Official OPPO BDP-93 Owner's Thread - Page 952 - AVS Forum | Home Theater Discussions And Reviews
 1521Likes
post #28531 of 28773 Old 08-22-2018, 07:54 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4713 Post(s)
Liked: 4588
Originally Posted by k3nnis View Post
Does the oppo 93 support mkv HD audio passthrough via DLNA?
And does it support 4tb HDD?
No to both.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #28532 of 28773 Old 08-22-2018, 08:05 PM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
Originally Posted by wmcclain View Post
No to both.
-Bill
Ok thanks. Does it work if I put it in a USB HDD? The HD audio mkv?
k3nnis is offline
post #28533 of 28773 Old 08-22-2018, 08:07 PM
wmcclain's Avatar
Liked: 4588
No. You can get HD audio from M2TS files but not from MKV. This restriction is lifted in later players.
-Bill
wmcclain is offline
post #28534 of 28773 Old 08-22-2018, 08:25 PM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
-Bill
Ok thx. I guess I will use libreelec with my intel nuc for mkv HD audio.
Am I correct in saying the hdmi out of the oppo 93 will be better than the intel nuc hdmi? Assuming playing back same content.
k3nnis is offline
post #28535 of 28773 Old 08-28-2018, 01:08 AM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
Hi All,
I playback my blu ray ISO's using an external USB drive attached to my Oppo 93 as I have the older firmware. Is there a way to transfer my ISO's from PC or NAS to the USB hard drive without unplugging from Oppo? I'm worried each time I have a new movie to watch I need to unplug and replug and may damage the USB port sooner??
K.
k3nnis is offline
post #28536 of 28773 Old 08-28-2018, 04:33 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5848 Post(s)
Liked: 8353
Hi All,
K.
No. Your computer can't access the drive while it is attached to the OPPO. If you are worried about the port (and I would not be), you can use a powered USB "hub" between the port and the hard drive. Then if the port in the hub fails, just replace the hub. Even simpler would be to use a short USB extender cable. Keep one end plugged into the OPPO and attach the drive's cable to the other end.
--Bob
htwaits and m. zillch like this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #28537 of 28773 Old 08-28-2018, 04:34 AM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
--Bob
Thanks bob. How many drives can I attach to a powered USB hub that the oppo can recognise? And 2tb each?
k3nnis is offline
post #28538 of 28773 Old 08-28-2018, 04:41 AM
Read the FAQ!
Liked: 8353
As many as the hub supports, and yes.
--Bob
post #28539 of 28773 Old 08-28-2018, 04:48 AM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
--Bob
Thanks. Will go look for one now USB 3.0 hub will it work?
k3nnis is offline
post #28540 of 28773 Old 08-28-2018, 06:16 AM
wmcclain's Avatar
Liked: 4588
Hi All,
K.
Another arrangement I've found handy are the pop-up toaster docks, one each at the player and PC. You move bare drives between them.
3.5" 7200rpm drives can be noisy in the open, 5400rpm drives are quieter, and 2.5" drives are nearly silent. Or you could use SSD, silent of course. The docks I've had take both 3.5 and 2.5".
You can use USB 3.0 drives connected to a 2.0 port.
-Bill
wmcclain is offline
post #28541 of 28773 Old 08-28-2018, 06:19 AM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
-Bill
Thanks bill on the suggestion.
k3nnis is offline
post #28542 of 28773 Old 08-28-2018, 11:38 AM
Coyote Waits
htwaits's Avatar
Quoted: 1333 Post(s)
Liked: 2365
--Bob
I've been using a powered USB "hub" for years. It's more convenient than using the USB port on the OPPO. Never had a problem with either one.
My Components:
Denon X3400H, OPPO UDP-203 & BDP-93, Xfinity XG1-P, Vizio PQ, Roku 3 & Ultra 2018
Calibration Resources:
Customer's Reports -- Professional Calibrations
Calibrator's locations and tour areas.
htwaits is offline
post #28543 of 28773 Old 08-28-2018, 04:00 PM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
Out of interest which USB hub have you got?
k3nnis is offline
post #28544 of 28773 Old 08-28-2018, 05:50 PM
Coyote Waits
htwaits's Avatar
Liked: 2365
It's an Anker 3.0 USB Hub and it's not powered. I use it for thumb drives and powered external hard drives.
I also have an Amazon basics 3.0 USB four port Hub that is powered. It's connected to a PC, and I use it to create the files that I play through the OPPO.
My Components:
htwaits is offline
post #28545 of 28773 Old 09-04-2018, 10:16 PM
Coyote Waits
htwaits's Avatar
Liked: 2365
Originally Posted by rdgrimes View Post
This HDCP issue is kind of old news. But I found another solution, which is to output the 93 into the HDMI input of the BDP-203. The only reason I mess with that is to retain ISO capability in the 93, which you lose with the newer firmware. Anyway I set the 93 for source direct output and the 203 does the scaling and deinterlacing. I haven't tried this using a 103, but I'm guessing it would also work.
I've tried what you have done with your 93 and when I get to the point of telling it to play the ISO file our 4K HDR TV switches to no signal. I'm using a 4/1 switch and have Roku, Xfinity cable, and the 93 going through HDMI IN. At this point every thing is working except actually playing the USB ISO file that I've selected. I have the 93 set to Source Direct.
I hope I've left something out in the 93 and/or 203.
My Components:
htwaits is offline
post #28546 of 28773 Old 09-05-2018, 05:19 AM
rdgrimes's Avatar
Quoted: 3965 Post(s)
Liked: 3236
I'd try it without the switch in the chain to see if that works.
rdgrimes is offline
post #28547 of 28773 Old 09-05-2018, 12:19 PM
Coyote Waits
htwaits's Avatar
Liked: 2365
OK. I should have tried that first.
My Components:
htwaits is offline
post #28548 of 28773 Old 09-05-2018, 01:38 PM
Coyote Waits
htwaits's Avatar
Liked: 2365
I just tested without the switch and the results were the same. Everything perfect right up to selecting the actual ISO file, a brief flash of the OPPO logo and then a black screen until the "no signal" TV message. So close ...
Netflix and PBS via Roku and TV via Xfinity are all working fine. The Harmony activity is set to assume that the OPPO 93 is the device playing the movie. That seems to be necessary in order for the Elite to navigate the selection process.
Thanks for your interest. I hope we can come up with something that works. I'm one FW version behind on the 203. When I get back I'll update that.
My Components:
htwaits is offline
post #28549 of 28773 Old 09-05-2018, 02:00 PM
rdgrimes's Avatar
Liked: 3236
I wonder if something is switching the 203's input selection. Try a shiny disc, DVD or BD, in the 93 and see what it does. For the time being I'd eliminate the Harmony too and just use the respective remotes to verify its all doing what it should.
rdgrimes is offline
post #28550 of 28773 Old 09-05-2018, 02:11 PM
Coyote Waits
htwaits's Avatar
Liked: 2365
OK. I have to go out for a couple of hours but do all of that when I get back. Thanks.
My Components:
htwaits is offline
post #28551 of 28773 Old 09-05-2018, 05:16 PM
Coyote Waits
htwaits's Avatar
Liked: 2365
I eliminated the Harmony and inserted a BD disk. The results were the same. Navigation in the OPPO 93 screens was normal. I also got a "Loading" message on the TV and then "No Signal".
Just as aside, when using the Harmony the OPPO 203 reports that it's on "HDMI IN" after the "No Signal" shows up. So it looks like the OPPO 203 is treating the input from the 93 differently than it treats input from Roku/Netflix and Xfinity cable.
My Components:
htwaits is offline
post #28552 of 28773 Old 09-05-2018, 05:47 PM
Read the FAQ!
Liked: 8353
In Setup > Device Setup in the 203, check the line for configuring the HDMI Input. Try changing that for use with the 93. For example to 1080p.
—Bob
post #28553 of 28773 Old 09-05-2018, 06:42 PM
Coyote Waits
htwaits's Avatar
Liked: 2365
—Bob
Bob, that worked. I changed the default UDD HDR to 1080p.
In the future, if I have a HDR10 streaming source, I assume that I will have to switch back and fourth between the two options.
Thanks to both of you from me and my movie backups.
My Components:
htwaits is offline
post #28554 of 28773 Old 09-05-2018, 08:37 PM
Read the FAQ!
Liked: 8353
If you don’t mind updating the firmware in the 93, you can get firmware from OPPO which should let the 93 work even with the Input of the 203 set to allow UHD HDR.
—Bob
post #28555 of 28773 Old 09-05-2018, 08:43 PM
rdgrimes's Avatar
Liked: 3236
—Bob
NOT if you want to play ISO.
htwaits likes this.
rdgrimes is offline
post #28556 of 28773 Old 09-05-2018, 08:47 PM
Coyote Waits
htwaits's Avatar
Liked: 2365
—Bob
Thanks. I've got all my BD shiny disks backed up as ISO. I suppose I could convert them and move forward unless the studios stomp on the alternatives.
Another learning curve for my 85th birthday this month.
Now you've got me evaluating.
My Components:
htwaits is offline
post #28557 of 28773 Old 09-29-2018, 08:00 PM
Mr Man's Avatar
I have my Oppo connected to a Pioneer VSX932 receiver via HDMI. I get picture but no sound - when I bring up the audio input signal on the receiver it says the Oppo is sending out analog audio? I tried changing the hdmi output on the Oppo to HDMI 2 but I get a pink magenta screen and still no sound. I have tried 4 different HDMI cables and have made sure the HDMI 1 setting for video only is ‘No’.
I am pulling my hair out here, could anyone assist me with what could be the issue..
H
Thank you much appreciated
Mr Man is offline
post #28558 of 28773 Old 09-29-2018, 09:14 PM
rdgrimes's Avatar
Liked: 3236
H
The Pioneer is HDMI 2.0 / HDCP 2.2, which the Oppo cannot play nice with unless you get a specific firmware from Oppo. (Its not a public firmware)
Contact Oppo support for the firmware. Be advised that the new firmware will disable ISO support if you've been using that.
https://www.oppodigital.com/ContactUs.aspx?CatID=1
rdgrimes is offline
post #28559 of 28773 Old 09-29-2018, 10:44 PM
k3nnis's Avatar
Quoted: 644 Post(s)
Liked: 60
Is the picture quality of the 93 same as 103?
If using 1080p native. No 4k upscaling for both assuming.
k3nnis is offline
post #28560 of 28773 Old 09-30-2018, 12:12 AM
Mr Man's Avatar
Noooo! What a shameThat is the only reason I still have it. Does that firmware support SACD-R?
Mr Man is offline
Reply Blu-ray Players
BDP-95 , Blu Ray Players , component video ict resolution restrictions , multiregion , Oppo Bdp 93 Blu Ray Player
