Official OPPO BDP-93 Owner's Thread - Page 959 - AVS Forum | Home Theater Discussions And Reviews
 1524Likes
post #28741 of 28786 Old 10-27-2019, 12:02 PM
m. zillch's Avatar
Quoted: 5802 Post(s)
Liked: 4143
I have a new issue. At first I though I had a bad drive so I swapped it for another but it now seems to happen to any thumb drive or HDD I attach to the BDP-93. After successfully reading the drive contents in just seconds and playing some videos if I either power down or view some photos when I return again to "Movies" the drive locks up with a perpetual blue arrows icon shown ("data being transferred") and I'm locked from any other keystroke. I tried doing a "default to factory settings" in the 93's setup but the problem remains. The drives when returned to my main computer are reported as being corrupted/RAW and have to be re allocated/formatted to work again. Any ideas?
P.S. I'm wondering if these drives which I have to alter to NTFS insead of their default of exFAT is the issue but one of the drives, a 2TB WD My Passport, has been working flawlessly on my 93 for years without issue. [All these drives once repaired on my PC report "no problems found" when I apply various scans to detect errors, BTW.]
m. zillch is offline
post #28742 of 28786 Old 10-27-2019, 12:37 PM
rdgrimes's Avatar
Quoted: 3978 Post(s)
Liked: 3245
The 93 does not support exFAT, only NTFS and FAT32.
rdgrimes is offline
post #28743 of 28786 Old 10-27-2019, 01:35 PM
m. zillch's Avatar
Liked: 4143
Yes, I know which is why I change them when formatting them to NTFS before loading them for use in the 93.
When they "break" they are NTFS.
post #28744 of 28786 Old 10-28-2019, 02:44 AM
wl1
wl1's Avatar
Quoted: 451 Post(s)
Liked: 410
Are the HDD's partitions set up as MBR or GPT? What size?
If the 2Tb WD does not cause a problem, look to make the other HDD's the same - even if just to try and work out what is happening.
i.e. MBR - 1 partition of 2Tb
See Here - might be useful if any of the above applies in your situation.
Ken Kreisel Twin DXD808, Q125 LCR, x4 Q125 TriFX, x4 QFH - for Atmos 7.2.4/Auro 9.2/DTS:X 11.2
Oppo 93 & 203 & Sony VPLHW55ES PJ with Lumagen 2020, 2.35:1 Seymour AT XD screen. Logitech Ultimate One & Hub, SqBox Touch & Philips Hue. Nakamichi AVP1 with Denon X7200WA. With MiniDSP 2x4.
wl1 is offline
post #28745 of 28786 Old 10-28-2019, 11:48 AM
m. zillch's Avatar
Liked: 4143
The drives are not partitioned; they are being used whole, in NTFS format. [It never asks about MBR or GPT so I'm not sure about that one, although IIRC it's MBR, if it even matters when not partitioned.]
The drives are all 2GB or less. I have successfully used one of them, a 2GB WD My Passport HDD, for years without issue but now it fails the same way:
Initially everything is fine and I can successfully watch both videos and photos but then suddenly it locks for undetermined reasons and it seems to lock, for sure, if I power down the 93. The drive then brought back to my main PC is unreadable and has to be re-allocated and formatted to work again.
I have upgraded to the latest Oppo 93 firmware, 1009 IIRC, which I was reluctant to do because I hear it no longer plays ISO, not that I need that actually, and the problem remains.
I added a powered hub, even though the WD seemed fine before without needing the extra electrical power, and it still fails the same way.
I will check out the link. Thanks.
post #28746 of 28786 Old 11-08-2019, 01:22 PM
calentz's Avatar
Quoted: 219 Post(s)
Liked: 149
RE: Netflix, I received an E-Mail from Tivo saying that they will no longer provide Netflix also.
--Carl
calentz is online now
post #28747 of 28786 Old 11-11-2019, 05:05 PM
Quoted: 27 Post(s)
Originally Posted by Philnick View Post
Here it is:
http://download.oppodigital.com/BDP0...X_85-0106B.zip
Instructions on how to do this are on the Oppo website under Support.
I just want to write and thank you for this post and link. I have been dealing with an issue for several days in which I was not getting sound from the BDP-93 via HDMI to a new Sony A9G or Yamaha RX-A880, and the only color space that was working on the Oppo was RGB. It was driving me nuts...to the point that I gave up and purchased a new Panasonic player.
Well, I gave it another try by searching this thread, and found the link to the 10/2017 firmware update. This update solved the problem!
So, thank you again. AVS Forum is an invaluable resource.
tvad1 is offline
post #28748 of 28786 Old 11-11-2019, 05:26 PM
Philnick's Avatar
Quoted: 585 Post(s)
Liked: 261
You're very welcome. I've gotten lots of help here myself.
Phil
Philnick is online now
post #28749 of 28786 Old 11-13-2019, 01:24 PM
InfinityBob's Avatar
I just thought I'd post this. I am quite old and have lost interest in my audio. I have an OPPO 93 player, which would work fine with a firmware update and as is, will play disks, but not operate right for streaming. I need to know what number to call for getting OPPO to send me a Firmware update disk. Anyone have that phone number?
InfinityBob is offline
post #28750 of 28786 Old 11-13-2019, 03:45 PM
rdgrimes's Avatar
Liked: 3245
Support:
https://www.oppodigital.com/ContactUs.aspx?CatID=1
InfinityBob likes this.
rdgrimes is offline
post #28751 of 28786 Old 11-13-2019, 09:25 PM
Liked: 0
My OPPO 93EU suffers continuos dropouts in audio and video signal
Hi all,
I would be grateful if you could please help me.
Since few weeks I can´t use my OPPO 93EU because every few minutes (from 1 to 5 minutes) it losses video and audio signal for 1 or 2 seconds and then everything is fine until the next fairule.
The OPPO has been in the same place for 5 yeras and haven´t made any change or new conection to it. This happens with all kind of sources: blurays, audio CDs, USB, etc....
Never updated firmware and never conected it to internet. Firm version is BDP9xEU-57-0917
I´m desperate because I have no idea what is wrong and I´m worried because it was an expensive investment.
Many thanks in advance
piyayo is offline
post #28752 of 28786 Old 11-13-2019, 09:35 PM
m. zillch's Avatar
Liked: 4143
Sounds like a borderline signal strength. I bet if you disconnect the HDMI cable coming out of it, on both ends, and then reconnect them the problem will be gone. The connections may have oxidized over the years or become loose. This scrapes the connections clean and makes sure the connection is well seated. Let us know how it goes.
post #28753 of 28786 Old 11-13-2019, 09:50 PM
Liked: 0
Sometimes I unplug the HDMI cable to connect other source for my projector. So I guess that is not the problem.
Anyway I just did it to make sure but still suffers the same. Right now a 1 second image and sound loss.
Any other idea??? please
Many thanks for your help!
piyayo is offline
post #28754 of 28786 Old 11-13-2019, 09:51 PM
Liked: 0
Forgot to mention that happens the same with CDs and no HDMI conected. I have frequent audio losses
Strange!!!
piyayo is offline
post #28755 of 28786 Old 11-13-2019, 10:08 PM
m. zillch's Avatar
Liked: 4143
You disconnected and then reconnected the HDMI port on the projector end too?
post #28756 of 28786 Old 11-14-2019, 05:28 AM
Liked: 0
yes, few times
piyayo is offline
post #28757 of 28786 Old 11-14-2019, 08:39 AM
rdgrimes's Avatar
Liked: 3245
yes, few times
You have a bad cable somewhere in the chain. Time to start replacing till you find the culprit.
rdgrimes is offline
post #28758 of 28786 Old 11-14-2019, 10:36 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5855 Post(s)
Liked: 8363
Strange!!!
So when playing a CD with no HDMI connected do you mean you are just not using the HDMI signal path, or that the HDMI cable is actually unplugged? If the cable is plugged in and marginal you can still get HDMI handshakes even though you are not using the HDMI for audio. (All outputs of the OPPO are live simultaneously.) Due to Copy Protection protocols, a handshake will briefly Mute the player, which would cause a brief loss of audio even on Analog or Optical/Coax for your CD playback.
Also with HDMI cables still plugged in, if you have one of the newer Sony TVs, and have it turned OFF while doing your CD playback, the Sonys are known to trigger bogus HDMI handshakes while they are Off (actually in Standby). To test this try leaving the TV turned On while you play a CD. You can use Pure button on the OPPO to black out the TV, or the Picture Off option on the Sony remote.
--Bob
shimonmor likes this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #28759 of 28786 Old 11-14-2019, 03:45 PM
m. zillch's Avatar
Liked: 4143
It's really rare for HDMI cables to suddenly go bad but I had one which worked flawlessly for many years and then without warning nor touching it nor making breaking any connections it suddenly became intermittent. I replaced it and all was well.
Look closely and you'll see it has a bad pin:
Name:	Bad HDMI with missing pin 640 480.jpg
post #28760 of 28786 Old 11-15-2019, 08:39 PM
Liked: 0
Just got brand new 4k HDMI cable and still have cuts/losses
--Bob
Playing a CD audio the losses occur often. More often than I could turn on/off TV. Both HDMI cables are connected to the OPPO all the time
Today I got my brand new EPSON TW9300 and I´ve been changing all possible video/audio configuration in the OPPO and testing every change untill I get a cut in the signal. I got cuts for every change I made aftes around 10 minutes. So I´m really lost about this.
The Epson TW9300 was conected with the new 4k HDMI cable and suffers the same cuts in audio and video. In those cuts the screen turns pink/magenta, I´ve noticed that is the same color that is shown when I change intentionally some of the video configurations in the OPPO (bitrate, 1080i, 1080p, etc...), so I supect that the cuts are related to video configurations.
But in the other hand if there were a signal or configuration problem, the pink/magenta screen on the projector would be continuous not every 10 minutes. Don´t you think?
I´ve really tryed everything today for more than 5 hours with no results!!!! desperate by now!!!!
Just an important information that I don´t know how to interprete: yesterday I plugged the OPPO with the (old) HDMI cable to my Sony TV instead of the (old) proyector and I could watch 007 Casino Royale with NO CUTS AT ALL!!!!! 2 hours with no problem. So I guees the problem might come from a bad "understanding" between OPPO 93 and my projectors because I´ve suffered same cuts with two cables and two proyectors.
Many thanks for your kidn help folks!!!! Should we declare an X File??? Mulder or Scully could help?
piyayo is offline
post #28761 of 28786 Old 11-17-2019, 02:24 AM
wl1
wl1's Avatar
Quoted: 451 Post(s)
Liked: 410
Chasing this stuff down is difficult at times. The magenta change is usually when moving from RGB to YCbCr or vice versa. I assume you have both devices set to Auto - and somehow this is getting constantly negotiated for some reason.
Try fixing it down to YCbCr in the Oppo (and projectors if the option is available) and checking if this reduces the problem.
I have not read further back - apologies if you have tried - just make sure all HDMI Control is OFF on every device in your system (even if only for diagnostics). This is CEC or has various manufacturer names, but is often a source of trouble.
wl1 is offline
post #28762 of 28786 Old 11-19-2019, 03:53 PM
Tighe's Avatar
Here it is:
I just spent way too many hours trying to figure out why my 93 was no longer outputting sound via HDMI (just analog). Found this post, installed the firmware, and everything is golden again. Thank you sir.
TV: Vizio P65-F1 -Receiver: Marantz SR6013 - Mains: Polk RTi10 - Center: Polk CSi5 - Surrounds: Polk f/xi3 dipole/bipole - Atmos front .2: Klipsch R-41SA - Sub: Polk PSW505 - Oppo BDP-93 - Nvidia Shield Pro 2019
Tighe is offline
post #28763 of 28786 Old 11-19-2019, 07:17 PM
Philnick's Avatar
Quoted: 585 Post(s)
Liked: 261
Here it is:
We all help each other out here!
Phil
post #28764 of 28786 Old 11-24-2019, 02:38 AM
Liked: 2
I recently aquired a region free BDP-93EU for the princely sum of about $50. The device works fine, however, it's running a really old firmware (9xEUBO-52-0707) and I'd like to upgrade it to the newest available. I've succeeded in locating several newer firmwares and tried to flash them, but no matter how I attempt the upgrade it never actually 'takes'. I've tried via USB and burning a CD. The upgrades seem to be recognized and the player says 'successfully upgraded firmware' (or words to that effect) and shuts down. But when I restart it the firmware it still says 9xEUBO-52-0707 ... very frustrating!
Anyone have a clue as to what's going on here?
bluefuzz is offline
post #28765 of 28786 Old 11-24-2019, 09:49 AM
Read the FAQ!
Liked: 8363
The EUBO identifier in your current firmware means you've got special firmware OPPO prepared for OPPO players sold through Bang & Olufsen (in the EU in your case). The changes are minimal (no OPPO splash screen for example), but it does make it a different flavor of firmware than the normal firmware you can find on the OPPO Support pages.
To update, that means you need to get an EUBO firmware release.
I suggest you reach out to OPPO Tech Support in the EU. They should be able to either get you the current EUBO firmware your player will accept or at least point you to the right place to get it direct from Bang & Olufsen.
--Bob
post #28766 of 28786 Old 11-24-2019, 11:43 AM
Liked: 2
--Bob
Ah! That's interesting. I've never heard that B&O sold custom Oppos. At least that gives me something to go on. It's not super important but it would be nice to get it up to the latest firmware.
bluefuzz is offline
post #28767 of 28786 Old 11-29-2019, 04:17 PM
Thank you. I will try contacting Oppo. I may just auction this off as is not working and hopefully it will go to someone who can fix it
post #28768 of 28786 Old 11-29-2019, 08:22 PM
rdgrimes's Avatar
Liked: 3245
They can fix it for a flat rate fee.
rdgrimes is offline
post #28769 of 28786 Old 12-30-2019, 12:18 AM
IanD's Avatar
Quoted: 180 Post(s)
Liked: 80
In my experience, the Oppo 93 tends to corrupt any attached usb drive if powered down with the drive still attached or the drive removed whilst still having the directory open.
The workaround was to never power down the Oppo whilst a usb drive is connected, but to keep pressing the Return button on the remote until it won't go back any further and then disconnect the usb drive before powering down the Oppo.
I have not tried viewing photos so have not experienced corruption when switching between Movies and Photos, but I would suggest when you have finished playing one type of material, Return(ing) and disconnecting the usb drive, then plugging it back in and playing another material type.
If you do get a corrupt usb drive, I think running the Windows command Chkdsk.exe with the /f option (fix mode) usually returns it to operational state (I suspect the File Allocation Table gets corrupted, but the backup FAT is okay and chkdsk replaces the FAT with the backup).
m. zillch likes this.
IanD is offline
post #28770 of 28786 Old 12-30-2019, 06:17 AM
EDH63's Avatar
Hello all. It's been a long time since posting here. I do have a question, though. Is OPPO still making/selling players? I have an OPPO 93 and I'm looking to upgrade. Actually, I'm going to upgrade pretty much everything I have... Panasonic ZT60, OPPO 93, and Onkyo NR-727. The main reason for upgrading is I'm tired of getting audio drops on Atmos disks. My equipment is not Atmos certified. Plus, I want to get into the OLED TVs. Anyway, can anyone recommend a great BD player outside of OPPO since they evidently are no longer doing the BD thing?
Thank you
EDH63 is offline
Reply Blu-ray Players
BDP-95 , Blu Ray Players , component video ict resolution restrictions , multiregion , Oppo Bdp 93 Blu Ray Player
