
Short article from 2014, explaining issue on older players:
https://www.audioholics.com/news/dol...lu-ray-players
HDTV: Panasonic P55VT50 Plasma
AVR: Denon X3500H
SPEAKERS: Ohm (mains), Chane 2.4 (center), Rythmik F12G (sub), DefTech ProMonitor 80 (sats)
MEDIA PLAYER: Oppo BD83
Mactavish is offline
post #41522 of 41528 Old 01-07-2020, 09:28 PM
Derek87's Avatar
Quoted: 122 Post(s)
Liked: 44
thanks for the very helpful replies. it is good to know there is nothing inherently wrong with my 83 and it's just showing its age vs newer bitstreams of info.
i don't have an Atmos system, so there really isn't loss for me to set the 83 to output LPCM data to my Emotiva processor which feeds a 7.1 speaker setup.
of course, i probably have no reason to not play BR discs on the Sony x800m2 since it loads discs faster and i'm assuming audio/video fidelity of the two players should be comparable. i can reserve the Oppo for its DVD upscaling and if my sturdy 777ES SACD player ever dies, i can use its analog outputs for SACD.
Derek87 is offline
post #41523 of 41528 Old 01-20-2020, 02:02 PM
Jbhur212's Avatar
Quoted: 208 Post(s)
Liked: 177
So an interesting development. My 83 came down with the sticking tray problem awhile back (probably a year ago, I think). So sent it in for the fix and it was back to being it's old reliable self. However, over the last couple of months when I press open with the 83 remote (or eject with my Harmony 665) the screen shows open, then loading, then no disc and tray fails to open. I have to press open/eject again and it opens and close like a charm. No problems when done watching. Everything works as it should. No biggie to have to double press but thought I'd post it just in case anyone has had this happen with their player. Thanks.
EQUIPMENT:LG OLED77C8PUA (ISF calibrated by Jeff Meier)-OPPO BDP-203 blu-ray player-OPPO DV-983H dvd player-Pioneer CLD-99 laser disc player-Marantz 7703 Preamplifier-200x3 Acurus amplifier-150x2 Acurus amplifier-Emotiva UPA-2 amplifier-Outlaw Model 5000 amplifier-2 Mythos 4-1 Mythos 8-2 Mythos BPX-2 NHT Super Zeros-4 SVS Prime Elevation speakers-Hsu VTF-2 MK3 subwoofer-Elite-Xbox One S-Roku Ultra streaming player
Jbhur212 is offline
post #41524 of 41528 Old 01-20-2020, 02:27 PM
rdgrimes's Avatar
Quoted: 3975 Post(s)
Liked: 3244
Email Oppo support. There might be a way to reset that drawer, there used to be. I think it has something to do with the torque adjustment.
rdgrimes is offline
post #41525 of 41528 Old 01-20-2020, 02:40 PM
Jbhur212's Avatar
Quoted: 208 Post(s)
Liked: 177
Thanks for the quick reply. Is it a reset through a setting or an actual physical fix? I'm no techie on any level.
Jbhur212 is offline
post #41526 of 41528 Old 01-20-2020, 04:20 PM
rdgrimes's Avatar
Liked: 3244
Too many years ago, but I seem to recall its something like turning the player upside down and using the little eject hole to open it. The 83 is the only player that has that little hole. The folks at support should still have that procedure. I just recall that this was a known thing with that loader.
rdgrimes is offline
post #41527 of 41528 Old 01-20-2020, 05:51 PM
Jbhur212's Avatar
Quoted: 208 Post(s)
Liked: 177
So, as usual, support got back to me quickly and said-"We're not aware of a reset available for the drawer. You can try opening the player to clean the disc loader area to see if there's any build up of dust or other contaminates." Tried pulling the plug and plugging back in after 30 minutes or so and reset to defaults but no luck. Still a double press. I'll check your suggestion, though.
Jbhur212 is offline
post #41528 of 41528 Old 01-20-2020, 08:29 PM
rdgrimes's Avatar
Liked: 3244
Cleaning the rails and slides is a pretty good idea. If you take the top off the drive and slide the drawer in and out you can see the mechanics.
rdgrimes is offline
Reply Blu-ray Players
105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
