The Pioneer BDP-62FD/150/450 2012 Blu-ray Player Thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #121 of 726 Old 02-22-2013, 02:02 PM
LNEWoLF's Avatar
Quoted: 476 Post(s)
Liked: 291
Thank you I appreciate it. These manuals now a days just are not very informative. I didn't catch that in advanced settings under audio output digital output settings that the digital out (to mean the opitical and rca terminals.) That would have been helpful if they would have stated that in the manual. : ) Am I right to assume that those audio output digital output settings dont matter if your using hdmi audio out (setting set as bitstream, it will just send the raw signal unprocessed to the AVR 1222 for processing.)
Twin Pioneer AVR Locomotives-Elite SC 97, SC 1222 7.2.4, DOLBY Atmos and DTS X, (Front Pre Out,) JBL Pro Synthesis LS Series Speakers, F L R-LS80, Cen-LS, S L R-LS60, SB L R-LS60, 4 Dolby Atmos Enabled Klipsch R41SA, Twin Klipsch R120SW. Mitz 73740 DLP, Sony UBP-X800, ATV G4, Yamaha ATS 1060 Sound Bar, True Depth Firestorm 2.0 3D Glasses, Harmony Hub with Utlimate 1 Remote, Broadlink RM Pro2, EYE Pad Air, Winegard FL6550A
LNEWoLF is offline
post #122 of 726 Old 02-22-2013, 02:12 PM
eyekode's Avatar
Quoted: 23 Post(s)
Originally Posted by Kilian.ca View Post
It's not difficult really if you understand the basics.
Dts Downmix is only relevant for 'Digital Output', which only means coaxial/optical (see the rear panel diagram), not HDMI. I know HDMI is digital too but that's just how it is called for some manufacturers. That's why there is a separate 'HDMI Audio out' for HDMI .
Downsampling ditto.
Color space: generally YCbCr 422 unless it's known to be worse than RGB (we dunno)
HDMI Audio Out: generally no difference PCM vs bitstream but most people want to see dts or Dolby lights proudly displayed on their receivers for psychological satisfaction.
HDMI Deep Color: 24 bits (anything more means guessing what's not there)
Is 24 better than 60 - yes only if TV can display in multiples of 24 frames per second, irrelevant otherwise
The other reason you may want to do bitstream is if the format supports DRC (Dynamic Range Compression/Correction?? "night time" viewing) and you want to set it through the receiver. I was frustrated with the bdp-150 because I could not figure out how to change DRC without restarting the disk. But I still don't have this worked out as I have not (yet) figured out how to set it on my receiver.
eyekode is offline
post #123 of 726 Old 02-22-2013, 02:32 PM
LNEWoLF's Avatar
Quoted: 476 Post(s)
Liked: 291
Eyekode - Under advanced settings. You can set it to on, off or auto. I have mine set to off. As my AVR (1222) has a mode for this.
LNEWoLF is offline
post #124 of 726 Old 02-22-2013, 07:05 PM
Kilian.ca's Avatar
Liked: 37
The use of the term "Digital Out" has been around since DVD players, so it's not something new or has to be explained every time.
The Digital Out settings are of no consequence whether you choose PCM or bitstream via HDMI, it's just irrelevant.
DRC is only for DD in some DVDs. Even if you want to set it in the receiver you can just turn it off in the player.
Generally it'd be better for receivers to do it as they can apply DRC or the equivalent with any input making it essentially format independent.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #125 of 726 Old 02-23-2013, 06:11 AM
eyekode's Avatar
Quoted: 23 Post(s)
Thanks I have the same receiver. I will compare this setting with the dialog enhancement as well.
eyekode is offline
post #126 of 726 Old 02-23-2013, 06:19 AM
eyekode's Avatar
Quoted: 23 Post(s)
I was under the impression it was a feature of the format. And if you use PCM from the BD player then the receiver will not do the decoding and thus not be able to benefit from the DRC information encoded in the DD stream. I also thought the quality of the DRC could be better using the data in the stream then a generic algorithm operating on PCM. Of course having it work on all disks would be best from a user interface perspective. Maybe we are saying the same thing? I still have to try for my self if there is any practical benefit.
But I am disappointed in the bdp-150's controls if you truly cannot change DRC without restarting the disk (baud I hate previews and "bonus content"!).
Salem
eyekode is offline
post #127 of 726 Old 02-23-2013, 05:03 PM
Kilian.ca's Avatar
Liked: 37
I never use DRC and if you prefer Dolby's DRC to others I can't argue with that. Maybe it is in all DD formats in all discs, I never researched into this.
But the 150 can apply DRC to PCM output, so it should make no difference if player sends PCM with DRC applied, or bitstream and let AVR handle it.
looks like receiver handling DRC isn't always straight forward:
www.avsforum.com/t/1223937/autoflagged-drc-from-truehd-and-your-receiver
post #128 of 726 Old 02-24-2013, 02:02 AM
Nisei's Avatar
Quoted: 14 Post(s)
I recently bought a 150. I have not used it much but first impressions are not good. It feels/looks cheap but the worst is it is not very responsive. For example if you hit the power button to turn it on... nothing happens for a couple seconds. At a minimum the lights should come on immediately.
There's a setting in the Initial setup menu called Quick Start which is off by default. I haven't tried it but I assume what it does is leave the unit turned on and just switch off the display and the audio/video circuitry. Give it a try.
Once turned on I think this player is very responsive so I'm not sure what you're talking about.
Youth is wasted on the wrong people.
Nisei is offline
post #129 of 726 Old 02-24-2013, 08:00 AM
haute's Avatar
Hi, could someone help me?
I'm trying DISASSEMBLE firmwares for Pioneer BDP-140/150/440/450 with IDA Pro but I can not get a good code.
I have MTKPio software and informs me about the different parts of the firmware, but not to have to disassemble startpoint.
I think it's Mips little endian.
A greeting.
haute is offline
post #130 of 726 Old 02-24-2013, 09:06 PM
Quatre's Avatar
Originally Posted by Advizer View Post
Time will tell... 140 doesn't have Cinavia. CFW 4.03 for both models is identical. CFW 4.02 is better than 4.03 and exists only for 140/440.
So you suggest Cfw 4.02 is better then 4.03 but why?
Is it worth getting the bdp-140 then over the 150 just for Cfw 4.02 over 4.03?
Quatre is offline
post #131 of 726 Old 02-25-2013, 09:49 AM
MortUK's Avatar
A greeting.
Is this what you're looking for.?
The firmware from Pioneer is open source
here: http://www.oss-pioneer.com/homeav/blu-ray/files/BDP-140/index.html
here: http://www.oss-pioneer.com/homeav/blu-ray/files/BDP-150/index.html
and here: http://www.oss-pioneer.com/homeav/blu-ray/files/index.html
Mort..
MortUK
MortUK is offline
post #132 of 726 Old 02-25-2013, 06:56 PM
eyekode's Avatar
Quoted: 23 Post(s)
It turned on "quick start" and it is a little quicker. But there is still close to a 3 second delay before anything happens when turning on as opposed to 6 or so. I also allows the iPad app to turn the power on/off. So definite some improvement. I just would have preferred some outward sign as soon as you hit they power button. All my other electronics have some immediate feedback with the exception of my projector which suffers from a similar lag.
I is not a deal breaker, just one of many things that in my opinion lack polish.
Salem
eyekode is offline
post #133 of 726 Old 02-25-2013, 08:41 PM
jklow888's Avatar
Question on CFW 4.03 - does it come with Pandora as some regions don't get all the apps ? Also given the interest in the open source firmware, is anyone looking at adding more apps, eg. TuneIn ?
jklow888 is offline
post #134 of 726 Old 02-25-2013, 11:25 PM
Advizer's Avatar
Liked: 24
4.02 is better than 4.03 because there is no "alphabetical" chaos in a file list. However, you could also install a CFW 4.02 for BDP-140 into a BDP-150 with a FW 1.02. Afterwards, the BDP-150 will become "BDP-140", according to the info menu.
Advizer is offline
post #135 of 726 Old 02-25-2013, 11:28 PM
Advizer's Avatar
Liked: 24
You need CFW 5.0X if you look for Internet services. Pandora, Youtube, Netflix, Picasa are activated in the latest version of custom firmware.
Advizer is offline
post #136 of 726 Old 02-26-2013, 12:25 AM
Advizer's Avatar
Liked: 24
Quatre,
you should know that 4.03
- supports external 3TB HDD via usb
- doesn't have DVD Cinavia
- supports ext2/3/4.
Advizer is offline
post #137 of 726 Old 03-02-2013, 11:06 AM
DongTeamSetup's Avatar
DongTeamSetup is offline
post #138 of 726 Old 03-02-2013, 02:50 PM
eyekode's Avatar
Quoted: 23 Post(s)
Salem
I removed an HDMI splitter from my setup and responsiveness is much improved! Now my only issue is that occasionally it locks up and requires a hard restart by pulling the plug. Seems to be related to starting the Netflix app.
eyekode is offline
post #139 of 726 Old 03-03-2013, 09:48 AM
Aj Rodriguez's Avatar
Been using a BDP-62FD for a month now and so far so great! Love the player, load fast, fantastic play quality.
Aj Rodriguez is offline
post #140 of 726 Old 03-03-2013, 09:51 AM
Nisei's Avatar
Quoted: 14 Post(s)
I've installed the RattleByte region free chip in my 150 last week and it's working great!
Support is awesome and at least I can upgrade to newer firmware now as soon as it gets released.
Nisei is offline
post #141 of 726 Old 03-03-2013, 11:43 AM
docjonty's Avatar
Excuse the newbee silly question, but I have a new BDP150 on its way to me.
I see the hookie firmware for the BDP 140 allows DVD-A playback.
Is there any firmware for the 150 that allows the same?
docjonty is offline
post #142 of 726 Old 03-03-2013, 11:55 AM
Advizer's Avatar
Liked: 24
Check a FW-version of your player (Initial Setup - Options - System Information - OK). If it's 1.02, you'll be able to install CFW 4.03. The latter would make it possibe to play DVD-Audio discs, that don't have CPPM protection.
Advizer is offline
post #143 of 726 Old 03-03-2013, 11:58 AM
Advizer's Avatar
Liked: 24
35 € ??? What a waste...
Advizer is offline
post #144 of 726 Old 03-03-2013, 12:01 PM
docjonty's Avatar
hasnt arrived yet and brand new, so could have later firmware.
Is there any way to get around the later firmware , or install the older variety then put the hacked version on if it is the latest version?
docjonty is offline
post #145 of 726 Old 03-03-2013, 12:28 PM
Advizer's Avatar
Liked: 24
Nope.
Advizer is offline
post #146 of 726 Old 03-03-2013, 12:29 PM
Advizer's Avatar
Liked: 24
Look for BDP-140 or BDP-450 (the latter with FW2.05).
Advizer is offline
post #147 of 726 Old 03-03-2013, 01:20 PM
Nisei's Avatar
Quoted: 14 Post(s)
Of course not. v1.05 can't be flashed with the custom firmware.
Nisei is offline
post #148 of 726 Old 03-03-2013, 07:15 PM
raif71's Avatar
Quoted: 142 Post(s)
Liked: 58
What you mean is that for bdp-450, if the fw is 2.05 or lower, the cfw can be applied ?? Thanks.
raif71 is offline
post #149 of 726 Old 03-03-2013, 09:53 PM
Advizer's Avatar
Liked: 24
Yep. If you want to flash a BDP-150, you need one with the FW1.02. FW1.05 is "no go".
If you want to flash a BDP-450, look for the one with the FW2.05. FW2.09 is "no go".
Advizer is offline
post #150 of 726 Old 03-03-2013, 09:54 PM
Advizer's Avatar
Liked: 24
Then it does make sense.
Advizer is offline
Reply Blu-ray Players
Blu Ray Players , Pioneer
