Official OPPO BDP-93 Owner's Thread - Page 951 - AVS Forum | Home Theater Discussions And Reviews
 1521Likes
post #28501 of 28774 Old 08-05-2018, 08:53 PM
william13's Avatar
Use of component video on Oppo 93
I need to use component video because of having a legacy AVR.
I would like to do this with an OPPO 93.
Will my blu ray automatically be reduced to less than 1080 because of the ICT (image constraint token).
Does which firmware I have make a difference and whether the OPPO was manufactured early or more toward 2012?
Thank you
Bill
william13 is offline
post #28502 of 28774 Old 08-05-2018, 11:23 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5849 Post(s)
Liked: 8353
Thank you
Bill
The Blu-ray will not be reduced unless the studio has included the ICT in the disc's authoring, and almost no discs were ever made that way due to market pressures. Instead the studios forced the "Analog Sunset" -- the prohibition against having ANY Analog video outputs in new players. Firmware notes are in the first post of this thread.
--Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #28503 of 28774 Old 08-06-2018, 06:23 AM
william13's Avatar
Bob
Thank you for your instantaneous reply
I just read over the firmware notes on post one. There were a lot of them!
I did not see anything about an automatic reduction of resolution if I use component video with blu ray.
So assuming the manufacturer of the disks do not embed an ICT does that mean I should be fine (in terms of not downsizing the resolutions) in purchasing an OPP0 93 regardless of firmware version or manufacture date?
Bill
post #28504 of 28774 Old 08-06-2018, 07:57 AM
Read the FAQ!
Liked: 8353
Manufacturing date is not an issue. There are plenty of OTHER things in the firmware updates, but none that affect ICT. So no worries on that score. You can update whatever you get to the latest firmware.
—Bob
post #28505 of 28774 Old 08-06-2018, 08:20 AM
william13's Avatar
—Bob
Thanks again Bob
That was 99% of my concern.
I doubt if I would ever use Iso's (mainly just rent blu rays over Netflix or Red box) but is that ability gone for ever because of updates?
post #28506 of 28774 Old 08-06-2018, 09:09 AM
Read the FAQ!
Liked: 8353
Thanks again Bob
Yes. ISO support existed for just a few weeks. It is gone forever, as a gift to you from the Studios. (No need to thank them. It's all part of the service.)
--Bob
post #28507 of 28774 Old 08-06-2018, 01:24 PM
Coyote Waits
htwaits's Avatar
Quoted: 1333 Post(s)
Liked: 2365
--Bob
Shhh. There is one they didn't catch.
My Components:
Denon X3400H, OPPO UDP-203 & BDP-93, Xfinity XG1-P, Vizio PQ, Roku 3 & Ultra 2018
Calibration Resources:
Customer's Reports -- Professional Calibrations
Calibrator's locations and tour areas.
htwaits is offline
post #28508 of 28774 Old 08-07-2018, 04:40 PM
Philnick's Avatar
Quoted: 568 Post(s)
Liked: 253
Just found that I can make my old 93 look as good on a DVD as my 103 (which I'm getting rid of) by raising the Sharpness control in the 93's HDMI 1 setting to 4. (This is on the DVDs of Star Trek: Deep Space 9 - which are fairly soft - with a 50" 1080p LCD TV.)
My question is whether this has any adverse effect on Blu-ray play.
Phil
Philnick is online now
post #28509 of 28774 Old 08-07-2018, 06:18 PM
Coyote Waits
htwaits's Avatar
Liked: 2365
You're probably the only one who can tell.
I have the 93 and the 203 but a Kuro TV. I currently play .ISO backup Blu-ray films using the 93 and play rental DVD and Blue-ray films on the 203. I have never used sharpness controls.
My Components:
htwaits is offline
post #28510 of 28774 Old 08-07-2018, 08:36 PM
rdgrimes's Avatar
Quoted: 3970 Post(s)
Liked: 3239
"4" is a pretty severe sharpness boost and will certainly result in some ringing.
I use HDMI-2 exclusively from the BDP-93 which avoids the softening that HDMI-1 can produce. The un-defeatable NR in HDMI-1 is source-adaptive, meaning that DVD will have more softening than BD will.
rdgrimes is offline
post #28511 of 28774 Old 08-07-2018, 09:22 PM
Philnick's Avatar
Quoted: 568 Post(s)
Liked: 253
Just found that I can make my old 93 look as good on a DVD as my 103 (which I'm selling on eBay because I got myself a 203) by raising the Sharpness control in the 93's HDMI 1 setting to 4. (This is on the DVDs of Star Trek: Deep Space 9 - which are fairly soft - with a 50" 1080p LCD TV.)
Before I read your response, I had - in line with the manual's advice that +2 should be the most used - tried dialing the sharpness back from +4 to +2, which still looked ok - but I'll try switching from HDMI 1 to HDMI 2 and see what that looks like.
Phil
post #28512 of 28774 Old 08-07-2018, 10:29 PM
m. zillch's Avatar
Quoted: 5777 Post(s)
Liked: 4116
By my read of the Oppo 93 manual it has two video processing chips and HDMI output 1 always gets the better one so that's the port with the best image and the most features for adjustments, whereas HDMI 2 has less control :
"6. Sharpness: To set the sharpness of video output. Sharpness (also called Detail/Edge
Enhancement in previous OPPO players) is a video processing function that can control the
image sharpness but at the same time may cause unwanted artifacts.
For HDMI 1, the sharpness level can be set between -16 and +16. The default is level 0, which
turns off sharpness enhancement. The negative levels may be used to reduce or eliminate
overly sharpened video. However, the picture may appear soft. The positive levels increase
the sharpness.
􀁺 At level 1, the player applies low level Detail Enhancement, during which the video
processor isolates the detailed parts from the original image, processes them separately
and integrates back before the final output.
􀁺 At level 2, the player increases Detail Enhancement to a higher level. Generally, to make
an image “sharper”, we recommend using level 1 and 2.
􀁺 At level 3 and above, the player adds Luminance Transition Improvement (LTI) and
Chroma Transition Improvement (CTI), which further sharpen the luminance transition and
chroma transition. However, we do not recommend using level 3 and above unless the
source content is poorly produced and blurry.
For HDMI 2 & Analog, the sharpness level can be set between 0 and +2. The default is level
0. The higher the level, the sharper the video details are. However, too high a sharpness level
may cause while line etching around objects."
My casual examination just showed these sharpness adjustments are not enabled while the movie is actually playing so setting them on the fly is not possible. Correct?
m. zillch is offline
post #28513 of 28774 Old 08-10-2018, 07:14 PM
monkeyboy1010's Avatar
I have picked up a used Oppo BDP 93 and the unit seems to be stuck at startup.
The player powers on, the power light will change from red to blue, the player front display will show HELLO at startup and then nothing, the disc drawer will open and close. If I place a disc in player, it does nothing.
On the screen display shows the Oppo and Blu-Ray Disc logos.
The remote control lights, the power button and eject button are the only button that will work on the remote.
I was hoping to find a way to hard reset the unit, but all the searches lead me to using the Oppo setup menu to do this, which I can't currently access.
Any help would be greatly appreciated, thanks!
mb1010
monkeyboy1010 is offline
post #28514 of 28774 Old 08-10-2018, 07:46 PM
Some success... I found this post
https://www.avsforum.com/forum/149-bl...l#post29071641
which outlined the procedure from Oppo to check your unit, once I did this it was able to get to OPPO and then NO DISC
Now to figure out how to get it to handshake with my TCL 4K
mb1010
post #28515 of 28774 Old 08-10-2018, 08:09 PM
Figured it out, hooked the Oppo up to a spare computer monitor and was able to get to the Oppo setup menu and did a full reset along with upgrading to the latest firmware from Oppo, handshake with my TCL is working!
htwaits and Bob Pariseau like this.
mb1010
post #28516 of 28774 Old 08-19-2018, 12:28 PM
LCSeminole's Avatar
Quoted: 169 Post(s)
Liked: 148
Just an FYI, Emotiva XMC-1 owners recently got an upgrade to this processor in the form of a new 4K/HDMI 2.0b/HDCP 2.2 video board and Oppo's non-4K players(in our case the BDP-83 & 93) were passing video but NOT passing audio through HDMI. After a few of our Emotiva Lounge members sent e-mails to Oppo, they responded with this:
"If you recently upgraded your receiver to one that supports HDMI 2.0 and HDCP 2.2, then you will need to upgrade your player's firmware. This firmware can be downloaded off of our website, and then extracted to a FAT formatted USB drive.
download.oppodigital.com/BDP0903/BDP9X_85-0106B.zip
Best Regards,
Customer Service
OPPO Digital, Inc."
Modicen and Trell like this.
Emotiva RMC-1/XPR-5/XPA-7Gen3, AppleTV 4K
LG OLED65C8, Oppo UDP-203, Panasonic DP-UB820
Furman PL-PRO DMC 20A, Monster Power HTS-5000
SVS Dual PB12-Plus x 2, Prime Elevation x 4
Klipsch KLF-20, KLF-C7, RB-5II x 4
LCSeminole is offline
post #28517 of 28774 Old 08-19-2018, 07:55 PM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
Hi All,
I just purchased a Oppo 93 used. Is this player still one of the best for 1080P BD playback?
I have a JVC X35 projector on a 110" 16:9 fixed screen.
I currently have a Sony S350 entry level BD player which the Oppo will replace unless you recommend me keeping it just in case the Oppo won't play some BD's?
Will I be able to tell the difference in video quality between an Oppo 93 and my Sony?
K.
k3nnis is offline
post #28518 of 28774 Old 08-19-2018, 07:58 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4720 Post(s)
Liked: 4596
(a) Probably not, but (b) no one can say what another person can see.
-Bill
bigd86 likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #28519 of 28774 Old 08-19-2018, 07:59 PM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
-Bill
Thanks fair enough. I also got it for the dual HDMI as my AVR doesn't support 3D passthrough.
k3nnis is offline
post #28520 of 28774 Old 08-19-2018, 08:14 PM
rdgrimes's Avatar
Liked: 3239
This HDCP issue is kind of old news. But I found another solution, which is to output the 93 into the HDMI input of the BDP-203. The only reason I mess with that is to retain ISO capability in the 93, which you lose with the newer firmware. Anyway I set the 93 for source direct output and the 203 does the scaling and deinterlacing. I haven't tried this using a 103, but I'm guessing it would also work.
htwaits likes this.
rdgrimes is offline
post #28521 of 28774 Old 08-20-2018, 12:46 AM
Coyote Waits
htwaits's Avatar
Liked: 2365
My 93 has one HDMI output. Could you possibly have a 103?
My Components:
htwaits is offline
post #28522 of 28774 Old 08-20-2018, 12:56 AM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
Hmm it definitely has two HDMI's. I am in Australia if that makes any difference?
k3nnis is offline
post #28523 of 28774 Old 08-20-2018, 01:01 AM
Coyote Waits
htwaits's Avatar
Liked: 2365
If the front of your OPPO is labeled BDP-93 than I don't know, but Bob does.
My Components:
htwaits is offline
post #28524 of 28774 Old 08-20-2018, 01:06 AM
zeuspaul's Avatar
Quoted: 250 Post(s)
Liked: 363
My 93 has two HDMI outputs. That is one of the primary reasons I bought it. I live in the US.
Spoiler!
zeuspaul is offline
post #28525 of 28774 Old 08-20-2018, 01:07 AM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
Ok. Maybe yours is a 83?
k3nnis is offline
post #28526 of 28774 Old 08-20-2018, 02:30 AM
wl1
wl1's Avatar
Quoted: 451 Post(s)
Liked: 410
The 93 does have two HDMI Outputs, and zero HDMI Inputs.
I believe the 103 has two HDMI Outputs AND two HDMI Inputs (1 front and 1 rear).
Ken Kreisel Twin DXD808, Q125 LCR, x4 Q125 TriFX, x4 QFH - for Atmos 7.2.4/Auro 9.2/DTS:X 11.2
Oppo 93 & 203 & Sony VPLHW55ES PJ with Lumagen 2020, 2.35:1 Seymour AT XD screen. Logitech Ultimate One & Hub, SqBox Touch & Philips Hue. Nakamichi AVP1 with Denon X7200WA. With MiniDSP 2x4.
wl1 is offline
post #28527 of 28774 Old 08-20-2018, 06:15 AM
wmcclain's Avatar
Liked: 4596
-Bill
m. zillch likes this.
wmcclain is offline
post #28528 of 28774 Old 08-20-2018, 02:15 PM
Coyote Waits
htwaits's Avatar
Liked: 2365
Nope. I sold the 83 to pay for the 93.
I just found it all the way to the left of the HDMI port that I'm using. Dumb, but I'm happy to have another HDMI port.
Thanks to everyone who has posted help for me.
My Components:
htwaits is offline
post #28529 of 28774 Old 08-20-2018, 02:17 PM
Coyote Waits
htwaits's Avatar
Liked: 2365
-Bill
Thanks Bill. I guess I'm a plug and forget user.
My Components:
htwaits is offline
post #28530 of 28774 Old 08-22-2018, 06:51 PM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
Does the oppo 93 support mkv HD audio passthrough via DLNA?
And does it support 4tb HDD?
k3nnis is offline
Reply Blu-ray Players
BDP-95 , Blu Ray Players , component video ict resolution restrictions , multiregion , Oppo Bdp 93 Blu Ray Player
