Official Samsung BD-C6900 3-D Blu-Ray Player Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 1271 Old 03-26-2010, 01:06 PM
Newfi's Avatar
Originally Posted by chiplowry View Post
I posted this over at the CNET Samsung forums but thought I'd try here as well:
I recently replaced my living room PS3 with a bluray BD-c6900. The PS3 connected wirelessly and streamed Netflix perfectly. I moved the PS3 into the home office.
The BD uses the same HDMI cable the PS3 was using. After unboxing the new unit, I had to upgrade the firmware before I could Netflix and that went fine.
Unfortunately, the audio is out of sync. Not just on one movie but on everything I've tried. The video leads the audio. As the movie goes on, the lag gets worse. If I pause or stop, it seems to resync for minute then drifts again. I see the same problem whether I'm connected via wired or wireless.
If I stop the movie, and restart on the PS3 in the home office (now on a different TV with a different HDMI cable), the movies streams perfectly.
Any thoughts on this would be appreciated.
I just hooked up my BD-C6900 this morning and the Netflix movie has the same audio video sync problem you describe.
Newfi is offline
post #32 of 1271 Old 03-26-2010, 01:23 PM
BritInVA's Avatar
Originally Posted by richandy View Post
You are correct in saying that it will access the NAS, but it will not play any MKV files. I have tried with all types. It will however play AVI, M2TS, MPEG4.
Have you tried running the Samsung PC Share Manager on your NAS? I have the BD-C5500 and it plays MKV..... I've had hit & miss when using TVersity.
BritInVA is offline
post #33 of 1271 Old 03-26-2010, 03:53 PM
chiplowry's Avatar
Noticed new firmware (1008) when I got home tonight. Netflix audio sync issue is better but definitely still there.
chiplowry is offline
post #34 of 1271 Old 03-28-2010, 02:49 PM
Yogi55's Avatar
Here is the response I rcvd from Samsung regarding the reported Netflix audio sync issue.
With reference to your email, we understand you notice there is a audio-video sync issue when watching the movies from the Netflix on your Blu-ray Player. You have already updated the firmware on the player.
We recommend you reset the player to isolate the issue.
Press the STOP button (on front panel) for more than 5 seconds with no disc inside. All settings including the
password will revert to the factory settings.
If you require any further information, please feel free to contact us.
Thank you,
Samsung Online support.
Yogi55 is offline
post #35 of 1271 Old 03-28-2010, 03:19 PM
armoredsaint's Avatar
i just ordered mine this morning with the un55c8000, plus the free 3d glasses offer. can wait to try it out! i read with the 3d tv, you can simulate 2-d into 3-d, is that correct?
armoredsaint is offline
post #36 of 1271 Old 03-28-2010, 04:39 PM
chiplowry's Avatar
Thank you,
Just gave that a shot. No joy. Still have an audio sync issue. Not as bad as with firmware 1005 (now using 1008) but still there.
post #37 of 1271 Old 03-28-2010, 05:39 PM
Soundmaster10.2's Avatar
Liked: 26
Yes, the 7000 and 8000 series can convert 2D to 3D. Please let us know what you think in the 3D forum when you get a chance to try this function out.
"With the advent of high-definition television, home viewers will see actors with extreme clarity and detail. Thus they will demand the stars of "Sex and the City" change their names to "The Golden Girls." -Conan O'Brien, In The Year 2000: Ted Danson Edition-
Soundmaster10.2 is offline
post #38 of 1271 Old 03-29-2010, 08:37 AM
dx31698's Avatar
Anyone who owns this try the full screen option which gets rid of the black bars on the top and bottom. Does it still look good or does it look stretched. My unit is coming soon and I was curious about this option
dx31698 is offline
post #39 of 1271 Old 03-30-2010, 06:54 PM
steffi's Avatar
I have this Blu-ray player hooked up to my C8000 but has anybody got the resume by memorize position working? If I'm working "9" and I hit "Stop" once it's suppose to memorize my position. I assume this means that when I return (after switching input) I can press play and it's suppose to remember where I left off.
Not seeing that so far.
steffi is offline
post #40 of 1271 Old 03-30-2010, 06:56 PM
steffi's Avatar
Where are the release notes to show what is fixed from these firmware upgrades?
steffi is offline
post #41 of 1271 Old 04-01-2010, 05:29 PM
steffi's Avatar
So spoke with Samsung today and they implied that that feature only works reliably with DVDs and not Bluray disks. This on a 3D Bluray player.
steffi is offline
post #42 of 1271 Old 04-02-2010, 08:10 AM
ilkevinli's Avatar
Sounds like they were just trying to get you off the phone. You should have never accepted that as an answer.
ilkevinli is offline
post #43 of 1271 Old 04-02-2010, 08:48 AM
steffi's Avatar
Yeah but what am I suppose to do? At this point I should be happy that a 3D Bluray player not only plays DVDs but actually plays Bluray discs too ;-)
steffi is offline
post #44 of 1271 Old 04-11-2010, 04:27 PM
i've had no issues with it playing any of my blu-ray disc, it's been working flawlessly so far and it loads so fast compared to my old sony bp-360 something which takes about 2-3 minutes even with updated firmware.
post #45 of 1271 Old 04-12-2010, 06:53 AM
ronorkis's Avatar
I cannot get this player to connect to my wireless access point. I have successfully connected my IPAD, 2 laptops, and a few hard-wired devices are wired to it, using WPA security. I can find my network, I am asked for a security key, which i provided, and it just sits there and eventually gives me the cant connect to wireless ap.
Has to be something I am missing here. I setup nothing in the players connection settings. Kept everything auto, and just tried to connect. Is it possible, the wireless adapter in the 6900 is too weak?
I am going to try and hardwire it tonight if I can get a long cable.
ronorkis is offline
post #46 of 1271 Old 04-12-2010, 08:36 AM
clemdog's Avatar
Quoted: 27 Post(s)
I picked up a 6900 yesterday. Don't need the 3D but thought it'd be nice to have for the future. Set-up was pretty easy.
All the streaming options were part of the reason I was interested in this player. NetFlix set-up was a breeze. However everything I tried to play on NetFlix was out of synch...by a lot. Vudu looks to be a terrific service and the moment I registered I got a notice that I had $5.99 creidit in my account good for my first HDX rental. A nice plus.
The first Blu-ray I tried was Alvin & the Chipmunks: The Squeackual...I know, I know. This title gave my prior player the fits and according to many postings on this board it's a problem on a lot of players. It gave the 6900 a very hard time too. Oh well, must be something wrong with the disc I thought.
Next I tried the first Transformers BD to hear how it sounded. Took a longer than usual time to load. Once it started I tried to Chapter skip a couple of chapters in. The player seemed sluggish to respond and when it did get to the next chapter the audio dropped in and out for 5 or 6 seconds until it seemed to regain it's composure. It did this everytime I either skipped chapters or used the scene selection to jump around. Not instilling tons of confidence in this player.
Next up was Disney's Princess and the Frog. First thing I saw afer loading PATF was the loading icon from Transformers !!! Then PATF loading icon just hung for several minutes. I had to shut down the player and reboot to get it to play. Once I did this it played fine.
At the end of the day I'll probably just pack up and return the player for a refund. Sad as I really liked the streaming options on this player.
Clem
clemdog is offline
post #47 of 1271 Old 04-12-2010, 09:22 AM
ronorkis's Avatar
Did you update the firmware? I believe there is a new one, which I haven't used just yet. Apparently it fixes the sync problems with netflix.
ronorkis is offline
post #48 of 1271 Old 04-12-2010, 09:24 AM
clemdog's Avatar
Quoted: 27 Post(s)
Sure did...
clemdog is offline
post #49 of 1271 Old 04-13-2010, 10:29 AM
ejqly's Avatar
I cannot get MKV's to play either. They show up on the list of files, but it just says not supported and it skips to the next file. It does play my Apple TV encoded movies just fine, just not the mkvs.
I also had issues with the Princess and the Frog Bluray disc. At the menu screen after selecting play, it asks for two options (don't remember what they were) but I selected the normal play option (this is part of the disc not the player), it just started on a loop with distorted audio. I power cycled the player and this fixed the issue. I, however, did not play the entire movie, but rather just the first 10 minutes or so of it in order to evaluate and test the player. As I posted on another thread, I'm having issues playing through the entire MVA 3d Bluray, it will not play the entire movie, it just stops after about 34 minutes into it. It goes back to the DVD Players main menu (where you select what media type you want to view). And the Stop "button" on the player keeps blinking, even after you hit play on the remote and the movie re-starts again from the beginning. I watched MVA last night (or tried to) and had this issue happen 4 times during the movie. I'm on firmware 1008.0. I got a hold of firmware 1005.0 today, I'm going to try and downgrade the firmware to see if it's a firmware issue. Has anybody ever downgraded firmware on a Sammy BD Player? Is it safe to do so? Before I do the downgrade I'm going to try a regular BD movie to see if it just a MVA issue with my player. I have not heard anybody else with this issue and the ones on display at BBuy don't seem to have this issue, but then again I don't know what firmware version they have.
Update:
Mkv's play if sourced from the USB port, but they will not work over the network. Wish samsung would just support SMB shares.
ejqly is offline
post #50 of 1271 Old 04-17-2010, 08:32 AM
clemdog's Avatar
Quoted: 27 Post(s)
Turned on my 6900 last night and it downloaded a firmware update. Anyone know what's in it?
clemdog is offline
post #51 of 1271 Old 04-27-2010, 08:32 AM
BigKeithO's Avatar
v1009.3 fixes the audio sync problem with Netflix. Also says it supports certain BD movie titles better, doesn't say which ones...
BigKeithO is offline
post #52 of 1271 Old 05-07-2010, 11:09 AM - Thread Starter
Geaux Tigers's Avatar
CNET just reviewed the player and here is the link:
http://reviews.cnet.com/blu-ray-play...CmoreStories.0
Geaux Tigers is offline
post #53 of 1271 Old 05-08-2010, 11:32 AM
Lars99's Avatar
I just picked one of these up today. Can anyone help me with the letterbox feature? This was one of the main reasons I went with Samsung.
I have it set to 16:9 wide and I'm using a Vizio 552XVT. The only blu-ray I have, Master and Commander, still shows the black bars at the top and bottom. Any help would be appreciated in getting Screen Fit to work.
Lars99 is offline
post #54 of 1271 Old 05-08-2010, 12:57 PM
Super Moderator
teachsac's Avatar
Quoted: 1313 Post(s)
Liked: 2145
It's supposed to. Aspect ratio is 2.35:1. 16:9 wide is only for SDDVD's not Blu-rays. The only way would be to use the TV to "ugghhh" crop and chop it. Besides.
http://www.highdefdigest.com/news/sh...rs_Go_Away/764
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #55 of 1271 Old 05-08-2010, 01:43 PM
Lars99's Avatar
Samsung BD-C6900 Blu-ray Player
Screen Fit
To maximize your viewing experience, to truly feel the power of on-screen portrayals, you need all the picture you can get. With the Screen Fit feature, the BD-C6900 Blu-ray disc player automatically converts 21:9 aspect ratio movies to 16:9 aspect, eliminating those annoying black bands crowding the scenes. Watch movies the way they were meant to be seen--with just one touch of the Screen Fit button.
Lars99 is offline
post #56 of 1271 Old 05-09-2010, 03:59 PM
Dave Vaughn's Avatar
Quoted: 1577 Post(s)
Liked: 2483
Screen Fit
Hit the "Full Screen" button on the remote, although you'll lose the sides of the picture when zooming in like this.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
Dave Vaughn is online now
post #57 of 1271 Old 05-09-2010, 04:02 PM
Lars99's Avatar
Um, isn't that just zoom? That doesn't seem like resizing. Am I missing something here? I can't seem to find Screen Fit anywhere in the manual.
Lars99 is offline
post #58 of 1271 Old 05-09-2010, 05:42 PM - Thread Starter
How many more 3D Blu-ray players do you believe Panasonic has sold compared to Samsung because of the 3D Checkerboard Format? Panasonic offer the 3D Checkerboard as an option while Samsung does not. Over 4 Million 3D ready DLP HDTVs where sold in the US. However, 3D ready DLP sets are only compatible with the 3D Checkerboard Format. Interesting enough, Samsung sold 3D ready DLP sets while Panasonic did not. I guess Panasonic believes in taking care of the customer more than Samsung.
post #59 of 1271 Old 05-10-2010, 08:50 AM
Super Moderator
teachsac's Avatar
Liked: 2145
There is no way to fit a 2.35:1 source into a 1.78 area without zooming, chopping, and/or cropping. Contrary to the picture on Samsungs website There is no information/picture behind the black bars.
S~
teachsac is offline
post #60 of 1271 Old 05-10-2010, 09:07 AM
Lars99's Avatar
So is the "automatically fit", etc... portion of their advertisement false?
Lars99 is offline
Reply Blu-ray Players
Blu Ray Players , Samsung , Samsung Bd C6500 1080p Blu Ray Disc Player , Samsung Bd C6900 3d Blu Ray Player Refurbished , Samsung Refurbished Blu Ray Disc Player Bd C5500 B
