The Pioneer BDP-62FD/150/450 2012 Blu-ray Player Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #721 of 726 Old 02-18-2018, 03:36 PM
Ricky's Avatar
Quoted: 87 Post(s)
Originally Posted by bguzman View Post
Verify the HDMI output settings on the 62FD.
I have toggled the HDMI settings between pcm and bitstream if that’s what you mean. No sound via either. Thanks.
Ricky is offline
post #722 of 726 Old 02-18-2018, 04:11 PM
bguzman's Avatar
Quoted: 138 Post(s)
Liked: 842
HDMI Mode Setting from page 39 of the manual, Dual, Separate, or Pure Audio. If that doesn’t work you can try restoring the factory settings by following the instructions on page 45.
HT TCL 55P605, Mitsubishi HC6500, Oppo UDP-203, Panasonic LX1000, Firestick 4K, ATV4K, Onkyo TX-NR787, DefTech, Klipsch, Martin Logan, SVS @ 5.2.4 Atmos
Stereo Sansui SR-4050, Dual 1219, Oppo UDP 203, Emotiva PT-100, Be One Audio MA100, Polk Monitor 10, SVS SB1000
bguzman is offline
post #723 of 726 Old 03-04-2018, 09:55 PM
Ricky's Avatar
Quoted: 87 Post(s)
I upgraded from Marantz 7702mk2 prepro to the 7704 last week, and now have sound when playing an atmos bluray. Go figure.
However, the HDMI output seems to be stuck on "PCM" even though the Audio Output is set to "Bitstream". Restoring factory settings doesn't change this.
Any remedies? Thanks again.
MAN CAVE (5.2.4): Marantz 7704 prepro & Citation 7.1 amps(2); 5 Focal Solo6 Be active monitors, 4 Focal Sib (for Atmos), Earthquake 15" and NHT B12 12" subs, Vizio P65-C1 4K LED, Nvidia Shield TV 4K Pro, Oppo 203
GAME ROOM (5.1): Denon 5200W, Adcom GFA7607 amp, NHT Classic 3s/3C/2s, NHT W1 12" sub, Panasonic 65VT50 plasma, PS4, Switch, Wii, Roku, Oppo 981
Ricky is offline
post #724 of 726 Old 11-02-2018, 03:46 PM
truelies1's Avatar
For Pioneer 62fd, can I copy a blu ray disc file to USB and play with it?
truelies1 is offline
post #725 of 726 Old 07-29-2019, 05:31 PM
randyman8's Avatar
Pioneer BDP-150 tray won't open
Several months ago, my Pioneer BDP-150 blu ray player tray won't open intermittently. Luckily on the second or third try it won't open. As of this week, now it won't open at all. The display says "open" and it makes the sound like it will open but it doesn't. When I press eject again, it says "close", makes the same sound but again nothing happens. I've tried unplugging / replugging but doesn't work. Any suggestions?
randyman8 is offline
post #726 of 726 Old 07-31-2019, 09:30 AM
peptalk1's Avatar
Liked: 1
See youtube how to change the 'belt'(little elastic band)
peptalk1 is offline
Reply Blu-ray Players
Blu Ray Players , Pioneer
